UML2 Log Interactions [message #106280] |
Tue, 24 July 2007 15:03 |
Originally posted by: cvkmurthy.hotmail.com
Hi Experts,
I have two log files, client and server log which contains
transaction IDs. I defined transaction ID as an Extended Data Element. I
am using these transaction IDs to correlate the files. I defined a
filter which filters the log records based on a particular Transaction
ID. I did this by defining ExtendedDataValues like *<trans1>*. I am able
to see the log statements having this transaction ID in the Log View but
the UML2 Log Interactions does not show up the log interactions. What
could be the reason?
Krishna
Re: UML2 Log Interactions [message #106916 is a reply to message #106513] |
Tue, 31 July 2007 07:32 |
--------------080908090208070000050503
Hi Alex,
I customized the LogCorrelator Engine provided as TPTP example to
correlate the log files. Transaction ID is part of each statement in the
log files. I created an ExtendedDataElement "TransactionID" and I am
setting the value of this element with transaction ID read from the log
files. When I apply "Show correlated log records only" I could see all
the correlations. I defined a new filter which shows only the statements
having the a particular transaction ID. Please see the attached
document for the screeshots. In the log interactions view the logs are
not correlated.
Krishna
Alex Nan wrote:
> The log interactions view is using the same filtering mechanism and filter
> definition but with an additional flag "Show correlated log records only" in
> the filter definition. If this flag is specified in the filter definition
> the logic of applying the filter is the following: both correlation source
> and target events would need to satisfy the filter predicate in order to be
> included in the result set. So if you open just a log (not a correlation!)
> in the log interactions view and you have a filter defined that filters out
> uncorrelated events then you won't see any events in the view.
> I need two questions answered from you in order to understand your problem.
> You are saying that you used the transaction ID to correlate the log events,
> did you create a correlator and registered it with the TPTP framework?
> If so, are you viewing a correlation created with the above correlator in
> the log interactions diagram or just a log?
> Kind regards,
> Alex Nan.
> "Krishna" <cvkmurthy@hotmail.com> wrote in message
> news:f854bj$f1o$1@build.eclipse.org...
>> Hi Experts,
>> Regards,
>> Krishna
Content-Type: application/msword;
name="logcorrelation.doc"
Content-Disposition: inline;
filename="logcorrelation.doc"
0M8R4KGxGuEAAAAAAAAAAAAAAAAAAAAAPgADAP7/CQAGAAAAAAAAAAAAAAAC AAAA8QAAAAAA
AAAAEAAA8wAAAAEAAAD+////AAAAAO8AAADwAAAA//////////////////// ////////////
///////////////////////////////////spcEAI2AJBAAA+BK/AAAAAAAA EAAAAAAABgAA
BQgAAA4AYmpialwuXC4AAAAAAAAAAAAAAAAAAAAAAAAJBBYALhAAAD5EAQA+ RAEABQAAAAAA
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAD//w8AAAAAAAAAAAD//w8AAAAA AAAAAAD//w8A
AAAAAAAAAAAAAAAAAAAAAKQAAAAAAKQDAAAAAAAApAMAAKQDAAAAAAAApAMA AAAAAACkAwAA
AAAAAKQDAAAAAAAApAMAABQAAAAAAAAAAAAAAN4DAAA0AAAA2gQAAAAAAADa BAAAAAAAANoE
AAAAAAAA2gQAAAwAAADmBAAADAAAABIEAAAAAAAA1wUAALYAAAD+BAAAAAAA AP4EAAAAAAAA
/gQAAAAAAAD+BAAAAAAAAP4EAAAAAAAA/gQAAAAAAAD+BAAAAAAAAP4EAAAA AAAAVgUAAAIA
AABYBQAAAAAAAFgFAAAAAAAAWAUAAAAAAABYBQAAAAAAAFgFAAAAAAAAWAUA ACQAAACNBgAA
aAIAAPUIAAA4AAAAfAUAABUAAAAAAAAAAAAAAAAAAAAAAAAApAMAAAAAAAD+ BAAAAAAAAAAA
AAAAAAAAAAAAAAAAAAD+BAAAAAAAAP4EAAAAAAAA/gQAAAAAAAD+BAAAAAAA AHwFAAAAAAAA
AAAAAAAAAACkAwAAAAAAAKQDAAAAAAAA/gQAAAAAAAAAAAAAAAAAAP4EAAAA AAAAkQUAABYA
AAAmBQAAAAAAACYFAAAAAAAAJgUAAAAAAAD+BAAACgAAAKQDAAAAAAAA/gQA AAAAAACkAwAA
AAAAAP4EAAAAAAAAVgUAAAAAAAAAAAAAAAAAACYFAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAA
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA/gQAAAAAAABWBQAAAAAA AAAAAAAAAAAA
JgUAAAAAAAAAAAAAAAAAACYFAAAAAAAApAMAAAAAAACkAwAAAAAAAAAAAAAA AAAAAAAAAAAA
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAJgUA AAAAAAD+BAAA
AAAAAPIEAAAMAAAAUH5Qi6rSxwEAAAAAAAAAANoEAAAAAAAACAUAAAoAAAAm BQAAAAAAAAAA
AAAAAAAAVgUAAAAAAACnBQAAMAAAANcFAAAAAAAAJgUAAAAAAAAtCQAAAAAA ABIFAAAKAAAA
LQkAAAAAAAAmBQAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAA
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAC0JAAAAAAAAAAAA AAAAAACkAwAA
AAAAACYFAAAwAAAA/gQAAAAAAAD+BAAAAAAAACYFAAAAAAAA/gQAAAAAAAD+ BAAAAAAAAAAA
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA/gQAAAAAAAD+BAAAAAAA AP4EAAAAAAAA
fAUAAAAAAAB8BQAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAHAUAAAoA
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAP4EAAAAAAAA/gQA AAAAAAD+BAAA
AAAAANcFAAAAAAAA/gQAAAAAAAD+BAAAAAAAAP4EAAAAAAAA/gQAAAAAAAAA AAAAAAAAABIE
AAAAAAAAEgQAAAAAAAASBAAAZAAAAHYEAABkAAAAEgQAAAAAAAASBAAAAAAA ABIEAAAAAAAA
dgQAAAAAAAC4AwAAFAAAAMwDAAAOAAAA2gMAAAQAAACkAwAAAAAAAKQDAAAA AAAApAMAAAAA
AACkAwAAAAAAAKQDAAAAAAAApAMAAAAAAAD/////AAAAAAIADAEAAAAAAAAA AAAAAAAAAAAA
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAA
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAENDQENAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAA
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAYAAAEI
AAACCAAAAwgAAAQIAAAFCAAA9/Pv5+8AAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAA
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAADwNqi94AABZoYh4XAFUIAQYWaGIe FwAABhZoaxLP
AAAPA2oAAAAAFmhiHhcAVQgBAAUABgAAAggAAAMIAAAFCAAA/QAAAAAAAAAA AAAAAP0AAAAA
AAAAAAAAAAD9AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAA
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAABAAAA AwAGAAAFCAAA
/QAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAA
AAAAAAAAAAAAAAAABAQAAQEBLAAxkGgBH7DQLyCw4D0hsAgHIrAIByOQoAUk kKAFJbAAABew
0AIYsNACDJDQAgAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAA
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAACL 3gAARABkAAAA
AAAAAAoAAAAAAAAAAAAAAAAAADw+KzICMgIAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAA
AAAAAA8ABPAwAAAAsgQK8AgAAAABBAAAAAoAACMAC/AMAAAABEEBAAAA/wEA AAgAAAAQ8AQA
AAAAAACAYgAH8AfeAAAGBtm8R2aN/PoyWN0pxedvr4T/AOPdAAABAAAARAAA AAAAFAAAbh7w
290AANm8R2aN/PoyWN0pxedvr4T/iVBORw0KGgoAAAANSUhEUgAABAAAAALi CAIAAADIIzNn
AAAAA3NCSVQFBgUzC42AAAAAAXNSR0IArs4c6QAA3XVJREFUeF7t/X9oHEe6 6I23L74whhyY
AS2MIAvRsgtReBdicwMr8eYPT8gfUciFyPjA2qwhUbLgdW4gtm4giW7+yKsk kK+ShbyxDZso
gV3swDFW4C5R4Bsi/5GDtJCLFNiDFdglY9jACCKYARvUcAz7Pj01Krf6Z3VP zWh69Om0lZ7q
qqee+lR19fNUVXcfunDpe8e3vfvnlnO45AW47VB1LFvpSPuvhDjO3fZfOSUH d917cVRMCWSD
AAQgAAEIQAACEIAABCwSUMa5Z6OXHNf1zPLOL/mpjnbtcDHUO1vbXN9pXPjX XZPecRrfbB06
91bbASg5F2+0k1XHnPtK5VLH4D8i6UtOuR2hpCz7exItFghREIAABCAAAQhA AAIQgECIgBp5
139jCLmhIfhW27Rv3nZadxxnY9O507pwpurecZt199C5N27KEP7FNdcpjzol MfPF1i+V21a+
GvQ/ohyGw07JZ/rr43Bm1BsEIAABCEAAAhCAAAQgkJWAtquVpd352Rn4b6/E CVj5yivY3XZ0
zHaIu9M54TkAsm27Tr0+84i7c8c5NPM/1hf/w/Gsf2fHGansUVT8AW9rewU6 P+2CyBk9JxA4
yFpc4kMAAhCAAAQgYIUAC3GtYEQIBPaFgN/M9isglr1n67vt5fe7u4qsrHV1 Vm2duYL2MiHl
