Home » Modeling » TMF (Xtext) » Xtext 2.3 M6 Grammar Editor can't resolve JavaVMTypes import correctly(When I import "http://www.eclipse.org/xtext/common/JavaVMTypes" a warning marker is created)
Xtext 2.3 M6 Grammar Editor can't resolve JavaVMTypes import correctly [message #842482] Thu, 12 April 2012 10:38 Go to next message
Jochen Schmich is currently offline Jochen SchmichFriend
Hi everybody,
if I introduce the following statement:
import "ht tp://www.eclipse.org/xtext/common/JavaVMTypes" as types
...a warning marker tells me that:
The imported package is not on the classpath of this project
which may lead to follow up errors.
The MANIFEST.MF looks correct:
Require-Bundle: org.eclipse.xtext;bundle-version="2.1.0";visibility:=reexport,
 org.eclipse.xtext.common.types;visibility:=reexport,
 org.eclipse.xtext.xbase;bundle-version="2.1.0";resolution:=optional;visibility:=reexport,
 org.eclipse.xtext.generator;resolution:=optional,
 org.eclipse.emf.codegen.ecore;resolution:=optional,
 org.eclipse.emf.mwe.utils;resolution:=optional,
 org.eclipse.emf.mwe2.launch;resolution:=optional,
 org.eclipse.xtext.util,
 org.eclipse.emf.ecore,
 org.eclipse.emf.common,
 org.antlr.runtime,
 org.eclipse.xtext.xbase.lib
Import-Package: org.apache.commons.logging,
 org.apache.log4j,
The editor seems to work anyway (at least after a restart) - in terms of content assistance etc. JvmType, for example, can be referenced and used correctly. The generator doesn't complain either.
I do currently use Xtext SDK 2.3.0.v201204101126.
Re: Xtext 2.3 M6 Grammar Editor can't resolve JavaVMTypes import correctly [message #842489 is a reply to message #842482] Thu, 12 April 2012 10:43 Go to previous messageGo to next message
Sebastian Zarnekow is currently offline Sebastian ZarnekowFriend
Hi Jochen,
That's probably a PDE issue. Please remove the common.types bundle from
your manifest, save it, re-add that bundle and save the manifest again.
That may help.
Sebastian
Am 12.04.12 12:38, schrieb Jochen Schmich:
> Hi everybody,
> Quote:
> Require-Bundle:
> org.antlr.runtime,
> org.apache.log4j,
Re: Xtext 2.3 M6 Grammar Editor can't resolve JavaVMTypes import correctly [message #842501 is a reply to message #842489] Thu, 12 April 2012 10:59 Go to previous messageGo to next message
Right, that worked out nicely. Only tried reordering before. Thanks for the quick reply!
Re: Xtext 2.3 M6 Grammar Editor can't resolve JavaVMTypes import correctly [message #842502 is a reply to message #842489] Thu, 12 April 2012 10:56 Go to previous messageGo to next message
The "Update the classpath settings" on the manifest editor overview page
is often a good way to persuade PDE to do what it could have done anyway.
ed Willink
On 12/04/2012 11:43, Sebastian Zarnekow wrote:
> Hi Jochen,
> from your manifest, save it, re-add that bundle and save the manifest
> again.
> That may help.
> Regards,
> Sebastian
Re: Xtext 2.3 M6 Grammar Editor can't resolve JavaVMTypes import correctly [message #842554 is a reply to message #842502] Thu, 12 April 2012 12:02 Go to previous messageGo to next message
Hi Ed - thanks for the hint -
Sadly, that didn't work in this particular case - this was one of the first things I tried, though. I had to follow Sebastians advice to get it to work.
[Updated on: Thu, 12 April 2012 12:02]
Report message to a moderator
Re: Xtext 2.3 M6 Grammar Editor can't resolve JavaVMTypes import correctly [message #870879 is a reply to message #842501] Thu, 10 May 2012 07:13 Go to previous messageGo to next message
frank fotso is currently offline frank fotsoFriend
Member
hi,
i'm frank , i have the same problem with Xtext , when i generate an Xtext grammar from an Ecore model i have this 2 warnings :
- " The imported package is not on the classpath of this project which may lead to follow up errors."
- "The imported package refers to elements the package registry instead of using the instances from the workspace"
can you help me to fix this ?
thks
Re: Xtext 2.3 M6 Grammar Editor can't resolve JavaVMTypes import correctly [message #870910 is a reply to message #870879] Thu, 10 May 2012 08:47 Go to previous message
See https://bugs.eclipse.org/bugs/show_bug.cgi?id=367013 and
https://bugs.eclipse.org/bugs/show_bug.cgi?id=366476.
Ed Willink
On 10/05/2012 08:13, frank fotso wrote:
> hi,
> thks
Previous Topic:mismatched input 'cmpResearchItem' expecting RULE_ID
Next Topic:dynamic template proposals in Xtext
Current Time: Sat Jan 16 03:57:28 GMT 2021
Powered by FUDForum. Page generated in 0.02218 seconds
