Re: Object mapping issue in libraries created in jubula [message #846667 is a reply to message #843822] |
Mon, 16 April 2012 15:08 |
Zeb Ford-Reitz Messages: 33 Registered: November 2010 |
Member |
I'm not sure what problem you are experiencing. I understand that the libraries (Reused Projects) contain Component Names, but where are the Component Names mapped (i.e. in the Reused Project or in the Project with the Test Suites)? As far as I can recall, the Component Names need to be mapped in the Project with the Test Suites. If mappings from Reused Projects were also permitted, this was unintended, unspecified behavior. The Component Names themselves, however, may be defined in a Reused Project, thus allowing these Projects to be used as libraries.
I'll assume for now that the Component Names are mapped in the correct Project.
Have you checked whether the incomplete Test Suites are actually runnable. We have had decoration issues in the past, where a Test Suite was incorrectly marked as incomplete, but could still be executed.
Beyond that, the order in which the Projects are imported may be important in this case. If you have not tried already, please try importing first the Reused Projects. Once those Projects have been successfully imported, then try importing the Project containing your Test Suites.
- Zeb
FUDForum. Page generated in 1.21157 seconds