Hqi/8nO76fxn6dTY1qFTZ9evftdOXC7fy+jwEW9lv4rdcQPSMPh7HHqfNFqc hwAEIAABCEAA
AhCAQAoBedpWb8rA1iFhe3uPNb7TGalX8cWwFwfgtuv8UD/1+Ogh5+FVZ7Tq OC2ntOsAdNb8
tH0A7TSovPUzwf7s1SmdJdY/bRkCEIAABCAAAQhAAAI5CPgt/qDp7xN3t72+ J9LqVhLUqf+U
f7suhDeN0D7+od52AGSrlOTZ3459n+AAhIvR8UV2T0QqnaPwJIEABCAAAQhA AAIQgMC+Eph5
tDT/63K1nE2J5y63Fr++N3KfX4h6Q0/b2J45Xpr/TXZN3t5a/N+Nzns7PV+g 6fkALfeQ8/Mr
zn1jIQdAhv93x/vDr/3ZM9jvczI0HCYBsrUTYkMAAhCAAAQsEeAWbAkkYiAg NvdrJ8sX/yxv
0XGbbvuZ2rvtB3MPO/7HbTuP6rZPNV13tOReebn87hfuYtt8tyXko6ebrU8v Os2WK0a8LObx
ngRQRvjuo76efb9rlt91d0Tl+0ZH37kye62y+G/1Tm22dpzDW87WzUNO9bpT HfWG/+V1P/JX
Nu+PzwFQKQ47tTtXFo67c5tjy62adkfurUPC+udCgQAEIAABCOw7ARyAfa8C FBgWAv9cqs5+
4oyVPTNYXqTj+QDtVTSelX1XXp7TGZv3HACx/v+zHeGOxGyVnfry+xOjz25J FFtCWr+fdUbG
5O1A7p2Wc2fXB/hPnw/geSC7joE4CeK0tFr1w+Vjf1wffWLDs9jvlryEbQfg vwTrSFv/nYeK
d8/fdV6rbh4tNy78ZFGCpsvL8rfqbAa/AjYsVU45IAABCEAAAhCAAAQOOAEZ +/deh9l+G77a
xfRtvx9TBssd73tZu6/hUSHee/Mdp76141811K0QtZio2fLeyyP/vPf0qN1x /qt6XtfTxdPk
3sO6naF8t1GvjrSTd051XvipHQD1AMAR52775f+Hd5ySGPd1Z+R69f7lsV9c dFork2OjzuGN
tY3G548vnjjakFhXfn1z+v72IwR6Y+DhgF8oFB8CEIAABPaXgGegsEMAAjYI yDvy77QH9d3O
8L8M/ruyBMeVBTZOU+YE5JR8ZmvH22X4f2f3tfid72WpK7FLIdq0ljzvuN7w v1oCJLsosdN0
7+y4Lfkre6s9OdCOIOuC1MtAO3a/5zrs9kzeQWgGQJ0cufjaEyur593vX5xc /d3E1EjzQnm9
dL+z9R/1xdaJ0V+MyjtDr7/ozYZUtpf2t6MjdwhAAAIQgAAEIAABCPSCgLes v23oi70tboBY
/2J1e8di98velHH59t6O0F4g1NZi7wO0fiELzzsf/A/no5dKV/5n6corpev/ y9s/f8Pbv3qr
tPpOKVaInJAFPJLlHbf8+Iny//rAM/1lgsIVi7/ltGT3zlY//qr861lRRXsj kVjEASh7zkFg
5H5r7s2vby5+c33t1sbK5sr1+kZtvOK0Pr/yt+rU4+NjD4yVSqNH72/Ky0Mb zrhf7s7Vstqb
fyzffK+88BvtbWSolO/f9yQ0/lCWNPJXHcgm4SJWHfvDM4i2FNWviRapCm4p h3tielpSXV+B
A+ul2HeB0hSFpCrm+jv3qum1pzvhjY/LV16811zjwsPE9r1oKAABCEBgDwH/ d4I4hgAEuiEg
T9X+p7L7O8a9WNVizcvTwGrdv/ez/b3ezn7vjZvti1JlHRCS1mF5AiPjyCJ+ b3S/rcrDExKl
+t6V9sp+CWk/CnzXrV71FuaUHp9uP6MbLUaFqxmA9hPAsnX8Fe/43E9eWNnc XPzr52tbm45M
cDTXZQHTujN6rrxQPtyYfnx8tLV85evSsjvTnlPwzyw4lZ++O/f6SqXknnui 9NEz2XwAMc5G
R5yL1xpj4++W/rHexueqAwn3Vl9tft7BshueRtL++aAmvhxKX3vPSFjeelbS I6daUlmyK4XV
sew9KUUXUFbfKIuB3oUAZ3ysJC575dGV+f/f6vj94kx6zXLm8dLs0yXx2iW8 udWa/lWnucaF
SxJNTOTIz/qt1qCx6oYSaSEAgWEgwPofCEDAFoG2ce894Cs2tmfuu95P7836 3iYPAXesf89Y
bccMbLtLgPxC8ncy6gFfUeU/3dbLp5Wc6qXP2z6Gp0v139pms+Ns/fefeRaL Pye1EEgeAva2
8BKgXdWrTn2sWp0//sHKZn1la1Pyqo/PLGyMukcnN+6bccrj9X9fO/besaVW O/vd4vlWFzkX
bx374Evv5IkJpyRLkYw3Mc5kmzt/1XnklPvTY6O/bY09tfcxg23vkeqIcOMs rEVsa9Lrrdcl
dR+dkV2XQv30h/S6gCbyj/7cKcsTN3/b2xJMUu7GefKN1kNnvGfW39x4yGs/ I6VS4+a5x0vi
Ui5/6YVf+ca7HiZ/4UpzjQtXwhSfE7+elOONvzacn3teOBsEIAABCEAAAkNJ QF6t07bg2/a3
MvpD5VQh93yAkDNwT4jYxv+P++Tr7mOvuo+97E6ed4+96D70O2//2W89MUEh flEylimv/WmH
bL14Qmkha368v1d91r9+Q+gePfeMyMtrQL9y7h91/qXklI+0XYL2M8V3V+ef GD96dLRyd3Py
DzMTzuTcb+eWG059+/PPnxp171acrfqxd8Y2/et/2trs/NETIUPI7qPnvJ9X S1KM0Yll9xc1
OZaQzR+8gfzRZ70Srr9TUua+BB572QtRcdR25JSrf8qxPivCm/+4oOOo8PpW Z36gse0s3nDe
/MyLL6O8kpc3KeM66z84T74RrK/GxyUxK2Xzp4qTpgXKTJBKpYuplFHaBgIj ixmnW1jhMIF8
JdVU4w7CyodrxwMVIiYJV75zjj3gMRGMS9840494dSGUPvhzpyI+f72kIkjg 9TXnhQ+jaz+u
KgOtIg5puIFFFvaD50szx+WBHnd0/GL9bxdEK28CRLzNUqXTXB/fqH9xNDJc 0miZzXZTHx17
1zl6yr2v80x9KmciQAACEIAABCBQFAL//LeyGOhjP9ldI6OW+vxnx0bvLAdq rwLas5bebe1s
3Wws1w79a0vOBITI0n9xAOKEfH+p9LPfte1VLeS/e8PN//zf1a0zk6XqmEK3 65C43gyAb9ua
/plfk+ZdZ/PHnelvGocm6u1wWUQkf+vOD6v/xSlV2i8Sak8UqKmBu/KKUGf9 jlsXBe4/+trj
czNPTLfcnWW3tDAuxm/F/W6ltbmyefjonneABr4XdtiZecKTVv97y/OZds9u bmx+/nWrVF9Z
fcOz/pe+bl35dFMOVl/34B4507HR26tQLuqfcux/nCIcPlZ1Fj5tXPxTXUzP meNuyXGFoFpK
tPjJRvk+Z3zELd1pBF6MMPpbtzKxLGs5JOYLj4vr09EzLM0D8o4ncOUvrbFf dBbMeKz8c0y6
AnyBkcWM1C0y0FZJ098IsVd5Zf2v/J9O7ay/1SlpBDHHqT3orHzjzn+4KXzO PSEOmDv/SUMM
6NmnPKRi/UuE+g8eallmM15ple424+SLFmH4gVaRkFaS6wYWV+QTj3hFXf+P pnP/uHLkvAtC
LHj1Ji/526rHhWuZH5z1pg5k/Y+8kdctt9MO0+7vSziGAAQgAAEIHGACen2/ t8gnzEGvgpFP
g7UX4nTsir0x/UIiWPqEyNmgEPW6T9lkIsL7/peaAejosvXbx7TArX/11ji0 I4d06WSh7Hwx
dyt73wKkjRjHXWq5yz+6V35wtn4xPTY69vmOe7S1PP7fSs5fFt0f61Nfn+rk p15EKp5DZ11R
J1hWUc8/7Tkoi3+UBwc6/oqcm/nd8guXd5yfHh1/wIs5c2rxhWtlORj/eam0 vfuVsrYM97g3
h2C+vfvq1bkvvIFYWd3hNG6OelK9pURzX1Y7gbe9V5f6t/W3So2vp+b+p7eW oyzx1SMH7S0g
TULEMJXtxMlF55Fpc60iixmpm4nCkbqZJzRXu1PYp6V2vLYydr/UzqYcxBGb OXXx3S/axAXd
+Yvvftl+Ga0kra/K2L9steMXncrYQ6+Xnny5LjMycfLj4GvNpVUkp9UNLLKw n79aEm9QLp8n
T151frLn+fV78fe2w8jw2i+84PVvGv62bY530GMOkzNDWSAAAQhAAAK5CcgN uz3k37H+1Wqc
/6q+BhC9+03ve4vk/UKUERAnRE7t9SXasZXh3vkGmTyP0BnAPOxU/+Ct/1Fb 9d9u7n37kDwW
vFNSOntv+W+P9Yvj0H4e4L94hrtyLPQQvqzwkdNNd/mH5sV/uDf/ulYpOVfv VK4/etP5cnHz
m5VzX1Y3XM9ovrd1FOn8T5bofPAb741IC39qLH7Rcstiad1b2yPfJXZLo503 pHqDr6NeyST3
hpiY96IFHiwOndKZ+yQfLndC/74mq01km3+9Nv+MJ7+17Tp/X/M9r1yS9TYy yL281qoc3X2T
6a2NPXr6pHnW7C4f9757/oxf4F4copW3RxYzUrd4hbstqaghS7PUvldh/09/ Lh21pR6bS15h
27VTjyHWSajqUW2uRvfD5r3R9BGvGbjVo27Z+46dbAH5CfD9bNPTthtYuKTi lE7+3JO0+KcN
mdoSNRTz9qZQeEuDvNYSE65lihMizu0LLy87XmNIoMopCEAAAhCAAASKS2D3 9T5tHyC4hX0A
ZQV5K4XUI7i71sXu2qF0IdqU0kI8e71t66r3/3iTAJ01SNX3O+t/tn7bMcur f7zZ+VqZxO88
CdC2aeRlP6KRrPe5ry3qcKk9A6C19Myy9oi+rPSR1wlttZwfGrM/dcruxj9H L7TWlpa+3JxZ
G1u6e8KLoz9FtseC8n6oN8kce+Tdd69tOUenvMxChv29RxxUoURLGXntyv7f 4yOoR5DPPX9U
FqU0Ws4Hn6x7D2v6WqAaOJcpCGfc9xBnQAFd1YJEV3xYyd2q6UT35RJZzEjd YhX26XCv5fl0
SC2p95Kn33YqpXTj3Wh71Z/LbmH1S4G8VfLb9WhiaertIbBLRgUG5AdrP0ay UdqoruY1WZJ0
2Nn4j9bcGyvOL45JduKjyiZeohwv/MY7lqVKzgNH48IVug+eb8eUtW1VWf9T HkL7/1474wgC
EIAABCBwoAl4L/8RE7q9/qfzzv72a/u/eqMky7zX32gPo+9+f1fitM1tMRf0 Qp6OlauFeEZv
m6j629mShewuAep83qudtPr+dZV263feKqDWs8faOZfK//Z9WwNvsVBpj9/i t19lBqAzsK0+
BaDcAuejZ8aaLzvrxxv/fHxlunTF+evc4sdLy7dKJ76bXXOmnJKs/vdPfPg+ SrxbEPeJ17z9
/on2YHCEgbz5g5fX4qWp6+2Xr2/+R0PMqeQZAN/7leLt9F0FXjjuxbn44YZY mQ/98l1vUcqY
uEf3DEOlwIUXJ6682hnRl+OEeYb6lhf/+h9l/U8GDyCymJG6xSusW0d0qVNL qkrdqZEnXosZ
sfbnUlr9u5fX59dOXfnitUb9wsrXXm3GEEtRT4uSfG/KFy5e9ZSJlJ8A31/1 ZmmDHsAHvymJ
AyNfyag94S3icktVyW55wyvm1ONj8tWN2ni7QcqKtcpYXLhCNznWbrF/k/U/ R4dz+N/7xjk7
BCAAAQhA4MATEEN+9x3/e016n+3ePtwRQ0stJfDiy1uD2jMA6mYaFiJ2uXqX 6H/dI0eEqN97
hOyuQNlpv+lfvfV/j/W/O0LdOtN+BkCWtS811HMCokn7gwC7RrvMA9wnr/zx FszvPgNwWKnt
xfj8d42ZR5v1ry+6m4uLHy+++Yf1zbujM5dm6vfPOHfLzkjnDTwdcVqoXkGk Mo+ZFtGnJt9x
Nm+500+NT/1f7sbfndpTV+XBgD1LlzrPK+yiOexc+T/eO4U8E9yfV8yxfJBZ NpkB8NaZ/ONC
/X9PLP5OeWmd/dhbngLyAMDofa68hki2sftlrZPPH9srWeLLW25qx8ea7++N o2W2NZW8dv7g
ql3yiixmpG6xCuu2kbekRs+n+nM57Dz5vrP6H+6x/zYqtSNt6PMvN+QZgEhi Ol1cpXRE/V8V
AVK5z/l8rS6iIuUnVOvyt17r9N7+FKNbRMvZ2wJPT3i1JuP1at2Rqp3Zz5yl /+M9NCKv9JEn
mK986crqILc6FheuSEpM2VbXGvJAvBHb+JWCJIcABCBgn8C9fpkjCECgawJt B0C5ATHbvfFZ
z5hWMf9zzwyACtRCOt/9lWmE/9WZRrj5Rul7sTPf8XIIClFP28qmPgLQdgPc f1+WAO8JYPUR
AO0DnPK+ACAr9j0xvleX+jTvPLV7yLn/pnN/xRHTt9yewjjsnPrF6lz5hY2/ NZrOsWNnPiof
lmeO62PlVuW9cec+GfLcuwrKj6N9XPrsTU/7p2WkObiFT5V+2HS+aS/Bn5h2 q52HMgPR/D9L
8gm0vy474zW3XN0T7stUhV/4w2sP3bflrfBpD/OLoe+9kPRZeSBBhn7vbR0F JuSTaY6nyePn
3PvKcZK90smDBH9dkVUijvfAQLCYKqF/UxwCxXztCSes28Kf3YdG3EiFrZQ0 XB2BkIjakUVZ
f1uTV7565RXmbS82TMz58qJGEauqiPrHpgfNLypSfqgqOwxbW84NrzY7P9PS RjS/tateWXzb
Pcn19Y5uv5iUBqCilCTHqHDv1MayxHefEofEPy2TypgIEIAABHpPINZM6X3W 5ACB4SLwzz84
lX/1hi/lgUbPCPINxXrDioc7HwLzjH3PxJdxau89Pd56gx9v/vPr2qHfeji6 FfKsJ/yff3Tq
j1aO/EvFEStFvxeoQ7s9MC0LfrzB/rYz0H5ZkLvjypLmzTvO9N/+eei/q08Z O85tObvp/LAu
