Home » Modeling » TMF (Xtext) » Change Default size of hover
Change Default size of hover [message #842356] Thu, 12 April 2012 08:13 Go to next message
Andreas Graf is currently offline Andreas GrafFriend
Dear all,
is it possible to change the size of the hover that Xtext provides? In our project, we are presenting quite some information in the hover, and it is somewhat awkward that the user has to focus the hover to see all information by scrolling.
Optimal would be adjusting the size to the information that is displayed, alternatively changing the fixed size would be OK.
Andreas
Re: Change Default size of hover [message #842398 is a reply to message #842356] Thu, 12 April 2012 08:57 Go to previous messageGo to next message
Christian Dietrich is currently offline Christian DietrichFriend
Did you try to customize AbstractHover.getHoverControlCreator
Need professional support for Xtext, Xpand, EMF?
Go to: https://www.itemis.com/en/it-services/methods-and-tools/xtext
Twitter : @chrdietrich
Re: Change Default size of hover [message #842411 is a reply to message #842398] Thu, 12 April 2012 09:14 Go to previous messageGo to next message
I am not quite sure where to put the size there. Should I implement my own getHoverControlCreator() and my own implementaion of DefaultInformationControl?
Re: Change Default size of hover [message #842425 is a reply to message #842411] Thu, 12 April 2012 09:28 Go to previous messageGo to next message
Hi the DefaultInformationControl may already have size properties you
can customize I guess. But for details you should have a look into
the code yourself. Subclassing DispatchingEObjectTextHover should be
done in minutes.
Re: Change Default size of hover [message #901294 is a reply to message #842425] Fri, 10 August 2012 16:19 Go to previous messageGo to next message
Dobes Vandermeer is currently offline Dobes VandermeerFriend
There seems to be a bug in the eclipse hover control where it doesn't calculate the size of <pre> blocks properly. There are probably some other cases it doesn't handle well either.
To see this try creating a java file and use a <pre> block in your javadocs, then hover over the element to see what your <pre> block looks like. For me at least, with eclipse juno on Windows 7, the hover popup is too small.
Re: Change Default size of hover [message #901295 is a reply to message #901294] Fri, 10 August 2012 16:20 Go to previous message
... thus the workaround here is to avoid using markup like <pre> that screws up the size calculations ...
Previous Topic:Register variables in xtext block of code
Next Topic:Content assist and validation
Current Time: Thu Mar 04 01:46:20 GMT 2021
Powered by FUDForum. Page generated in 0.02528 seconds
