Home » Archived » Memory Analyzer (MAT) » CorruptDataException with (MAT+DTFJ) when reading a jextracted core
CorruptDataException with (MAT+DTFJ) when reading a jextracted core [message #9636] Wed, 25 March 2009 10:41 Go to next message
François Mercier is currently offline François MercierFriend
Dear All,
I am generating a core from J2RE 1.4.2 IBM AIX build ca142-20080923 (SR12)
using gencore and process the genenrated core on the same AIX machine
using jextract.
I the transfer all the 3 generated file (core + sdff.hdr + sdff) on a
machine (OS=win32, ARCH=x86_64) and open it using MAT + DTFJ.
Has any one seen the parse error (pasted below) before ?
Francois
!ENTRY org.eclipse.mat.ui 4 0 2009-03-25 11:17:53.272
!MESSAGE Problem finding class loaders
!STACK 0
com.ibm.dtfj.image.CorruptDataException: IOException java.io.IOException:
Negative seek offset, could not read address 0x3000308
at
com.ibm.dtfj.sov.java.imp.JavaClassLoaderProxyImpl.getObject (JavaClassLoaderProxyImpl.java:614)
at
com.ibm.dtfj.sov.imp.JavaClassLoaderEffigy.getObject(JavaCla ssLoaderEffigy.java:101)
at org.eclipse.mat.dtfj.DTFJIndexBuilder.fill(DTFJIndexBuilder. java:327)
at
org.eclipse.mat.parser.internal.SnapshotFactoryImpl.parse(Sn apshotFactoryImpl.java:183)
at
org.eclipse.mat.parser.internal.SnapshotFactoryImpl.openSnap shot(SnapshotFactoryImpl.java:101)
at
org.eclipse.mat.snapshot.SnapshotFactory.openSnapshot(Snapsh otFactory.java:87)
at
org.eclipse.mat.ui.snapshot.ParseHeapDumpJob.run(ParseHeapDu mpJob.java:54)
Re: CorruptDataException with (MAT+DTFJ) when reading a jextracted core [message #9661 is a reply to message #9636] Wed, 25 March 2009 11:43 Go to previous messageGo to next message
Andrew Johnson is currently offline Andrew JohnsonFriend
Does this error stop you opening the dump? If it doesn't then don't worry
too much about the error. Some dumps do have corrupt data in them and the
DTFJ adapter attempts to work around the problem. The class loader would
get ignored by MAT and any classes loaded by that loader would instead by
indicated as having been loaded by the bootstrap class loader.
If you still have problems you could try a newer DTFJ adapter. See the
archived update site attached to
https://bugs.eclipse.org/bugs/show_bug.cgi?id=269534
https://bugs.eclipse.org/bugs/attachment.cgi?id=129464
A new version of the DTFJ feature should be available from IBM shortly.
Andrew
Re: CorruptDataException with (MAT+DTFJ) when reading a jextracted core [message #9683 is a reply to message #9661] Wed, 25 March 2009 14:45 Go to previous messageGo to next message
Hi Andrew,
thanks for your fast answer.
Yes, this error stops for opening the dump.
The latest error is:
!ENTRY org.eclipse.core.jobs 4 2 2009-03-25 11:17:53.693
!MESSAGE An internal error occurred during: "Parsing heap dump from
'E:\mat\laurs57b\lab36\core.622872.3.sdff'".
!STACK 0
at
com.ibm.dtfj.sov.java.imp.JavaClassProxyImpl.getMirroredData Reader(JavaClassProxyImpl.java:943)
at
com.ibm.dtfj.sov.java.imp.JavaClassProxyImpl.getClassLoader( JavaClassProxyImpl.java:808)
at
com.ibm.dtfj.sov.java.imp.JavaObjectProxyImpl.initializeHeap Object(JavaObjectProxyImpl.java:351)
at
com.ibm.dtfj.sov.java.imp.JavaObjectProxyImpl.<init>(JavaObjectProxyImpl.java:304)
at
com.ibm.dtfj.sov.java.imp.JavaObjectProxyImpl.getInstance(Ja vaObjectProxyImpl.java:297)
at
com.ibm.dtfj.sov.java.imp.JavaObjectProxyImpl.getInstance(Ja vaObjectProxyImpl.java:283)
at
com.ibm.dtfj.sov.java.imp.JavaClassLoaderProxyImpl.getData(J avaClassLoaderProxyImpl.java:152)
at
com.ibm.dtfj.sov.java.imp.JavaClassLoaderProxyImpl.getObject (JavaClassLoaderProxyImpl.java:612)
at
at
at
at
at
I've tryied your proposed solution using newer DTFJ adapter from bugzilla,
but when deployed in RCP MAT using the 2 steps as described, the File/Open
Heap Dump menu doesn't recognize anymore the IBM format (only HPROF is
available).
Any other hints ?
Francois
Re: CorruptDataException with (MAT+DTFJ) when reading a jextracted core [message #9922 is a reply to message #9683] Sat, 04 April 2009 20:09 Go to previous message
Please try the new DTFJ adapter and the new DTFJ as explained in here:
http://www.eclipse.org/newsportal/article.php?id=264&gro up=eclipse.technology.memory-analyzer#264
Previous Topic:How to get all objects which class implements specific interface?
Next Topic:IOException with (MAT+DTFJ) when reading a phd file
Current Time: Thu Sep 19 23:06:18 GMT 2019
Powered by FUDForum. Page generated in 0.01994 seconds