3wFYdx4Y7TgAbQvvntzDzsIjywsbY+8+3phbO1Z3O4ZRJ7tAFxPyBPa3DXz/ hlO5z1380p39
onz9t46MZMtzwGNPLLsTu+8v2j/9InUTv7AyUsqh8CCXdP8YkzMEIAABCEAA AhDoisA/LzlH
plti/Ve8xTzttTL6lTC7DoDYb7Lde9GnmNkyWi0OwFrt0O/aDkCXQsQBECEf O/VHjjj/UnbU
i8sPl3wf+u04AB3r31sj1PleWMcBqLcdAE9LN9EBkBgdT2CXmiptYJGPhCT4 AF0Bt5B45lHn
3NGW9/7Kw/JSl1Jj252ceFee93X/r5oF6d2JiNRt5uXpmadGcyg8yCXtjhOp 94kAw4f7BJ5s
IQABCEBgoAg03nJqL9blXTJiFx+RV+jstYTVKh+1LlwtEPL+ym+3WS01Gv+7 4wB0K0SmEe46
jfecxqmHnKZ80kpUuWf8765DaOuilvurTwW3PxcgbzVsjFSnv24cmm4Hagfg 1ureGYCOd7P7
OHPA7g87AP5a0kbD4FgPMhsiSz7+sdFZxPKTMff+mFe/97+5ReqWW+HcCftf cHKEAAQgAAEI
QAACRSAw84h74VHnxKsb9UazJE/QhjZXvVxfmf7qud67O9WfOMvvHbv4dWnx Gy9JV0JutIXc
dWYm3IVH66svnmj9o15Sw/R7t/Zrf5QCakJAvSqoWvtwefbL8cUbu48QqCVA EQ6AF9/31s72
qu97WWgfYHCs/CI0IHSEQJEIcHUXqbbQFQIQgAAEekhAzPePns/2vJ+8RX/u mqusf7XlF7K2
+/ivCJlwPzqbXZM/yXr4thL+ZwD2OADqRUD6raDq1SXymTCd154ZgCgNBnAS oIdNAtEQgAAE
IAABCEAAAhCwR0Bsac/8VsvsO2P5HeO8M8C/G0HO+y1ztexHPR/cSb5r9Pu1 C84AyDl5K+jt
hvdGUv1ik3sHu0ll/ZPSLG5j7NBeG0ASBCAAAQhAIDMBtSSZDQIQKCIBZWNH mtPyAlC1qbVG
ahO7XX7q7wmo48B3i7VTIWa894kw/xIgESEOgNvoiDN/uWHn+wKyPqnd5Zgn LGKtoDMEDgIB
dS2zQQACEIAABCAwTAR2Rp07O87hrd3XgN5fLj9ScbebjUvDVErKAgEIQAAC EIAABCAAAQh4
BCpnRr33CG1tOK367peAIQMBCEAAAhCAAAQgAAEIHAACOAAHoJIpIgQgAAEI QAACEIAABHYJ
4ADQFiAAAQhAAAIQgAAEIHCACOR0ACo/+VmPIPVOco8U3nexEOtpFewj3n3M uqdIEQ4BCEAA
AhCAwP4SSHEAxATx76Jr90ZJWGYYgcola15KspZmnrwXMRPqNYB0X1pADh0M KRlG81eTVsY6
irj2kK+B2VIvgCgrMVtqIAcCEIAABCAAgYNJIH0GoPnj93oXRnLcPamAzLBA K7mY69nP7MTa
Sy2+uebdxNRqGBqgvaOUVZNuSu1P27sS2dIQORCAAAQgAAEIQMA6gXQHIJBl ePAyMO6eT8XA
GLDOJatwMenC5myccFE1MBIcHhcPD077VbI1dB2Xi5+D1lYdWFcjDoWq0OTs IvXJ1xJ0djq5
VswWbRPJhjUSqJRuihyuVj/5rBdCl5qQHAIQgAAEIACBISaQ7gCEbWK//ZRv 7DZsL/onGfy4
VXiXFWCopH9sXucYTqtV8sc3HEQXscpFCdjTcbn4/RmVnTITA7gMC5iKMTIL VTRdC+FSx+mT
ml3WCDmKqQEqJbUvEWhUAcnhEuWr64QCRrqacQXMUfCsbIkPAQhAAAIQgMDB IZDuACSvV8k3
KBtn7lvhHp4ECCiZYAiGFUguYJfF9w/wB4Z4w5K7d4QCpdNZaMmGWeQrtYk1 bKiAlXZiRYjf
r8gkMPKysg42k0pEhgAEIAABCEDggBBIdwCSQSS7B4MAMXJc31Cx1LS2ih+Q k5qvof6GdZdV
mq1S63ytzPNkLcUAxrcOdgDLiEoQgAAEIAABCOw7gW4dAF0A8zUwfShzeBIg kKmKYHG82Vbx
bcnpA2TJwq62qbWWr1D+urZY7z0Sq8poF2w+bqSCAAQgAAEIQGBYCXTlACgb SO2ZjOnAAmi/
HD9oHd4N/TjhYZnhmAkhkjxf8f1lV9DCcpJ1Ni9Rbm4JRUvVtpta0z5AH8qY ACe5JWRq6uZV
kMA831VmnjUxIQABCEAAAhA4UAQOOdV15/5y+ZGKu91sXDpQZU8qbFaX5iCA g8m+1DLY9wU7
mUIAAhCAAASGjEDlzKjTbDhbG06rnuIAhJcidD/82QuZqoYiF05kUlhLyJTK evvoHSKtatYs
emeGdl9rCfyT19LsVy1nKnLvyFtvtwiEAAQgAAEIQGBgCWRwAAa2DCgGAQhA AAIQgAAEIAAB
CBgS8DsAXT0DYJgf0SAAAQhAAAIQgAAEIACBASGAAzAgFYEaEIAABCAAAQhA AAIQ6AcBHIB+
UCYPCEAAAhCAAAQgAAEIDAiBPQ8B7/zb2ICohRoQgAAEIAABCEAAAhCAgC0C h6Zc07cA2coS
ORCAAAQgAAEIQAACA0WgdPhIqVwdKJVQpncEcAB6xxbJEIAABCAAAQhAYKAJ +O1+t7Xl3t0Z
aHVRzhIB3gJkCSRiIAABCEAAAhCAQKEIKOtf7P7Wdl12rP9C1Z41Zb2HgEvW pCEIAhCAAAQg
AAEIQGAQCYjpXx4ZU9Y/dv8g1lAfdDrsOHddycd7CLh0f7n0SMXdbjYu9SFn soAABCAAAQhA
AAIQ6B8Bveanz6Z/fdtd32zUt1v9K+oQ5VS5rzw5Pjp+v7WBem8J0O2Gc2vN udPAARiilkJR
IAABCEAAAhCAwF4Ces1Pn0f9N39w6z+6E78cG6uWqZMcBFotd/mbzbGflGz5 AH4HgO8A5KgR
kkAAAhCAAAQgAIECENgv61/QrG42ph4Zx/rP3UrK5ZIAFIy5JSQkZAagF1QP kMzV7fpKfWnj
1mbJ8d4jNvngsYmxyWP38U6xIrWB1WunE9SdPHmlSIWxoevm37eUmPGf97Al 61ySVe6pDjZo
IQMCEBhcAvto/QuUhc825p+fHlw6BdFs7sOl2aePWlHWaAlQ44et+j8akxOT jtPVy6HWrz12
7ORX3etteLM0vG2HpeW7y+agNPXbF5b/8EH3QFIlNO66764t3ry1ueV6T3tU S6WHHhi/MDEz
etjaYrKLf11e/W5lcmJzvDzVrEs2o/Wtet3dOXH09NT946kaZo3gORubSxtb 9ZJbdsrOZPlY
bXxyfKSHJlrW+l3/pr7xbav5D7fy09LRh8vHHrHzZb3Sl6cXv66M/XK0VHLG HqhWfjmTis5c
8+uvT85c2ogTuHx52twBMM+08c2iznH0kfTipJY3NYK5btI5TPyq09Wu/WUj X8+Qqo9EaGc0
sXJjTUWuHZ8Ip1r7y1rvFDBRkjgQgEBxCfTN+o+z9JIdgMnzi5u3tsYfqKq/ q+/1415QxNo0
dAAqP/mZlK754/fy13/sL7LREqD6P+qb362Xu7OupE3Uzq7LXyvE5WYpe7la VQeBXYcb5uVP
Lk6O3Iwz+RgqlxyU2tZ4Z5v67ayhtlmjzX598fSns2NjS08e33zt+NT88akT D046bmvm01k5
lVVaZPzNOy3P+n9gdKI8N/3AvDPabLk3x6rVY9XKlY0rjbtWMrkn5OLXSxfX FitjK+eeGJ9+
uDL1wENNd3Nh7YOVH2KN1+41yFS/Yv2v/HlrtDr20CPj8leOJaR7HcT6d0uj 5947N/XM9JHx
mfqtzuB0smRDzZffE+u/sfis8vMj9wwlMMx0/U+z40/M611+Zsgjb1RD3fKK z5+ufquudq8/
2dry7/mF9iVlvj6zG9X6n2M32pIWAvtLoJ/Wfz5LTyz+66+fEutf/mL9d99a wqa/cgPittgl
QO7dI9Vq1bnrtFpJRsyJtzzzSwYmxa4t/6Q0Wq6MVksT497Ap3vjmPydOru+ fNk7mOxuHkC6
/qMPT8grS1f/slb7VcRQ2cpf1ibbETYMxszU2JuGUr+16bbkWQsxgI5kGm8z pKQzWv16c/bD
+YXn5yYf9QbIa2eeW/njR93XekCCmPiNrXrtgTF3dOm1h79/89uflRtT7Tje 2P/yrbqYpwuP
nusy39kvL+64jdGSc+LoCxMPCkx38bsX1jYaJWdUTMlSeWzO3shu/c7W3BcL nrMxPll7YFoy
2qrvlEtjLbe1vtWcO/7CWG8WHWWq38UPN5o/3ptdqZRK44+OXtyaF5NO/KKZ idO1kcyzIsr6
Lz8x8+T51udvldxWc+WLtcmTr6XWnbnm7RmAFRH45ietHXfHuxB+bDa9y6H5 1dXTy5dnzGcA
TDJtfnN1TA11u67bkn9N+ec0W03v6ru3WZ8WMNFNZd/uajozAMufXRkdeyhM O1MvEVdZgV4o
MpqtGYDai1dX3j+ls1j/0OuTjz2/ntqQkpW3pZ6hGopYnzM11I1oEBg0AnYd gMnfLnmmXseQ
ODJaakw8Ojk5Me4kWnoJMwAr39aXNzZX/9pZ3T75y9Gpo+O1h+1Mmw9aXXSp j+EMgMoleR7A
aAagdHjH+0JEovUvOY0/Pqn2o49PTh4/Nnl8fOLo+EMPlFtfjE8987nsjtto H1xf+ZOMMna5
uZ6fIZaDf5ew9s/21omQNZuxB8bHH5YphVrWhIaUar99oXbmhckzz4n17zxY m/16VTyByX89
Pf/8haw5psaXlT/rtzYnq2KFuxMlz7sQH6A1utymJPjc2gOjEkGipYpKjlDf 2hR59a1W02mq
TmHmwY+mpDvwBpIrm+0RTVvbxbXr5VJJrMQjrvQOktEH1bEjG1sbjZYrHsiV zc9tZRSQY1i/
mx8+Wf/zaVn5s/mdzJt5uxi1Y49UZr99YebosfknpuTv3GfvrmxvZtIzbP17 wHe7y2RRhprv
zgA8Ka3jtWdK82crC6+MffTesesf1766euLehWWmt1mmXvPw9tJoqTpWfuBY 9cHJ6sTU+PET
/n392rtmeZrGMtNNS9N9jBOebDTN0jje0medBVFq+F/S6QNjGbERxfR37rQb 3p1N79hxxPqv
vdLV5WniunSveZwEqZEcs7W90wfJEBg0Aj152X918vTzp0+/eHrmxdMXXp4+ 9/K5E09PuJ6l
d112x62rA0NL793P1pY36rWJ8aXXT6tdjiVEwm3BPNTetDT/sa0sIuX0LaPI 3E1WAemEsW8B
kiWzq2syun8kmdTml6tq3/hydfXG+uqNzbWNzfqt1ujTm1d/X5PdcTfaB1O1 36xag+7Zsbt7
x6zNbM6KgI1vN2WNr0wdLN9YWfpi2b84x1BVQ0orf/hg5Y8fLIi5/2Bt5a2Z xRePiQ/gPOx5
ApLRsadOiDNgmGNqNFn3P1ouNdxmXSzz3U18AHd0WULUPlktS7RUUckRmq5T /1uj/o/2CO7u
NuackMcAxC7PXB+JmSU7G5Jjl2WJS25SvysvT068cvPoM6tS5kq5pPbxX3pj /9MPHl2vN9Qu
xxdvZGCurX/RTY39e0Pm9dWZR+9Va0KpTTSX5FPnVxd/NzrzsTiKzTc/cecu N2ffrj93fv3E
syuPnbougZnAmmTabhh7XPiYn5lyTo9sopuWIqTV5pdr0ShXYmUaQQazxfqf fnpG+QAyUyS7
/yC9YGkxVt46Wnt1Y/KRCfkrx5asf5kh8Sqx2airZTn+PU0j0/NhyZKdSowP YAqReAeYgOX3
/W+tXvnwypX3ryy+f+Xdd5YuvnPx+mdrpSfE0puS3Wl1DkwsPWXln3t6svbg mLzlRu1yLCES
HukDKGs+YNMn1K3E/Gd7kzj74gZo3frpD2Sy/kXDWAfAcMnsa79c/OCt6YXX p+Xv/EtT556Z
mH7iaPWB8vgD5elXGju3XadVl7+1X0UbuKKufze8VCPNB5O0+o4izU3uXuMP jh19eHzy4aO1
icmp4zL870q4jmMi0JCSEuUt+xGjeWtj5p3Zz18/cf3lJ8UTmHx98YOX5xf+ x9zkmdMyURCZ
aSZKMrovZROrXHa/NPEBRsfXVHip5E0CdJmXeGCtksi6l8vKdyszn16o/yhj 9EYPjpuXq/lj
krNh4m6Y5+XHklq/m+89Of3evNNadG9dnDpZlccgqtWK7DIN0mi11m5t+ncJ MWlUK3+ak315
a2zlVnu+1Vsq07H+S626+7jRO3lSNVea7M4APNeeAWjOn3UXXil99N7o9Y/H v7oqfXG2KTWj
TNt2Y3B3ZGJnd1dn47ceVaVkqK79Rt2/MMZd+vSi7HJWW+cJuskTGv7dpLqn n5C+0Z1++nRg
HkBNBdjNq15frr0iF35n0lScgcCeqrBaH6WHX2pPTMvPwB43PJ8JjppkCOxT T99bxZTsA2TK
K7XURIBAgQjYXfmjC37hkevXPz7X3mfmn1r/4NKF07+eGHugfPSltqXnepbe 1PPp47yy8qfR
2pk+flRGKpWtPzr9psrl6o0NCZezEicMXBn0smU1qZUboDb/cYHq1FBVeQZA PQYgm/84Lnms
A3DskdqF/zkvzwCYbLIMw79XSu3F5o4z81ZdjmbeWo+bSNC6KnWT81J3HS/m Vj28S7iOkCBH
3VGUIFmqIZMAq99urKytyiSAl8p1OxFMii2D92aU5GFf9bzvwuOTM++sf/7W 9SMlWdIi6+lK
H7w4Nvuld82s/vGKTBREZpuJkkiQL3x3drflFyg+wAtPj8spL07MGL15XlMP T5R/Mjr6U6n5
9qMF3628+cW7pdKRsV+MivDag94i4+TNPK/unQ3zvPw6p9av5+iUjsleqk7W jlfO/Q8P75a8
