using p2 to replace a plugin in 3.4m6 [message #107302] |
Tue, 01 April 2008 10:04 |
Francis Upton IV Messages: 472 Registered: July 2009 Location: Oakland, CA |
I'm trying to replace the pde.build plugin with a patched version
(patched for https://bugs.eclipse.org/bugs/show_bug.cgi?id=224098).
I'm using a headless build by launching the antrunner from the command
line and pointing to a build script in the pde.build plugin.
Back in the bad old days before p2 (3.4m5 and before) I would simply
rename the plugin (a directory in this case) and put my patched plugin
directory in the plugins directory.
However this does not work so well in m6.
I have tried putting the patched plugin (directory) in the dropins
directory, and it just executes the old one.
I have tried putting the patched plugin (directory) in the plugins
directory (with an identical name), and something is wrong with the
execution (the ${eclipse.pdebuild.scripts} variable is not set in the
ant script).
I have tried deleting the existing plugin and putting the new plugin in
the dropins directory and p2 complains about the missing existing
plugin, and seems to execute the new plugin incorrectly (as above).
What's the supported p2 way of replacing a plugin?
Platform UI Committer for Common Navigator
http://wiki.eclipse.org/index.php/Common_Navigator_Framework
http://help.eclipse.org/galileo/topic/org.eclipse.platform.d oc.isv/guide/cnf.htm
FUDForum. Page generated in 0.03056 seconds
