p2 in 3.4m6 dependency check not working? [message #107334] |
Tue, 01 April 2008 21:17 |
Originally posted by: jens.ja-web.de
hi,
just did a clean install of the fresh 3.4m6 SDK, win32
I try to get used to the new Software Update feature. I added the two
install URLs for subversion, then I selected one connector for
installation. I saw a "checking dependencies" for a short moment but
then there was only the selected connector offered for installation but
not the other SVN components that are needed.
Also, I choose WTP (from the ganymede update site) and expected to get a
bunch of other plugins due to dependencies but no - only the WTP was
offered for installation.
Does depencency check acutally work? Do packages need updates to make
them compatible with p2 style installation?
thanks
Jens
Re: p2 in 3.4m6 dependency check not working? [message #107540 is a reply to message #107431] |
Sat, 05 April 2008 16:22 |
Pascal Rapicault schrieb:
> The dependency surely works!
> In order to simplify the UI, we have decided to no longer show the plugins
> and features that result from the installation of a feature, which is why
> for example you don't see EMF when you install WTP.
Ok, I see.
I tried again and noticed that it downloaded lots of additional plugins
silently in the background.
I'd prefer to get noticed that Eclipse will download a whole bunch of
other stuff that I did not choose initially.
thanks
Jens
FUDForum. Page generated in 0.02677 seconds