d0mWtXuOkLBR9extXkjaJqb/2PHZsYnZ0YkXyg/PLL6xmMP6l0xSNVeK7M4A zEuLePOTytzl
0uzb7nPnGyee3XzslDTLPe0nTXejTL0le9Is/XtpfOvW6son87LLgVMSPzkp 3x5VpSqd3M8m
j9fabrK3y7Hs6pTJDIC8o0lT8h9Homsb0+Ner9bepp44sfTpolyco9Wq2pOn 0QzzUgP/q9+s
LT7fmPnQez5H7bVX1sO7ejYgblMKG0zgRAswVFgn1vMwcQfieMQ5G1nzSm3b RIAABISAsvT0
gfp54q3m4vsLxx4xWsgg6/5rE2MyTy792zlZRNTGeuXGpvop4XJW4qTSVm6A dgbC8wN6uiA8
AxA5n5AwyRAQnpw8VfPBiRDrABgumU1c6nHv/tVoxH7FQN3OU63/NjJv4ErG 4WTdeXhvT513
RrYS+Ppn9kMzAO08QlP/CdIMKS3/YUF2eeR39v+d91R0vWctl7+7rjyaud8e eaHtAyRs5pTE
+G782FR7QKCM0J97Y8U71UoyLQzzOnd0Riz/tnHriOT5L+bkYYBRb2rFM3cv HD+3+Oeti3+u
L/xpc/5Pm3MfRr+rxzCvqUcTnY2q0eMlhnn5oRnVr9uQB13ae7M2ceSDS+Mf XRo/d3Z07l9P
yZC/99BUG5E8TyMhybWsrP92Q3ednR35I8/CLr6/LCt/zMf+VRZGmt+bAZgT i/C1Z27On60v
vNL86D3n+sflr67KkLzRTI4ulFGm4RkAx1397Hrt7Aeyy4FX+vLRyV+LSrFb j6pS1uTI8sXA
AqXVGyvTv/aemDeZAfCitX0AI+v/QW9K8N4aRtcRH2D500XpFRpbW7J3Bjzi OZjk5T37e5/3
9PnRien1j2Xso5603065N6Ua5YF1UwFxJgrrJO2HxFP2BHUz5ZVSbE5DoCAE ejT875Xe1znI
1H+Ax4n3muvfGL1UQJ76PVYd9a/jUKJ0iJzVTwYnU1frfCSOXvDjnx/QS4Ai hQTmE/wSwvHD
kw+Zkg9s2+n2GQC3M9YfUUBfAznSbCURMLP+OxIq5cqxB8fDu4RnoVza/G5T P7LZPvb2LBK8
uJkWFssLf8Twl1QtVyxDuQaOXV+73nYGPFHekwBnkhxoc0ruT1y1+4uz9O3S C5/NSmDlpxW3
lLK22ySvymHnhYkZ6QgWN5YXN67Km4XGqmPtei7NH7/objdmnqqee2ps9jfj c78Zn38+9hsW
JnmdHn/ySGckPehsfN46durLzebrb8pe+tB7xjFhM8nLnzy1fj3E9wazt5Ze Pb306glvP//k
6B/fnP9HfeabDbXL8emfJz1lLta/CKvfWPBMqB1HWkXHFxXExit/tPKpmquY uzMAYuDKDMBD
c5fHZt+uPHfea6S7e4ZrwiTTtoHo26u1tU8vTj8z6WxdrN+YK5ePLH9yUfaV T2VSoq9VqTLz
fICtditubys3VqZ+fU7U1W/nTB6VV6lSrX8VbeO7zeUvrsvbltRsw/IXV+Sn OiWOtPKlUzfD
vOarC7JIN3VPfnZH4Eif6cj7mpL3RKUNFRYZXteYuIsyya9jMs8rlTMRIDD4 BHpo/e99I0Rd
3ivyyVxgN+kbNcPFz9ZkxazaVaA6lvA4znrcXS/j6dt6nkyPHwx+O9EadvsM gLphtEc59+y7
Gchp74zJKu1Uau2x87bt4Dqra+v+/d6pNCnKqBp7YHTsgbH2X7XLcWfPNANg tOjZp1LpSOmD
xydPv7HedBtNWWAwPnnlxhXP3HMdeRJAVgHJy4LSSpByvvagLK0bHWvvOqpY /4tri15gdVQW
H8krHiValxlJ8qn7j84/MSfZyYPFjS1xbJzp8anrzyzOvO+tp7ry5ZY3CXCt njADYKiDvOXz
3MTpsLMxf3z24vsfjL21oHY5NhRoGC21fmWAUi9nX3pjbvr11yL32ovpL12d rNanzx6bfmm2
vvaB9zrO3XXWXts2W/fvL1Sq5iry7jMAssZdngFYmT+7tvDK5kdvyfudGk5r VYxyQ1AqmmGm
ex8AaDvA5THZxyYma89MTz0zpfbVP3UWhmbSIS6yqW7t9GL3q7/Tv55RKwuV Re4Z5ZaebxfL
VXbvHaP33mfgTD19WnbJ2hshMHtixBDO5KvrS++Ih7nX+wr9TL2Fez7ALW8R odoFkfwM7Fbe
kdqejdnzQIX8lNkYjUt+WsnIECDRIDDgBJT13zslW+6R1U/evH7Z2yWX6Wfm A7tEMMy9ISse
J8b1dKJK1VkJOTEuZyPl6EF3w1xsRUueHLCVy77I6fYZgLglAvJhAO8GsXXd qZ6WGX15Y4yF
rT3cKv+tb6xPPVHT+/j46Ppae+5J3ZQSN323TT4w1NZwpfU9aSXvChFoz71T b7lbTbdVm6hd
+d9LEqK+DCAvCzLMOi6afOvXu35KssCuw0Ks/4UbF9sv6/FCZCS94bYkWpcZ qeQrG87cE6+t
nL2+9vXk589cmfnVjCx42bjlrfg6/XjVmwQ4OZY8A2CoRu3+owtPzIoFJu8d lZLIm38+3zpW
fkfeoPJk/dVZtcuxyTyAYY4SLbV+ZYRSNbuld96dfvlccHV7e3JAtpX3L9be SPoetvvl6erT
J5ySTBEcPfXSlbp8rK39Epq05hxblFTNVcrdGQD5VLu8Bag2d3li9m1ph62t b5c3vqgvfVpt
uRkm1kwybc93+c3Qth6RV6N5PRnENNFNixG7v2P9+2xx60Z5gtbmMwAGRe9E qb26fvWN3XkV
15Hj8C5xUgUq07zjF409pDwZ/54qwTBCWLL+JoPM0mD9G2Ik2kEgoMf+5e3t 7t1sSzcN+UjX
PfnMa6fPent7AX9wU2sZUjd533+j1SyVystrm/JX9oX/MT37/y6pY9nlrMRJ lVPcCHFvJcr6
cHP3BLp9BkBenONXQs8D7Fr/8irxqhcjtGIsl+qqfXl/9eoduU/X6+oBA21V JMlOm73uzG0b
qme06HlXlrzkZ/WPH4mhv/nOjLO5fOH9nbk/7Mz/QWzZaS/E0jZ6uDT5wFGx kcvtwQCx/udv
LIjTccR705a6uloSQaJZyXDuT6vKuztadY9MewPGuhOwOAOgVJV5APm42PWT C1eeml/5zZWN
rz8f/eX40mfeX7WrYwm3UjQRklq/MlAv49lL71ycfrEzVBywZWWGIJP1rzSf eWuu/o1MDbmN
b67MvJHHJ0zVXGW0OwOw1J4BuDJ/dmnhFRlkvdlslprygif3yNTzGT5UZ5Lp sZMXVm64epfH
HNrXrn6Owndgqxbbckx0k2j6K2De2H9707Z4L4zyQBE3vt0I7FYZOFNvtH2A zios72dgN8wu
sFDKMJWtaFj/tkgiBwLmBNR6b2Xjea8SDK37SFgQ7s9Fvva1slaXMeJTT0yo ZwjlCwDiA0w+
+6b303HlrMQxV0xiqqX/asu3LsgvIZB1wikdMznOwK4g6v4ZgPbNdXdv42g5 ratOS8b+Petf
ATLzDDPUuKz47+wVbzNPublx02Q3FGiy6FmL2vOSnyPO4lOTsovpb9H6V3nJ V34fqo5vbm0t
bly5snn92APHHnrgmNj/ct+XQDnV/WeAdaGOPuAZcFK/K5cuNJfOTf7O+36T CrQ7AxBZIxff
WJg8OiZ/1a6ODevOJFpq/coyjaX3r06/KE/3dl6u4j9oOaVU69+7fI5OqrH/ XZU2pA/0ngTN
a/2LnFTNVV67MwDeO3Dv7a58yEzWiTmZrH/zTMUH0HtnsKolK46Cu91OwxCI wnLl0yW1e4Vq
r8bRu0mzyRdndOxYeMzb+ji35wO8Y+Ea2S8fAOs/X+si1RAT6OnSf83NvzAn snM2XB0p3/od
LR9ZuiG3OW/NkOxXv1h7su0DSIiEy9nw94DDZn0gJLBAKPzqTxXi/6uK5n+i IO65YS3cJHmc
YpGPLuzvK0oPOdX10v3l0iMVd7vZuHTvGlldW9v87qa8CVRmlBKunCvtdbqy quSho7WjDzS8
Nx46lZY7trl2Zf1Wq+V77+G58691cwXKyFz1gc43osWCl2U/StrGxubRo+Ob m43xow+pkK1b
sU+GiZBmc8dzGNTwt7Riz5ltH/sOmo1mpXLE5NZrSClccHneV1b8dwMkNa18 61e+9rVySy6z
TgFrDxyVlT+2xv6VAvU7lWPnr+ws3VvjLvMA6++dHruvKTMA7ZUdO97qI9dN eA44tSyRETbP
nC6VK/KWTPmrIqhj+Ttuia1J/V5/OekdRCfeSX8vsnN3rVzVLwhqW/9bzXff 2cg39q9QmGiu
qa5+KF8C3ruVxyZPZp55yJSpP7/VqO/+Tp60+Z1sQ93UDED7G4jeNjkR8aiM DNKbdA4mrVqy
G6uWO5dSH5e1LL/uve5TnAETJYkDAQgMLIH+WP9S/NmX0x9QXHgneNdY+Gxj /nlZYhrc5AsA
8r5/eeOnvPNHnVvfasjYv1j/F56e2BfaegVOvjmEnuo89+HS7NMWntsUJStn Rp3bDefWmnOn
EesAuHePVOXFmnedVqtXn1nNxCvTt98Tbs+Gcgxv8PkoyVqguFf+Z2IyIJHF B5CnftW6fxn7
X3yxJtZ/H3STd/5ErvY5+uiT7vMpL9w0VC9f/RoK72m0fdF8XzI1xGiom93+ wUQ3naNhn2Mi
kzgQgMBBINA36z83zDgHQATK177kff/6jZ+y7l9W/oTH/nNnPUwJ++0ADBM7 ygIBCEAAAhCA
AASGhsDgW/+CevGLzXMna+21IWw5CcgCiovXVmaeyPZcRFxm/hmA2GcAcmpK MghAAAIQgAAE
IACB3hAQ0788MiYv/XTly/O9eeePLcWPjo8ufb3p/7iKLckHRI68tF0ACsZe lLe9BKhaLk0E
nwHoRWbIhAAEIAABCEAAAhDIQUC/7H/wTX9duvq2u77ZqG+3cpSXJJX7ypPj o+P3W5tCCT0D
gANAK4MABCAAAQhAAAKDSqAQa34GFR56dQiwBIimAAEIQAACEIAABAaagFrt o/ZCrPkZaJoo
t5cAS4BoERCAAAQgAAFzAnHfqLAxTX/YXI2EmN4n5022kp3s/FklQrCfXaCU vtwN8rJRYbsK
WPq2ZrjWCrTax6TJEWd/CbAEaH/5kzsEIAABCEAAAhCAAAT6SoAlQH3FTWYQ gAAEIAABCEAA
AhAYHAIZlgA1trY2N28OjupocpAJjI8/NCofqjPYaLcGkIgCAQhAAAIQgECx CaSaRpmXAGkT
qna81k82KzdW+pxjauk0iumTM6mRCxFh6dqi0jO13QxUcaRtpOqsK+vEtScH Snm7ylw/+XkR
a9AuhEGWNoD92CDjQjcIQAACEMhHINU0yuYAKCtqXwzxQbtxKhRDY/oHmlcR PQFpIXF+i6qs
E58Ns+kfqMHrT+MJ5Osze5tq0Pqx3pYW6RCAAAQgsK8EEkyjDM8A7KP1v6/0 IjIfbutfCiyO
jdrFbpbWI+UdtCoI6yN+qWgbVlVV1unPnpSXPBycXcqr9gLV4OC3MTSEAAS6 J1D/+0b3QrqU
0FMdeiq8y4JbTE4xLcLsnag40yiQY9IzAPtu/Q/OyFnH+n/6tMa3/GFwNdTU 896ilKHZlj67
UpRFQQFnt2P9/zk49n99Yjqhdk6sLQ1N3amCXHnq86LU4JCRDxRncPqx4eZM 6fpDYPVa+z4o
r0KVwRX1QtT2weRvriQoIIbj2M+P9kfDuFx6qkNW4fNvXZ179VRuIPNfr135 7qaQf6hUOVod
nXt0wkRUp+5CUSdPJtWdP3rWYppo1dM4m39PGcoc/3nEw4SFK2Ykw8h5ANMl QDgAmmnYAVj8
7UMzH6/e8wcuTw+ZAyBFEx9A/nZpRM6/8WbC5T33+muRZzOlinYAvtjjAHxQ OjpzKXYIavny
9Ilvhs0B8HyAJ7xFQV3WYE9754MgHAfgINTywSmjGJFTZ1eV/a+3zS9eqN9a T7AjzS2qubeu
zu9axvMfrsw9b+3JQ3MdctSmufDlb7ZWv+wMF04+Xpt6xOhtFkqlmT/VF38z 5vXqHy7OPPDQ
7OMTcvBQuXL9ZNLwli5OeSTiAxFy+1MVV/ry9MWvK+O/HC2VnLEHqpVfRjzo aF5MEaiM70gL
25Cw33zPJ6dxxx1/YDwuu7W/rO2XA5DJyNH6Z0rVlQOw7/etfVdAQY+x/r/f +PTY4q05ifDB
K5NyCQ2fA6CK3+VUgLTXhfc/irz8Zl98LsEByJTK31TkeGav9X+xevTUW43F Z3828/FXkZos
Xz59ehgdAFXYxSeYCjC83fQk2oD0Yz0pG0IPHoHVPz1Xe+krz/p3HbfUcQPq N+Zct5XgA5gb
juIA1LduXnl/XnLopwOw/Od3HdeV8ux0yuTNbhyRY9fZKbltw1mO3amT0YNW 5gUUQeIDXPnT
B6d/80Im618Szvxpc/E3e8xZcwdg+b3Jna0j4Zug3P48B+DL005prPyEN72z 9m2lubE4GVVS
82KK7T7xK29eIs7ITr102hLuzRqt/WUjhw+gHIB6e0mzVOLO7l/5OVat5nMA zr3uDRce6XjA
JfGXvO1f1P+P6P+dO5k05dV/00gBN50B2Pf71r4roHgpB2DKt/5HAq94MwBe D6W25csf1J5f
2dje7Q53p0ePjsR9MzK18fckwtz5F5Tc+fc+0BlEBvqzX+5iOVDuVp5Q/rDb EHQAvgyu/1k4
LDMA3qDLm5+0dtwdt9Vq/dhsyl+3+dXV08uXZ05vFGMGYKbk+ZyyLbr3ml9k oB/g4uP4AD25
