Re: Eclipse Juno themes [message #845136 is a reply to message #844978] |
Sat, 14 April 2012 19:43 |
On 2012.04.14 9:45, Yurx Cherio wrote:
> Some application wrongfully assume that the default system background color is white and build the UI based on that assumption. I am surprised to discover that the new Eclipse versions (e.g. 4.2M6 I am looking at) make that assumption. The new Eclipse UI looks odd and inconsistent :? with non-white system backgrounds. (see screenshot).
> My advice to the developers is to be consistent. If you want to force white background then do that and ignore system colors. However if you want to rely on the system color palette then don't make assumptions about those colors, e.g. that that the system text background is always white. You either use your own theme with all colors you want or entirely rely on the system theme/palette.
I agree: so much so that even earlier versions of Eclipse work badly on
Ubuntu being annoying when not positively unreadable for some situations
(like Javadoc pop-ups, errors, etc.). This has long forced me to adopt
the Clearlooks theme, a white background theme. I have never been able
to adjust the colors via Preferences to any working or acceptable point.
While this doesn't annoy me too much (being forced to adopt this theme
for my entire Ubuntu experience), it's seem a bit ridiculous to force it
on me.
My Windows experience with Eclipse never created this problem for me.
I'm guessing that most Eclipse developers are Windows-oriented.
I'm a white/wheat/light background sort of guy. I'm speaking from
Lucid/Maverick and earlier versions of Ubuntu, also SuSE 10.x. I don't
know what that ghastly Unity desktop brings to the equation.
(Hope my comments aren't too random.)
Re: Eclipse Juno themes [message #845235 is a reply to message #845136] |
Sat, 14 April 2012 22:18 |
Thanks Russell, I forgot to mention that my development environment is Ubuntu. Eclipse versions 3.x also had minor color inconsistencies but those could be fixed via Preferences. I couldn't find a way to adjust the colors in Eclipse 4.x so that they don't conflict with my system background.
What it means to me that instead of migrating to 4.2 I'll be moving on to 3.8. 3.8 also doesn't waste too much space between editors and toolbars. Increased spaces between eclipse views/tabs/editors makes the new version almost unusable on the not-so-large-resolution laptop screens. It may look prettier but I don't run Eclipse to simply look at how pretty it is
[Updated on: Sat, 14 April 2012 22:23] Report message to a moderator
Re: Eclipse Juno themes [message #847845 is a reply to message #847418] |
Tue, 17 April 2012 18:04 |
I haven't file a bug. I always question myself what if it is only my personal opinion and hence may be subjective. Thanks to your feedback it looks like this an obvious issue and a bug.
Even though I've been using Eclipse for a long time I have never filed bugs against it. I'll try to file one tonight.
FUDForum. Page generated in 0.09338 seconds
