Home » Modeling » TMF (Xtext) » Content assist with Xbase grammars
Content assist with Xbase grammars [message #843958] Fri, 13 April 2012 14:40 Go to next message
Jochen Schmich is currently offline Jochen SchmichFriend
Hi there,
As a newbie to Xbase-based grammars I have to ask this rather simple question:
Consider the following pretty straightforward case in which I use the JvmTypeReference to assign a type to a property.
I think most readers should be familiar with this Smile
Property: 'property' name=ID ':' type=JvmTypeReference
I've also implemented the JvmModelInferrer as proposed in the documentation. The linking stuff works nicely.
I didn't achieve to make the elements declared in the model (they don't exist as Java classes yet) appear in content assist.
Of course I only mean those elements being propagated as a JvmGenericType to the JvmModel in the JvmModelInferrer.
I guess that, after digging deeper into the Xtext codebase, I'll be able to get them to appear - but is there a nice out-of-the-box way to do this in my ProposalProvider?
I've tried whether the Entity-example project supports this - without success.
Can someone give me a hint on this, please?
Jochen
Re: Content assist with Xbase grammars [message #844052 is a reply to message #843958] Fri, 13 April 2012 16:28 Go to previous messageGo to next message
Sebastian Zarnekow is currently offline Sebastian ZarnekowFriend
Hi Jochen,
I think you are facing this one:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=350823
After you save your dsl file (and put the src-gen onto the source-path
of your project), you'll most likely see the proposals.
Did you face other problems with content proposals, too?
Sebastian
Am 13.04.12 16:40, schrieb Jochen Schmich:
> Hi there,
> question:
> I think most readers should be familiar with this :)
> success.
> Cheers,
> Jochen
Re: Content assist with Xbase grammars [message #849991 is a reply to message #844052] Thu, 19 April 2012 16:52 Go to previous message
Hi Sebastian,
sorry for responding that late.
Thanks for pointing me to the bug report - that exactly addresses exactly my problem.
Following your advice makes my stuff work, at least for tool development purposes. This approach doesn't work out in our environment yet - our generators are too slow for that (we currently generate from UML models from context menu).
I didn't have any other problems with content proposals...
Cheers & thanks,
Jochen
Previous Topic:compiling Xtext sources
Next Topic:Validation errors in Xpand template for project wizard
Current Time: Thu Aug 06 19:51:48 GMT 2020
Powered by FUDForum. Page generated in 0.02188 seconds