oEyEDkg/ZqIqcSCQTuDukXK12ln7s+sDbH17cafZEB9g87vN2m8iRnySDUex a0tu68jtpvxV
CigfoL8OwJvTz4yXXGfxk/rME6PiCyzdaEwc9e4aa5uT49/IbKq7/svTJ05e iESUXMDr//qY
UxLjs70pO3H3oB3i4ZTg2jvryfyVA7Dw9draVuOm25T1PzdbzSwzAF5GchNs bjXqf6vr299k
WbL3rP8nz7c+f0vcnJ2Vz9a6cQA82/3htvnbLmw+292KAyBCGo2b009Hv7Yx nwNw5cvNY0fH
2+vf3EajVa6UxaZo/2r/UQ34VqNHDkBCC0k2jVTCPjkAlZ/8TDJr/vh9J9ef /EwfJzdxfXZA
bpwdB+Cpew8AXPmdWP+dGYAPnpkVhZc/LdfOro6euhiw95tXzxkWtj/R5l5+ QY2sy+j7/Due
DxAOidRk+c85HwnINGOls87qNgQdgBsn/KW4WB7fnQG4Hl26y+dO/3W5P1XQ ZS4zh2d1DS7e
XRBp4ZDILBaPX2ctUJfw8yUfkH4sn/KkgkCAwOb2kQvvf756ybOoJn+3+O6L tYkHxzzLp/0k
wNLlyamohwHMR479MwAzLy8uvmPtjdvJOsgMwKlfj7ql0hVxAI6PiWvjOQDj yzIJ8PlG7dhf
5d7hrv7y9OlcDsDii4/NPFL3SLbfSuENEsu/cskbLy5VvONS6eobm1NmDsCJ a0ti/W/+xiOT
fQbg3tifqtnl389NPjhePn76sfONr96quC0pemPx/dXTb3j3l8BmUo9icx99 OLjqZuPbzazj
92059wbRN77NMwOgJiKWP1ucenqmfmtL4MvA/1Z7QqDaxQzAQ78Y7dRmuzKV n+MNAKtB4FJp
a6uV6gAk9C29WByhssvjAChrXm0mdrzED5j+/hDDLjVw48ztUeTI2q/hrgOw x6a88rtjM+95
S/c2vnDrWyXXPTL9UrRx6Rd15EhlZ6dpWPxeRJt7uWM+inDxAeSvXmnTdgki LnitxvKf+2dB
dukAnPt6T2VJEebvjs9c8pY5vvnJkdAMQG358tzMZtABaLxfHn2xla8W/GnV cTfS/DqcdpJq
8IqTVIMXH81Qg4GrRv0MX4OqQwhfYrrHCHQX3VyMcTI7/Vr2IYa4yg13X/ma gUqFA9ANPdIO
FIHNbefC+2u1R6rzz3hL8+c+WVn5pv7ui09OPFhtj346S79/bOr5zDMA/jL6 nwGY+te55X+b
X//wmEQ49nzK6HgqqJRB+muyBMgz38T+FVElOZYRXWXNtYd22+fcE7/JNwMw ueeZCbH8lbrt
sX99KoMD0GpuPj8jUwGL360/VB41fgZgrX0THPPNADy0/PuFqbPt+WQpZavp ylZfLbXq7uMR
TwanOgCe1f5gx/rX46FqjczGd9l8gIAjYe5C+J8c0MP/S58thucB8s0ALP55 48IznYcuNr6r
H33QeyojsL37ydLMU/afeu/GNFIaZngNqL9IciNXu98ZSL3kJIKJw2AiJ3cc 6wp41r/MAHwh
HUXd3PrPrb/FhGLiK7tfNjH9za1/iT/11InId25aVK9Hot69T6x/eQZACu6+ 9kxz/qy78Erp
o/dGr388/tXVyfZS1p6v1MrtSwSYiIkfV4PJ1r/IEb+oPzWoDOh83UVCG1AX svXLObnV9Tm7
Hl0CiIVA9wTaY/8rYv3PPVPzholdRw5qj4zJhMDad1uemdxeY93lpp8AFjli /StptVfqyg2I
3KTD8e/5FGg5pRO/Pv1kexH8aWfyROmYzAbM/M2d+av3ZMDUHzdr1zYlJJ/w 0acemlxqqH3s
UXfm0typ9l79pXP04+bRS95e/mVsAQOZTlRHZdmPjP0r619WAZ24djVVMXkG YPFZWUFaf+2Z
lYWXVq9fanx1adPZ6qwplep0Peu/Jda/E2P9p2Yhlve4TAd5TcPb28thvF39 lFOp7+QJZnFP
RmrmnQhq3kDvU0+c9lwaeXjjidPiA0iki59cXfz06uInV7u56699W1e7FEwf +w9M1d3XeP8l
d+7KDdDOgL78tEAV4o+TOy+dMNL9CGTt90+sK6A0OX1p/erbjzVuucufVNTY /8onU4HdsLAy
J6B2HV+H+AMNpZlE8/sAKn7q2L8WWxgf4LDj+PYL7ubi70bbz2y03vykMne5 NPu2+9z5xoln
Nx87Ja9yankF3JvE+xkKlFF8tevIOsQfGEzblqMjBIT4w5XYoKiQYlcO3/MB dA1KYEQRQmnP
rXXrA+hrMGEsP5PRHNd16A4kslVH3u/9SSK7hdT+KhAhoYtLUCDrEInJZUsc COw7ATH0xdyX
sX81YKIsO/mpfABlTnVjVKkCiqEf2FV4gg/g73AydT57kLoyGu89BCzD/u0p gJ1We/xffqkD
cW46B3lqwvOMRkveHthUYDvc1HuafXRChvxlBmDz+XPq4PrJ9DeKTp1fnflY xq2bb35Sm/39
5Na3yxtf1Jc+rbbcyuIbi2L9ez5AfV3G/p2osX/DQm9+V5d95YvP5UECvctP FW4oREfTvoSa
ljHcPDcmaq8df3Lp08XxB8ZGq1XZDaWFo0mzn3h4TO3SQPSx/6D3g4q51b+X ML8DIDK0BRA5
4KfG/yzomCaiF2ONaXk6YvSf+Gam9tKqWvnT+GZr6uyS3lOTqwhqRZDalbnv DzEU0udohfAB
jhx2/Pu7JTUDIEMdO689c3P+bH3hleZH7znXPy5/dVUuYK/bDSSRn4HAxnvl n73cUrscSwR/
SCByII6WFhaiE4YPwirpkHClJ0QOnJr9plsfwLzJpS74CXcd/pDkjMIXvu5z InskvzKBtOFM
A91XQhcX8Ij61u+Z1wIxIWCFgCz1kQU/suxH1q6rTQ5md1cBdcJu5xwjVwJX 3ztWe2k5vDvu
puwSLhEiy9L99KAYmIuffP7Bp9fl4Iq7flHsYNd596fVhZ96luLVfz26+K9H s1ihe9R0ZcnP
2nONGy80bngz8CufzKldjus3OuFenLRNPyTtj7j4r8uBPVJMewZA3nUh0+BX Fs4uNJulpjg3
7pHqw6+NPjKz+P5ywsqfNL0652WVv9pHxx7aHff3bHj5qU+lipIhfLU36jc7 kd0dx91p1Nf1
qWQhu46HTGjcc0K8J5u/uC5vc6lv1Ru3trzvh2bwKQIZuit/2VT7juvoY/+B DV84FVW3ETI4
AHrES5v1/bHvA0UMTwIEhvpMRijzYLvrOHv3UnVMhXRWBH069cLbq7J3hIfi e5Fl84f7f6rj
cEiknC4C/Y8BKFVlIZAEBkqX8HPqif5ZkHlqKpRm7q6aAZAHsmUG4KG5y2Oz b1eeOy/xWru7
lXyMhHz/Tlnt/tjyU3yGQGCcuGn33mMAugYl0Cj7dqQufYDIRf/h3FOtf3OF c8QMTyz4+6vw
2RxZRBbZihyEQGAACYyP7Ph9AFkOI87AqnoG4IHqVquz7KMbzSfPry+9OhXe ndZN2SVcIsTJ
79YgcY9MPT375BOzjltpPjznPCw96pE558SbsiDIPTL3j6k3/yHrRdNt9Ej1 PFNz4qPR4x+M
HfcekKg9M692OR4/7oWPHv/IxByVFyVFyh/91ejMv03J3wT47RkAeXKjvarG lbUrpVbLEetf
rZDxhtjzrvzppsYj08pXCGSfPC5zTZ4FL3FE6cnjUyo8OTvxNORh3/Yu76Xd WvlCnu7z0MqB
PAcsB6efPnX619Oy57bRxeiv/Wpc7V5t7h77DyTO4G8ZHAA9ZjZQpTIfL+xa bf9iNHWsmqV7
+v1Vecf80V/PfvCKK7u0NHVq4255405ZL4PzJ9kN7EjwnQqHhPPNHzL36p5H SP2ryeXUXlWT
cpl64sleryYX3SJ3o3o8XHJ8+/xhNQNwsT34sTJ/dm3hlc2P3pIhpYbTWnW2 JFzW3uxJ4v0M
BPp/quNwiF9IIM7uz5+96ur9nhB/5EhldiX7rX/FRwERL87zAcKliAmZ3Tjd 0xrcX+tfgOj+
KmwW9KjT0M88sATI6CIlUgEJaB9A3f/UE8BHH6xu7Zo73Zs9tVfXA7u62S69 MSvhvWPWNjOl
V5e3de4caWfp2dre+3ncttEtq4NKud/gocxBkR7HR06ZmIyRMwBi90+dP7r8 3kbjLw3JRTyB
OErLb6929k8qja1K+cH5tuXv7d6ypy5W/lisF2XB++0lf+OSU6lvE9KzDXIw Ni5TRiWx/qd/
LW8BasgukncPcmotPsnyjQ21iwh97D9Qfksvtq5Mo70KZXAAbJUkvEZfSTa/ a0Y+CeBXL26E
svusAxBGX16tnLly5cXJ9ltBF154u+Q9UiN7e/1X7dl3a7971xY3kXPkX+75 93HHhtl56/7f
mpddW5CGCXW0nvoA8g6shD1V1dJhx7/PH663ZwA6yx/nLk/Mvi2Oe8u/CDKQ RH56/bVPjv+n
Og6H+OM/9Lr7/Vsl+asCw0nkrIT7owWShFVSctQmFbdc/kB2fw1GJokLnPtr fh8gebBt361/
fwsx71hS25VJhG6HIU3yIA4E+khg6q212utroy8uj77ojW2NlUvyDlAZPJZ9 5dKMWP9y0N52
h2q7003eAnTvLvOv3iIZuZteFev/jR5a/14uP5au/NvF63+86P5Yafz5SvPP F53bzrl/LF34
27Jzu3ShtHnOWXPzLnASQo0bs6ufza5/5n2Kx78EaPWzF9Y/8065t5PAzcsH kttkhM/ce3se
+dXWv3gRCda/pD32QHnqpZmpV65MvXJz6uzn9a8XvXX/6oX23dWa3dRtH2B3 Rskbiuw8VGxi
/Yc1Uda/13QfGJXdf5BPbfe2O3X8qNpFM33sP5A4+YQnp+rSNAoIt+MAKINb 7X2+//mz7gXu
BJmNdyZlb/7xdGcG4InSB2cXNm6U1VM1klBOyR6QIIa72iV853ZD/5TjQEiP iqPcRzH9lXzl
A+RzA3rqA3RV/P/qOL597u5Yewags/xx/uzSwisrjntTL4Kcv/u5P37n2HFu vlFSu4Q89P+4
+qccB0I8bfdm6v30B7aPw0Iio0WI0sLbpr9n/f/kAxVNDu7VYFiHxJC572J9 AP+VZXJdhx+6
jVtm4w8Pdx0JV7Qy5eMMep3Qu/QSe6RwFoEQvyjVDk26uP3qA7u6UkgMgTQC y69OyMvqx6ud
N1V88M5p+YKULMqWdI2W22jp9CU1cN79dvrFzqtpRh/wXrA49ca67N2LTZYg Y+BTjx+denzc
exfoUyXnKXmxaWnlF42VX3qPrq4619cd+RZY3u12afT4Qu3phcmnvdfw+5cA ScikF74gryFK
kD736in5OJrEkL/z5/c88qvH/k+3x/7lZ6Qc98vT1adPOCVZyNR5PeXMWy/U v7ki1rX8nXkj
+H2AvEW1k87zAWRVWfsRPTWWLj9Tx/7DeZerZT32rwb+vV2eL/CmAnJuzZZ7 +nfvqv3KH1f0
sf9A4uSU3sdkh5zqulMtlycq7nazcWlPzvv++up9V0DhUN8BqD0e/LishnX9 vJoBOHb0eGPp
U/kkypGpsxEv0M1arZXKaLOZv41mzS53/JUv9/8rs4EPgYldGyjOhYb4AHtr cOvzjbWx+i1n
7o5astXVdvN/lTyvoJjb/IM5v/LW6+KaOB691qF7+QPSj3VfECQcZAJTb23I YOfKqxMLb6nH
jcLdnbJf3dlXI0zJwf8S8Nx7S+IAyEqYq19vVB8vS0laX7qrP90Us/zY30bF +pdTDzknFl7t
vAA+0BiSC3jxrRem3/p8vE1o5e2KWv3vHX8yV3uls7Bo7vyTkej8GYlrJB9I DmQtTwBLiBr7
X3lvo/6XRvQ8wPbF8oPyhZyJ3eQbUp/vvroiXzyI/OZXZGtP/Q6ASiVP645V PYZqy2e7++Xk
ltC4447J45oxW9zHxQyLGSd2cMLDd5/gh8BwAJJra9cB8L57ErctX36u7HjG essZnTob8RkU
8wZRqXS+udZs9uMdSuaKJcRc+dKzoffxQ7MBB2D+70EHQNSbd0KvjyiPzbXS P9+WUPD1Vzpj
NsfeLqr1r0o393PPZd3HGvRD1mP8fZ5OtHIthIXgAPQILGL7TODEWxvXX835 bSNzi8r/JeD5
D1fmnk+682YikKzD7OtLux91lWUx6oOuMiug/5NnAbyXhM7ncgAW3urMach9 Qn1WrP14gedF
ddwmL8SdezXpS45xhVUOgH+LdgDurpWreupArH95/q3x7jsbmcb+zevR/8r/ HCP3ujhKTm4J
qV8eiJRsXsxMLbD/kXEAumVu4gB0m8dQpBc3YL8sSBMHYCgY97YQ4gbsVw32 tmD7Kh0HYF/x
k/lAEDC3qPxfAu6nA9AlJvMCdpnR/ianmPvLP2vuyQ6AnWcAsupE/KEkUHu8 JmulpMF5b9jd
3y38VS9CDAjM3/IeCRiIGtzf9kPuEIDAPhHwfwnY4vD/PpWGbCEwuARwAIzr potX75u/Yr/o
MWvHa7IrI3If7cjSYXnBDnseAgs/zMi+7zVofFkSEQIQgAAEIACBzARwADIj I0EqAeUGDIIn
kKoqESIJKDcAT4DmAQEIWCEw9vOcDw9YyV0J6akOPRVuEUKXoihmlwAHKnnK W4AGStf9VUbM
2f1VoNC5y2xAr/XXFSR5LWx5L/1ls0hgtrpoURqiIAABCEAAAhDoNYGA7VqY twD1mgvyh4ZA
4CHghW0cgKGpWwoCAQhAAAIQgEBmArMjiwkOAEuAMgMlAQQgAAEIQAACEIAA BIpLYKA/BFZc
rGjeZwKRMwDLJ70vOLJBAAIQgAAEIACBg0Ng6pr3+TNmAA5OjVNSCEAAAhCA AAQgAAEIpBBg
CdDANRH50EbvdOqp8N6pbVey/tBspNjks3Y1ySRNFPPrllvP3AkzaUtkCEAA AhCAAAQGlgAO
wMBWTQbFTry1Jh9pP/3exsx7G+c+3Jz90+bctX3+FNf6h8dkz1CGfkUV87f5 4/eSm7Kn9a5C
tBZdWsm2jHW/PqK21rwbPUVIl6XrV12RDwQgAAEIQAACPSGAA5AB6/q1yQyx 21FXr52W3b2z
NfXlmPxVP/WeVZqOHzCvxx+vHX1qcvK/16b+tXb66cmZpydLzk5u4d0nFPVq r3S1/n7+9TcT
9u41VBKUSa0Na2VeD/5WFD0HnyQaQgACEIAABA4mARwA03pfvTZZO9uQv6YJ HOf665NTZ5em
zq5Mr02sXbtYfeBo+2dnN5cTGVMsbD3Evvnl6safV1f/98ryv61e+Wx18bN1 xzmSQ/7yN1vJ
u4nM7q1/yWXujdfk78KljwK7PmWiSTiOHv6PTB4YF/eP4vsnCiStiqnjRw6o Rw60R8pJFaW0
1frk1lOXmkmAfO2HVBCAAAQgAIHhIIADYFSPq3865rZaElX+yrFJmuX3Jmcu Nerf3pz8tCTW
/8TJc+1UMjCvdxMxwTi+sf+S9gEu/HT+g7emF16fnn99au6lqQtnazVHZZd5 O3p8Im43kdW2
/sX9aLZ3R2nr302EqDjiA8z+7jl/fPmpHANbW2AJUECsf8mNnijwG/1ZR+KV +6H2HItwtD69
1tMWXuRAAAIQgAAEIDCYBHgN6J56kcU5gXqaenpr6f369FueOSv2v+OUZF96 e6z2/Gpcjcpq
n+XHvQUwze3N0xtTyvpfnGgtfrrS+rHZbLVabvOrq6eXL89MnrwSFiLP6cZ9 bXv1vWO1386W
qr5vqrv15Xfmar89V6/Oj4pqSkXXWf79sannr2cSLpFl+F+s/+VPlpIb68zJ 6I+6e9b/S8vJ
aZfOT9XeEA/BdJOFQDIJILGTrX/D14D6ZwDCswEqxP9XaRkw1nWchDL4nzTw y/QnCeQVztcf
Oax5l3omT4aYVg/xIAABCEAAAhAYMAK8BjRzhfiX6Khjp7o6/eLY4vmK7I67 7h28Wpl+JnaB
jVj/YvF7K/591v/qr1vjD9QXXhn76L1j1z+ufXX1RNtQz7Zt/vmx2pmZUrnq uA1vb3l/Xe/v
PTniApTFASg5jduVbNL3xp56ZjpuTxB77Pl1se876rkNOQ7vmax/yUvNA1gf +88KJ/C0QNbk
Or4tOXEK9Fp+7oKTEAIQgAAEIACBwSHAEqB7dSGLdhaflSX+/lU66tiZee97 17Oz665Tmnnr
ZkL9ydi/jPevfTg3+sWU/JVjsf7f/GRz7nJz9u36c+fXTzy78tgpGZtXUwoZ tsZfm6VSxbm1
tvTGC7I77pZza2X5/YuTr3oD6kuvPrZw/rH59v7u+cfa2na1yXxC5J4sVOz7 pVdnOj6A48jP
wJ5DJ/EB7K78yaGDThK5dCdhPU/cah+VxD+ZYDKxYK55jiVG5sKJCQEIQAAC EIBAoQngANyr
vqnzqzMffy5j829+sjX79sbSDVd2+bn8WVUORk/evHh+dvQpsba9kGQfwHlq 3vnznPy9Mr4i
rwJ67Znm/Fl34ZXSR++NXv94/Kur4ma4TlYjXXRp3bz6h+u1V286bql9vFx7 db321trsF8fO
vfrR7KsfLTsz8leOZd+vdun5AG/MhXP3ngS49th+aaXyNV98r2L6zXT1M+u6 f395tcwu5UTK
1KUz0dOiAvtboeQOAQhAAAIQgEAOAjgA96C1ZwCelGF+sdfFWJ8+Xl/589IL 55eW//akHMjP
c5euy1+JkGq7N39TF+v/+yeWxx6W9/HLDEBl7nJp9m33ufONE89uPnZKnh9o Za0tMayv/mFp
qr2AXrwHdSzW/8XXx1f/5g34q2P5m1VyZHzvWYeo3UR4nA/gtJr77gNo/cOm vArR4f6Hbv1v
C/XH0X5FAItfeIKcgKgE7yIgMJ+eJnVHHAhAAAIQgAAEhp4ADsC9Km7PAMwr e12M9aUbY+vf
3tS7/MxkuzfE+n9wavFZGQvfee2Zm/Nn5RmA5kfvOdc/Ln91dUytLMq6Tb3R WX0kB7KLrb/w
8viO64z/tHTuTxv6OKvYyPhHanPh3VyyWvkTiO99HEB8gH39QJj5JIB5Ya3H 9L+eSE9E2MqF
4X9bJJEDAQhAAAIQKCgB3gJ0r+JkBmBn68jMxzNekNteo+/KYP/G8qflqZdO BEImfxPxjp1A
I5DvAMxcmpXANz+Z3HF35BWi8hagj95rqWjLv78SKSThLUB++WL9n3i0PD6+ 52Hfzc3m6net
K89PxDXHZOH6LUDyBPBYyXviIbzJO4Li3gLkjxxp5dde6rw6aeX3k/LEsMVr xvAtQBZzRBQE
IAABCEAAAhAYQAImbwHCAdhTceWRi217/URzqzF7fK5RL9W3Sq57pPSrD1b/ sukPmXo+ZZG9
uBOn3mosPvuzjkeh8tnrV3TpAEw9Uh4bu+cA1OvN5W9aK6/GWv+Sv7kDMN5+ qWh4e/dyugPg
vQ/0bMQbTv3SVi6ftugDRDoAsyOLA3hZohIEIAABCEAAAhDoHYGFbW8sW6yg 2vGaP5fKmVHn
dkNeJ+PcaeAA3COzOwMw5QW11jfX3MZWaWvryKlXxgMhqda/EtqeAfA+LCAe hZoBWHhpeevb
Ve1XRMoxnAEQscdeXzn16GilXFm4dtNbsO84m2/sqelw20p1ACRJ41ZDZgC6 cQBEyPLrEZ9L
O/W6rLDytqtvzKmHGWxtzADYIokcCEAAAhCAAAQKTcBkBoBnAO5VcfsZADGg vTf/yOIf1y3J
x39PvSLr9feEGFr/6kvAi8/KR7Xc1565Mn92aeGVFce92WyWmq43q2AoJ6EJ rr9Re/fPjcZW
s+V6pn+q9Z/amqceqcqeGs0kgtj3gV2nsm79m+hDHAhAAAIQgAAEIAABRQAH YE9LWH57tbN/
UmlsVWq/uRIOMWw64k4s/m70nkeRy4tIzavxvvgA4qt0/dr/vTnJQn9Z6hO5 p6qUHAHrv0uA
JIcABCAAAQhAAAJdEmAJUJcAU5KvfijvFd27lccmT36QkMx8CVAO1XsqPFkf tSjI7sofnSNL
gHI0BpJAAAIQgAAEIDB8BFgCtP91Ovn858E90frff417poFaEdQz8QiGAAQg AAEIQAACEDAi
wBIgI0xEgkCPCKiPDSdvJnHSZFg4b+WLBPtblqy5Z40foGyFmIWayy4isuBd 0siuBSkgAAEI
QKBXBHAAekU2t9yxnx/NnTY1YU+Fp+a+XxG6MVz83+TaF/31d7t6pIkhHKVG 5LeK44zFgML+
aIaZ5gPeU+GikqFZH0dMY/GXLqCzSZx8cLpJVYiP6HVTQNJCAAIQODgEcAAO Tl1T0pwElOE7
CNaPdU26t5UTJGhtldsQ6TzkrJL9S5bgCJkopZP7m1PY+g9XdPc1ZaIecSAA AQhA4IAQMHoI
WJ6wPCA4KGbhCKiPXCQ/BKwH0XXptDmlrVK/geU3Vf1pA8dKWliCCglkodL6 h/O1MpHx1dmE
3ONShQsSLqy/lsNwdNb+AiYIiZQQyVwTCMMJ5OVnFdZHJTcnr4VH1nK+xhC+ UpILZVihJpUe
rr5wuzKHk7VZxjWYwnUdKAwBCEBgWAmYPARs5ACUR+Rd+GwQGEQCre26qJXJ AQhb1XF2dpw1
liwhMpXfZk1NrkGnOgCBmJmKFjZJE/JNMPviHAB/c/Gb/gHjPlJnv30f0NNv 7AZmFQJeVqAi
4urFbysn6KaS60JFZu1XNdUvMqnchJap89KsUttVMurU5AkNZhC7BnSCAAQg cFAJmDgALAE6
qK2DchsTEMNI7YGZARVoLCZlDYyJqLAmOiRBDZM45qUwjxlYApRJw0zrhbos YKbkXa7CUg5G
1paTzHzfm6V5kyAmBCAAAQgMCAEcgAGpCNQYXALK5gvoZ27dmhRMSUu1C3Wm /rHYSPX8mdpV
1aQ4WeN0o6FyzFIhJKjUTe5ZSyrxu9Q21RmwKN+wWeaAQBIIQAACENhfAv12 ANZ+f0zv+1ty
codAJgLKQA8nMRm5N8wo07C3oUx/NIuq5sjdJMn+atjP3BOWVJmASo1jsSy9 bpapZSECBCAA
AQhYJ5D/GYDlf99c3fSWXwe2yfGxqf97PFLRpd/9bPrSvZHUwE/rZUPgQSBg +AyARqGsGW0e
+dd/B+Kon+GVP6kSIiOE5fizC+ujz+qEkSaj384L5CsS4lT1C1fHYSMvoFKc wRqneTi+CvEX
J07DuJLq4oQPIus3XHy/5IAmfghhqtaJBdbtBGohoX0GaiquXYUbtpVm2Wu/ 5SB0WZQRAhCA
QK8JmDwDkN8BmPtwef75qXAZ4sLX3j42cfacxHdbrre1mjtNd+vbPe8Xmngl +kuxhw4d+uc/
/9lrXsgvIgETByBTuQbNxMmtT+6EmXAR+UARoFEdqOqmsBCAQEEJmDgAlpcA iWEfB2tHTpSO
yV6qTpYfqFUfPjF2/PTES4t69yKwQWCfCIhlo/ZBW/AQt/QojtPAFmSfKpZs rREYwKvDWtkQ
BAEIQOCAEejKAWiP5Pu2O63WdiMW4G0Z/G8k7PW/tszhy5yA2nQSHaIDw3HM 5RPzoBGw+Oik
dXSZfJJBLoh1MgjsJ4FM7bCfipEXBCAAAQhkJdCVAyCZHfFv/1LZ2Z0BWLq2 KGf9f72pAbel
96U3ZgN7pVpaOv+Q2pOLoVYEqU2Z+/4QlTYckhUN8SEAAQhAAAIQgAAEIDB8 BLpzAO66O7eb
zWaj+aO3N/7xvXO3swRo+uSMwPL/9VYHuU21L70zP/3yhci99lsvoZXNPz9g RSBCIAABCEAA
AhCAAAQgUHQCXTkArVazsVVv/tCQv97B9lbrTjOOSPvxAG9fev/i9Isz/tkA fdxqtVb+sDj9
3s3user5AdyA7mEiAQIQgAAEIAABCEBgaAh09Rag04+UWs2Wc1dotAf+5eBw 6fNbpci3Ay2e
Gp15fWbpD0vTvz0dia/llOKs/8BbgPw/1XE4RGfBG4SGprFGN5tt7120KzdW asdrKoIcL2x7
80izI946NDYIQAACEIAABCBwcAhoK0ibRqrslTOjzu2Gc2vNudPI7wBk/Q7A u9OjYw9Upn87
HWP9VxLG/v2j+Op9oDpEvx40ECcc4eBU/IEqqfXXgB4oehQWAhCAAAQgAIEh I2DyGlDPAShV
y6WJirvdbFzaQ0CPqpZHxqygWXw24kOqWvLMx/e+EdZNdgz5d0OvcGlxAApX ZSgMAQhAAAIQ
gEDvCJg4AF09A6BVV2/7Sd3ExE/YU5MnR9Av/eSTYV2SJDkEIAABCEAAAhCA wBATsOMAqLf9
7O+mXwy6v2qQOwQgMFAENv++aWsOs5/lKqja/UREXhCAAAQgkJuAHQcgd/Yk hAAEIAABCEAA
AhCAAAT6ScCOA2C4BChcsEwJly9PJuz9pEZeEIAABCAAAQhAAAIQKCgBOw5A 7iVA5gkXfzc6
dXYpbi8ofdQeYgKVn/xM7zmKKWl1Kv+xoagukxvmMnzRuqy1MBBVETlqMJWt UtXfSHqRS6oa
RIAABCAAgSISsOMAZBrI92MyTHj11dGZS43FZycdZydmLyJ8dB4sAn7jrxvb XRl8zR+/13uX
5RQ53UjoMnk3WRcrrd1aU2UHfrHaANpCAAIQOCAE7DgA5gP5AayGCU+91ZAZ gJmPP5cvjr35
ydbc5frs2xvPnV858ezSY6fkBUTtz5CxQaA7AmFbLZ/1puzIgC6BkeCwgxEX otwJJS0QJ3m4
Wo8Q66z9IeHBY8aPI5tPmLmOllAvutYCcfy1GTjO0XilmenK9Te51NYV15D8 RUuNk0NhkkAA
AhCAwIAQsOMAGA7kh8tsmHB3BuBJsfVfe6Y0f7ay8MrYR+8du/5x7aurJ3AA /B9BM2xYOZKk
Su6FTJVp7yQHCuW3ovJZ/wmUtGPgH2nWBqKeLgiE+G2yuDjaEPTnriKHQ3Tu fttRRT7gPoAi
oN0kZaCHmQeqODJO2AkMV0fqBZUvQlgff0igUCqLQBkD8Q055NOWVBCAAAQg sC8E7DgAhgP5
4RIaJtydAfhIblVvfuLOXW7Ovl1/7vz6iWdXHjt1XQLj2OmPA6iD/iPOl6lf 7f7rnJyjoW69
I58PqTlGZTRbt/4DMlPHaM0V7j5mWJnuZRZUQtjcD8CJHHQPA0xoP3HD9vmI KWmB7CJbl19+
wNMzaQAmcfIVgVQQgAAEINB/AnYcAMOB/HDxDBPuzgA8154BaM6fdRdeKX30 3uj1j8e/uioP
BriOG70KSH0cQPLVB/1HnDVH9SXjwfysgbluRSSva6oX1n+gGQSeEAiPuWZt Nt3EDyjTjajh
S2sCxyROP8kE9NHTO8ruD/w0bHuDVsZ+8iQvCEAAAsNHwI4DYDiQH8ZnmHB3 BmDecVpvflKZ
u1yafdt97nzjxLObj51alcBMFaMHp3WqQIj/Z2DqICGmSIscHfdLCCdXqZL1 90fQx+FS+BUI
Fy0ulwQagSTK+g+rqqPJ2eSyGHIOYwxI3q/5HMNmlmktzUCtuhkoZQxp9y2a f2lWeNBdqWEI
MHLYPndBEvxVvz7h9WD5cjQsYz7hpIIABCAAgf4QsOMAGA7kh4ukEib/lQi7 MwBz8gqg1565
OX+2vvBK86P3nOsfl7+6OtZ+L5Dp5h/D9luuasQ6EKIjq3B/2sDPVFFx8cNW tVIj2cYNaKIK
Hy5aZDQ/qRxJTEGH4iWQD3CWpHoCJNKj0NMLqb5Tbm27TOhfTR42mPxn9Yqj yKUmAQNOx0md
o9BZpBYkrExqkmGNoPFq+94ETqY4fUAX1ifQbAI//fGVeskhqW2vD2UkCwhA AAIQ6JLAIae6
XqqWSxMVd7vZuLRH2sqNldrxmgSVR8TI3ufNewvQpVlR4s1PJnfcHbfVav0o PkBLqbX8+ytT
L63Hqeg3sgMmoxrS9gcq+1uH+w8CxnpYVCAjv6hALsrGDVv/gSIENPH/VBJU fBWemrt//D53
kuR2EEbkV9Kf1pBzXF3ogitzRLdVdbywPeO1ipP1fW61ZD8ABDb/vjnxq6nW 9gA1hrgJBD+t
AVHbRNUBqGRUgAAEIACBewSmrnl2++zIojLj9VY5M+rcbji31pw7jYGYAUit tN0ZgIvtZwBW
5s+uLbyy+dFbm47bcFqrzpaEZ9gCK+xTh8kTRGddrJ81flzWer5iYIfAIzW3 VfwMlU1UCEAg
OwHzuabsskkBAQhAAAL7T8COA2C4lD9cXMOEu88ATLffAlSbuzwx+/a4LP3f +nZ544v60qfV
llvJwdKi9ZxVVNb4kdMFkSvyc3AwTBK3xD9rWSS7HEkMlSQaBAIExn8+PlDD /6KeySqa/VVb
P/JLc4IABCAAgaEkYGcJkCziNzTlAxANE8oMgOcDPPuzmY+n7klorW+uuY2t 0tbWkVOvfJVQ
PXFLdyJXpyQsTfFbroG1Q4ElQyqmP05qfK1/YD2SPzyscHipkoofV7SwNJ1d ahKVNqxe8rKf
wLojv3oJS620nuFlS1oHdUrZdpFLgJae2BjKi5ZCQQACEIAABCAAgTgC018c lVPJS4DsOAB9
qIP2MwDyITDftvX5xtpY/ZYz/ZK8CGjIt9SnBVLLn0NCjiTKOu9yaiJOQmR4 ggOw+OhaKhYi
QAACEIAABCAAgWEiMPP1RJ8cAMOB/DDcTAmX334oKKE8NnX282Gqs7iy5Laq wwP8qbhyJPHL
zK2qFmLLAbh4dCW1sESAAAQgAAEIQAACw0Tg3Ib37O+QzAAMU8VQFosEEmYA Vs/uycf/4iOO
DxoBaSfyNrPClVq9kVOvSyyc/mgOAQhAAAL9JzBxyVsjPQxvAbJoLyLqYBLQ swpqeRJ/DxoB
1ewPWqkpLwQgAAEIHEwCqcaenbcApWZjJcLy5cmE3UoWCBlWAoaPJfB6omFt AJSrGwJyXcRd
Gio89cJJjRCpnkmqhDgmybvBYittMtvcufS5+H3OLjeWAUnYT1z+vOKOFRbz mH3GmA9XvlR9
Lpr17MxL7TkAbtf553sFkGRrnlAeAp46uxS3d10CBAw5AX1JKFPG/AoJxNc/ U4WEM0oNSRae
qnmgUAnxwxmllitVeXXzCGDJF6JvRZHwdUtNrYLetWlz1L3QwV9ZvZAfkCnZ if9s6EL3QZ/9
zcK86+iDnn5lkhVLPZv1yk3trBKKn6Nb6EUHFSnTsMMPkA9fkiZlzNFCIms8 R17mzTguprmE
HMUkSRwBu9jtzADIs7z5Ksww4e6HwCYdZydmz5c/qQ4KAW2+ZDJltOmjFvAp WEpCspxwQpOQ
BMmRmvgrL2ySammRXUYgr+RCmShvK46/UMlF2K+2mxW1XT39nDHK7bI1kTaY zFWrMNE/HCff
lWvSDUbq04vsbMkMy4ksZqAHCMcx0SdfZQW6R/mZLy/z1mIes/sSIaHPBOw4 AOYD+YHiGSbc
/RCYvPDHffOTrbnL9dm3N547v3Li2aXHTonv0f0cRp+xk12/CUQawZGjKeEe NoeuXXaa4dt5
pEC//iY5mgwedGNJ5ACVNYn2xPZRTxPUWcvVTXyTQcHAGGHgpzIj1KY0ifyp wrWq4eaUekGF
JVsM8SsWKEtAZ126gMJxBCKlhRkGyuJPZVLMBHqRefkL5W+TWo5/2EIrEK7f LtuzvhL7nJ2V
jlrTSIXg73DiImfqlPy4/NedVsnfZsINVV+MYWUiQwJXa9yVHqhE/yUf12kk 9BhxuRheDoEr
KDmjhGs5skPTRfOXK/maNek3ImstsjtVCufOMXzLSO4lIm8xdhwAw4H8sAaG CXdnAOQ7AO5r
z5Tmz1YWXhn76L1j1z+ufXX1BA5AZNWGb8+R0TIF9kKmv7/rXUFS+/dkDv6e PdNllumWYFIX
tgRmKoWJYsTpDwF1h468NQYsQj1JpdpM5E99E4qLoGTqtF2W0a+J7kx01pHK qHtkapy4sscp
HBCoy+g3gFQcnXvAwvAT8+cSmSpTEQI6R0ILlNekXuLaQw5RA5idvo902dWb FK2fceIaariR
hG8NJjeLsPysl0zgCk3+aX7VRyqWrwOJvLr9cOKudPNeQvcbgc42svvS+gT6 FpPSxfXG4XxN
WqkdB8BwID+skGHC3RmAjxyn+eYn7tzl5uzb9efOr594duWxU9clMK6o+k6Z fL80IZUvTg6L
2a9z5EUeGWixgAkK+LPed7aZaiRHRUTeF3WPEB4pCetj0v9mShUQmPVWp+PH lSKfwpkqIlNk
3cb8JdU2WSZRwxTZ/J6d2jH6G3ng6s5BLHAXNJSgazkhvkmcBMPF71qYMzHU vw/RMhU/a7eg
9M937edL1aPs8iljkspWnOSmonLJd6vSJmzkbasPTTRslqQWNtloiWvzma4F P41AdiaXiUle
tuLoy9CiLZda73YcAMOB/LA2hgl3ZwCea88ANOfPuguvlD56b/T6x+NfXZUH A1zHjV4FpMc8
9EEqkUGIYH6D97t9Jg06tXTmAovFNjcck64/kmruhAkGSu5SpNb7YEaIG2Qd TG0LpJXfAxS1
tfWgjI/Az56Wy9/hJGQUUNi6SoZqWM/XUGBC8XObjP6srXdWqcaf9a6sz0Uw rLj9ira/NFI7
kNTLLSFCjq4gNbuEO3iy6Wgo2Vxn85hWmpYdB8BwID+ssWHC3RmAecdpvflJ Ze5yafZt97nz
jRPPbj52alUCM7EIe2yBEP/PgDeWEFN00Gf9TrxfQji5SmWiv25qOr7hRZ5Q 3kDWcQJ1tNSb
jSHJMKiA5GTOftQm6MwhB6SFgURWVjjQsGrCyidUQfiWadhydC7+lmOSdVb5 hnXRfTTr1kP3
KhVUgr+KA1TzQVYXcr60Jgzztclea2WiuZU4kcUPd56Z8spdX/kS5kul+vBA u8p6KzTp9HoX
J6FS/O0za1u1ePfJ1GxSI/euE1BZ5+sKUtXuaQRznQ1jGkaLK5QdB8BwID+s hEqY/Fci7M4A
zMkrgF575ub82frCK82P3nOuf1z+6upY+71Apps2o/2dpva6/Jauvg51TH9a 3R9pZ1dpECcq
Ln7u3tCwwOHyBkphKMckWgJbfSpAONKjCGsYR9W8i1ExRbLa1E+Vu9riCqgj qDj+JMm5pyY0
F6X7uwRtlXp+vIHC+guYNetw/N6FmLS0/Y2TCbV1Vf3tKq4ZBxp2ws/I68Kw 5eQoWnKz0V1o
oJ2bpNLKmFzUYc2zpuomvmGtRZYors+J7Eh1f+XvuCL7PVudlVZD8+lpdv56 tFIEw44x0AMk
N6dwdetKjKu1hCvLDzZ8vWjJARr+lhAQHr7Y47SKu3uGqzjhPmvY+OOuL5MK CqfNerXGdUQm
/UZy7sk2Q6bSBZTJV0Y7DoDhQH4Yn0qY/Fci7M4AnGvPADw0d3ls9u3Kc+fl TGt3z3AzCltR
qVZgnPSsCcPxIxtEwg04QzntRU1utZG9sL3MoyXlIK/6KbX5b67+wEBJ9Sl/ qrCQyH7Bn1Z3
KHG5+/WJLHCcJuGCJIcYntUKZ5VvUsDUOOHczUN63fCSW1E/c09oxmElA402 609/uQINW9/R
VRztXQdQaG1Tr0G/8plSxV3UYa0C6AKXZ6BEfh2UbnGXc+BsoNHmKHhyXv7s IrMOV0GkQMNe
LlL/hAYf12dazC5cnOSO2qQIPY0T6PoCl1X4LpDQUBOaYiThgHDdyMPlNY+Z WsUmt4+4Rh7Z
z0T2bJHc4rq4wNVteM0mp0ruThN0DvQtmUoX6F4iu82Ey1OdsuMA5J4BSNVP RdidAbjYfgZg
Zf7s2sIrmx+9tem4Dae16mxJeIYt0LDUHSvhykzt48zTBrKOkxwWqIccUsce MoDoQVTDAnaZ
c44q8/ekXeYeSB5n8djNBWkQgAAEIAABCAw4gUEbwE3AdciprjvVcnmi4m43 G5f2xFy5sVI7
XpOg8ogss9nnTb4EPHPptCjx5icndtwdt9VaeGl569vVRr1U3yq57pFTr3wV p6LfRAsfJ4To
U+ogYOplEiW6JcfXykdqG5d1gvUZ1jkuxM8tUmAcwMhCKWmBvBJIBk4FZKZy a23XJY5uq+p4
YdubWVo+6Z1igwAEIAABCEAAAgeHwNQ1z26fHVlUZrzeKmdGndsN59aac6dh xwGQGYDcq4BM
6kNmALxVQM/+bObjqXvxW+uba25jq7S1lWT9RxqUSogeFVbD6jowwSTVMVXa 8E+/TH+c1Pha
gUhbP9n38CsflhNQ0q+2H4I/YUBgqucTTqvLG3kQAJ6sc5xHpFI1f/xe/kY6 AKtnTRoXcQ4E
AXEUB2EgIyvrgqqdtZjEhwAEIAABiwQmL3vCkh0AO0uAemr9Sxl2nwEQP0Ze 97m7u3XXLbVa
TsLYv7bp/VgjF/n5AyMXZmlRceveAsZ0YGVbXPJwfQcWq4QXn4UzilzCFFDA LzZ5yVN4GU/C
+pmwtgE+gSpI0CqujgKaR5K0eNkgCgIQgAAEIAABCAw3ATsOQK+fAZA6mLnU WH57dc/+SaWx
VZl+SV4DypaNQIHWqGUrWNex/VMTXQtDAAQGjoBJCzeJk1qwOCFdCu8yeara gQh9zi6reoMW
v5+4/HnFHSs+5jH7zDMfrnyp+ly0wc9OYfT/za3zPtZIl1nbcQB6PQOgKmbq lZvB/eznuevs
ICdMngFIJdP9A7VxErqXnKq8dn5SY+qbh0oS+OkPjBQVzig1REeIFJ6qeaAv SIgfzig5a9VR
BrTqXUgYtT9E006tAsMqzhHNHHUO4clJuuzxretjXWCyMefPLhlFjvaZegEm FNZ6dvkuusgi
BHSLK2aAvD9aZGcYqWGO9hBZ4yY8A3mZXxpxMc0l5CgmSeIImF/y/WSYo5M3 abT54gT6PZOu
z4SVHQegDzMAJoUhDgRSCYTfsJR8U9fOkr7kwkukwhIkciChSUiC5HDy5Jtf avxAXsmFMlHe
Vhx/ucLwU+u3DxHCN4bB1LMPKHqahWpR+bLI1xpNLu1IfXqRnS2ZYTmRxQy0 6nAcE33yVVbg
kld+RWr/Gc7LvLWYx+y+REgoIoEcnbxJo80XJ2D9J9swOgsT7HYcAJOciAOB QSOQOvCQ+z6R
O6FCFDZ9IgX69TfJ0WR8qxurqw/1K8VUpdhHPU1Q9wGFziLfkJJJKt0aVWSF PXDVJIckXGJh
BcL3OX8Z1bFuAH7dwnp2WUe6dfU5u7ApnLshmVwg/jhxxEzkaCX9uHTVBw50 vYcbkmpgqpYD
BY8MCXRo/oz8zTJQiToX3Z4jNQmfDbRYkysoNUm46frzzXGt+a9Tk2s2oToi c4+D7C9pap8Q
hy5wUYd7j6zahi+f5G7H35JTL8aAqC77HJMrPfJiNCxRpHw7DkB/lgCZACIO BHpBwH/hZbre
Mt0+TTS3JTBTKUwUI86+EFDtQW36fpkweqpvsalxAvc/Jd+fUThrf0gyjUi1 dRLzRq4Hw+Ky
NhdlUn19zs5fWSbqFSVOXIsN6K/6qIBdZVKhYflxZBI0CbSohJ/m112kYvku YeUmBS58Pxx9
KrlziJST2jkk6JzaSyTkqKpJX2WRtZagm6qIhF7IvIOKazCacGouPboYwzdu 89YeVsmOA8AS
oB5VNmIHgUC4Vw10qamdRaZSJNzhAqeyDjno+LrL8FuNuuvMpG1PI+vOzl9S bYn2NOtCCzfx
7kzi9BRCJgWyNvVuTGcTEzOSTL6Eyal6IdMcTr7c/XCUBG0iZ2pR4W62e30y KRB2SJKTpzbp
uAipCePam0qoz5pcJiZ52YqjW1pAT8Na0C0n9RoJyM/X3lK1Mml+JnFSM0qI 0I253ysHwHwG
YO33x/TeDQXSQqA/BHJfz7kT2nUn+kOpR7nozq5H8odSrGp4yaNoUnC/E7gv HBIUyG0yhk3P
vhXN+vUumvdCZt+AWM9of2lobyTOuEy97hIi5LgYU7NL8FGTOwdDyeY6m8fM 12YC8lNrKl8u
Js3PJE6+3HuUqq8zAEu/+9nES+t6l589KtXgi+2Rhzr4BS+WhuHrObLiwoG5 O4K4hJHhWVuR
jh9XisAAUlb5fatck4GuvilT9Iz2vZYjFQjPTWXibP0CTM7dYnb+izRfOzdR xlac5KFKnUvW
WTuLPWqmZpMaOV+NpIrVEfb9YjRXNYfOOUqXqeX45ftrKke+AQ59uF5ykO8+ iR0HwGQGYO3t
Y9Nvvea0Ft1bF1vfvbv1l7mjT01LoH9PKI9UgN66LHaXrcFQky5z6bKMJI8b /1DVp3oH1bmo
LY5YoLr9SZJvBqkJzUUp3ZIbniqCLkiy8KxZh+P3LmTwm24m1L0ojr/RJleE yj3czk1SpWpu
IiTuEjNpgXHzADpcC4kso60LsM/Z+bFbKYIJat11JPSEJpe8rojUxuOP4K/H cIvV3Wy4A4xr
ITqmTmsYM6FFBWTmaPzdXwv+W5XJzStcCyapkruLhAqKrHST5heJPfWOrCo3 LD9c+1qUSfH1
3dZ/Pw3ffyNF5bhgDS8rk+siAMTkGrTjAJg8A7Aj6pSOyV6qTpYfqFUfPjF2 /PTES4t69yLE
bMpi05tJwXoaR2uCld9TztaFh5tQoF3pG4a+3sINz6Qd+lP5b0Iq3N8fhUPi utFITZJFJQiP
RBHIOlVVk+LkiKPhJ+gTF8d6m4m8iaYWqndqmDTIhDgmrTF8FQRoZxISd4nF XUeBVpdc0f6K
8Au0fgH6O4RA56CskEz14r9s4xq5XZmp/Yxhh5Cp5adWZaAhKZJhvHGEAxhV 2nBF+AnrOHEx
U1uUSZdrUorkwoZbSOpFnUw7rJIfRfgCD7SHyOYRYGXYS8TpGW4MIlCP1plg j2w5fs7hSg9D
MG9+4Z4tdydgflnF1UuAqv9nws3IcwBKXd+sTGYAnNuO4zYS9vpfW+aK+C1v PSCn/WO/oxw5
bhoZQeXuH11LHhtWjUlr4k/oFxUWmzskLgv8EPOWYz1muIeyngUCIQABCEAA AvtFIGFYfb9U
It/uCRxyquulark0UXG3m41LewSu3FipHa9JUHlkLDknmQEQHyD57/Krx6Ze nNVylt6ZT5A5
/d7NwFn/2gZlpmsXRx3rkMBBQsxMcrQ+AYMvbP8F9AkXxK9tQAftGwTiJKva fTsoroTWdl2U
121VHS9sz8jB8knvFBsEIAABCEAAAhA4OASmrnl2++zIojLj9VY5M+rcbji3 1pw7DTsOgAnT
pfMPTb94TsVcev/i9MsXIlO1Wq2VPyyGHQAdOc6+33cHwD8MH2m+6yLEOQBh CZLE7+f4ienJ
B8O5HpM6KmKcBAdg9WwRC4TOPSEg7SR1IKMnGXcntKBqd1doUkMAAhCAQFcE Ji97yZMdgP49
A+C6rqwBkt2z/l+ccdxWeE+1/rvi0cvE/qcUwvkkn1Xxw3HUYi//MqTINWep 65R6WW5kQwAC
EIAABCAAAQgUjIAdB8DkGYCd1o7jNpfeX5z+7WlHnIHQ3nKd5LH/ANrwKHv/ 2fdh/XfkAH9g
rqD/BR/WHHmaYlhrlnLpgYZUFFaugjghXQrvMnlq2QMR+pxdVvUGLX4/cfnz ijsOt/nkmH3m
mQ9XvlR9Lpr17FSp/X+tZ9FrgQNYcXYcAJO3AIl9v/SHpenfTjuOvO8nuLec UoL1rwa51ZZj
xUsgrX9YXR9nkhxWxi9HNaO4XHQji9NKt5KECApCN0x63dYHVr6GZqhhIL6/ KSZfz+GMUkOS
hadqHtAnIX44o9RypSrvb5DhRp4pRN+2I+EHRBnWo91o5qjt5qtvgdbFDo5A P9vUSyxB7Rwt
NvUC7Gd2+S6oyCIYdmIB8n5RgUsy4XLO0ZAia9yk+gJ5JbcWf+S4mOYSchST JHEErGDP2ieb
NLB8cTJdHb3IQsk0aW/9ewZAtFl8NunLXzMff2+isR+uiTMgIEyiZcqayIND IN8zAHGtIhDu
/6mODZtTcsKwqLDYVE0ib36BJ+P1bTtwCSSXIlmZOOXzFTmcKvIC15nK2cBT MYZXt8XF9Kpv
NUTd5ZUSVtuwBSbca1OJdZlFXKtLDg/Xe6QaCQ0mYOHFvSVCGdY53sSQgCVf 449TOAzK/KIL
y0wmps8GWrWJnNzdY7jvSuigspbdpPvK1zF2eS2Hk+e70PKlsq68RYEmJfI3 g8gqztQn57tg
TVIl378stnPdjwUas1ZysJ4BEC3FxE/YLbYnREHAhIC65+nrJ5wk1VSKyyV3 wrg7k5WVYP7y
dmMgmrDtURz97LvJPaN3OvRIcj6xgkJt/sZsJUS3Ri0tq9iESyysdtjoDF+e ugH4dQvraesC
7HN2fgK2ipDQqPwXUVx2mS40Py5d9YEDXe/hFqtsGr8lp5UPqxeoGp1WHfgb qnlMnTbcosJi
c1x3cW0+EJ6AKOEyV6f0X8NrNmte/tr0Q/YXIbmXSG4Ageaa3EvENY+422VA sXz9bTepDItj
mEW4mJmuVsnFzhIgk2cADItkHs2wfzSMZp4vMQ8gAf91lekaznpBprK1JTBT KVK1IsJ+EVDt
QW363hwI8cfRlk1qnIAxqofMAz6YP+twRnFYItX2m/uG/bbKXdk9ukT+TG1d L0pmn7PzV9Z+
NbBe5BvXYiONv0BLMKnQsPy4UiRoEmhRCT/Nr7tIxfJdwro1BpwujUtfmMmd Q6Sc1M4hQWd9
SrsiqR2U/8oKX7z6osvRFHVrMe+acuQSmUTVi9oCleKvMivZ5bZP7DgAJs8A WCknQiDQfwKR
F7DJNWxyrwoXJyFV4JShkaSzCHdDgVLkU7h3NRLuQNWtYtD07B2BfJI1t4Tk JnHy5W6YKpMC
WZt6N6Zz7taVL2Fyql7INIeTL/ewDadNZMO2oaIFLFcJ6V6fTAoEIqeWIrVJ x0VITRipdjiV
yWVikpetOLqlKYHdwM+RNqG1+K3zHJJNkqjcw23YJG2mOGGrwNxlsuMAZFKX yBAoEIHct5zc
CePgWBc4+LUQOaY7+Grvr4b+G0+CJpqtidHQixIlKGDiXaeq1OfrpRfZ9UJm KreBjbC/NLQl
F2fIpl53CRFyXIyp2cX5DKmdqqFkc53NY1pse6mtJZWDRWV6Jyq1mMlZ23EA 9mUJUO+YIhkC
eugiYB5F9v7hwNyXZVzCyPCsYyo6flwpTAo7CG1jv2zWQSi7dR2ytqL+KBCe m8qUr/ULMDl3
i9n5L9J87dxEGVtxkj1MnUvWWTuLPWqmZpMaOV+NpIrVEfb9YjRXNYfOhqUz jJagqknzjrvF
5yCwX0nMixmnoR0HgCVA+9UCyDcTAblg1Kb6cZN5QJ1E9Ur+JMk3g9SE5qJ0 V6Vlhkut1NNd
Z7LwrFmH4/cuJFOF7kvkTKh7oaG/GSRXhMo93M5NUqVqbiIk7hIzaYFx8wA6 XAuJLKOtC7DP
2fmxWymCCWrddSTYXiaXvK6I1Mbjj+Cvx3CL1d1sgEZCXoF+3jxmQotKuHfE 3U0Cjb/7a0Hp
EHdRmzA3ueUldxcJFRSpgEnzCzeArGUM9MmqPcf1k/77qW5dJs3bJI6GEFnw TK0o3K60tjqX
1GImtwo7DoD5DMDa74/p3aS9EgcCFgnI9aM2/1XqDwxcYPqUP1VYSFhDw4SR +sR1o36Zun8M
FyQ5xPBsbvlxeDPpGc7dPMRia4kTldCK+pm7/9aV3KqVARRQO/Va8FdZgH83 WSekjWx1cVWv
wyMFWr8A+5ZduDjJnY9JH9LTOIG2578EAj1tcv2qyHHNI7JCA01US0joov25 hC8KfaX4qzsg
1qQrMylFcmEjr764SziALiA5fPH65cTVkXl3kdA5hDH6dQsTSLjvBCou0NMm kEmui0BzDTTm
hE4yoRnEnUpob4FaSFUjADa5i0i4K+V3AJb/fXPuw+XwLuFx+S397mcTL63r XX724X4ZmUXC
OMd+qUS+BSWg5xMKqj9qQwACEIAABBIIhCdVwDUEBPJ/CExM//nnp8II4sLX 3j42cfacxHdb
rre1mjtNd+vbFb+EiVfWk5ug37Xqhn6c0eYPx7DrhnDf0iZ8CGz5ZL1vapAR BCAAAQhAAAIQ
GAQCU9fGRI3ZkcXa8Zpfn8qZUed2w7m15txpWHYAxLCf/9NKpGOw8vax2kuL CVxWfj9Ti3cA
7JrjJg7AIFQhOqQSyPcl4FSxRBgyAha/BNxPMgVVu5+IyAsCEIAABAIEev4l 4PZIvm+702pt
N2Kr4bYM/jcS9vpfW3FpE+x1/2Mx/gdBAg+F+B8H8ecSDtcC9TKhQJzwo0gi ME4+jRICEIAA
BCAAAQhAAAIDRSD/MwCqGEf8279UdlxXhav3Avn/eifclt6X3pgN7JVqaen8 Q2o3YaS8ArX5
jXX9OIV2GyJjqizCEgKPX0SmDaTyxzHRnDgDS4CHQwa2alDMCgGTFh6I4/9p kjyHnn3Iwlyr
fGXMl8pcK2JCAAIQsEugOwfgrrtzu9lsNpo/envjH987dzsOgHovkP+vzBQ4 blPtS+/MT798
IXKv/dZLmHuLfKRdpJnPAOTLmt4/H7f+p8o6V5Mw/5Nc6XGTSwFbJzCFFTm/ pCilah622/zC
/aj9uahU4ZBA1eQoTqTOJnIC5fW792F6/W9CqlyRPPugzH51NX3INy6LPmTd h4orXBZgL1yV
oTAEMhHoygFotZqNrXrzh4b89Q62t1p3mnHZew6A4+1L71+cfnHGPxugj1ut 1sofFqffu5mp
DCaRI1/AJB1cwvvCTMSqOHoWgh7THNp+xQzM8CSr4W8hunIj21LYXE6YJtI2 dyBOguRITQI2
aOBneHbLHyGQV3Khwrn3LiRSyYG6ssLWfzLq/WrqdvP1j63Ylayl9SGLHmmO WAhAAAKFI9CV
A9Dcrm/9o77VqLd2d7fZikOw09rxxv7fX5z+7WnHmw0I7i3XibP+/Yt8ukTc O0uCu1eXVdP/
5IHh5LACues0d0KlgzKvA6ZwWD2//iY5mjT+cNb9r5eEHHVXsI96mqDuJzST SZV8cSI9zIAo
7c3qpqsi6J+qPeu//vAAJX8qvxCVNu5sWJ/ItIGLPUGg1ipOcoIorWocAZ1v spI6a8O8TODk
zrGfjZm8IACBvhHI7wBMjo9d+cb9/O+lz2/JXvb2H+RvScIjtRf7fukPS9O/ nXacnfDeckrJ
Y//qxu/vkf0hybfkuJj+cKWzDtFFMMlFazVolkHfmtHQZyRVrCs3YBYkl92f 0AolWwIzlcKK
5gjpBQHVHvQkpO7H/CH+ONr+TpihStYznJ2/TSafNSQQVyJlXuuzyT+1TZxa 0sgJnHxg1U0k
UB1hPlp4nJKRclILkqBzIEeT0mkdDGuNaBCAQLEI5H8NaI5yLj6b9OWvmY+/ zyGTJAecQL7X
gKr7X8CsD4RosHE2d6otHpbvN7+Sz0ZWa3KOOQRqE8qvWDjrZFAmMM3j+LHr Y+V9aTXCB6lX
gd33aeZDnapkOEJY7UAbiNREm5XKhousPn9ekXEC7d+kBlUd+WstUttwM/YL N2lsgUbid87D
x8kqxensT5WAMVN2CQ04tcqS2WqAcdUayDpr6XI0XZJAAAL7SKDnrwHNWjYx 8RP2rNKID4E+
EEi18uN0yJ2wbwL7QK/LLPxjvV2KOjjJVcNTW0KpdZzkaJm4GWadSWZyZD3W HrBoA95LAo0E
nXMgykfAJJVJHOWomNR+ppgW6wtREIDA4BDIvwRocMqAJhDoEYHIocpwXmHj I7f1H5cwMjzO
6ElwIdSpyISGhe0R6kxiLdqsmfIdyshZW1E3EOIm2bqRqWzZLiUkJ+8nIlsF MdfZPKYt3ZAD
AQgMAgEcgEGoBXToEwG51alNWQzKHFFbgtHsj+NPkmx26FRKeDihuShttSdo q3LRBUkWnjVr
E+VtxelTU+gim0you8gnNmlygwy36uQQ82sh0A7D7d/kgjIBEnedhq/ZhCs6 rlwBJeN0NrlG
TFCblNeEm0leJjorfUxi6jgmRSAOBCBQOAJ9fQYgTEe+FKa+FWB9U0vDh3Ur j0Q/aT2s5U0o
V75nAOyCihyet5sF0rokYPcZgC6VMU9eULXjCsiVYl71mWICNhMuIkNg6AkM 3DMAYeI9sv6H
vmop4OAQ4NY7OHWBJhA4UAQCEyAHquwUFgIQ6JJAMWYAli9PGpZz6uyqiskM gCGxokdLmAFY
PjnMs0BFrzj0hwAEIAABCECgFwSmrnnrRGZHFmvHa375lTOjzu2Gc2vNudPY ZwfAuNhb4ZjL
l6enzi75w9shOADGUIci4iAsARoKkENeiIKupSmo2kPemCgeBCAAgcEmMKBL gJb/fXPuw+Xw
LuGRPK++Orr4rMwAhD8fJtEDgT2vkMpPkj5lkC/7OJm9yCufhqSCAAQgAAEI QAACEBgaAvvw
FqDVzfr881PhXcIjsZ56qzHz8eeO4775ydbs2xtLN1zZ5adEVscnnl167NSi ConcxJLWe49q
zm+sZzLcJXLzx3tfQPOnlfBMonpUtAMlljfiHajqprBDSYCruBfVakLVJE4v dEPmUBLI15zy
pRpKgKmF2gcHwK+TrirXjTXf2zMATzpO/bVnmguvlKaP11f+vPTC+aXlvz0p B/Lz+sfjX12V
KYK6EyVEWdh6TyXSfQS/QZ9JGuZ+Jlz5Iqe+9zMgNhDf/3LP5I4mnFFqSLLw VM0D+iS/MzTw
ltLUcqUqL9xsxQl0Ef5yqSx0hMDPfE0iRypz1DmEJydJrale5OgHnlV+crtV JAN1GplF3+7r
Re: UML2 Log Interactions [message #107066 is a reply to message #106916] |
Wed, 01 August 2007 15:45 |
Alex Nan Messages: 29 Registered: July 2009 |
Junior Member |
Hi Krishna,
unfortunately your attachment has been removed and I cannot see the screen
shots. Can you reattach the screen shots as gif files? If I won't be able to
figure out from your screen shots the cause of your problem you may need to
send me your correlator, sample logs and a test case on how to reproduce
the problem.
Kind regards,
Alex Nan.
news:f8moil$2qr$1@build.eclipse.org...
> Hi Alex,
> not correlated.
> Krishna
filter
only" in
definition
source
be
correlation!)
out
problem.
events,
in
> > Kind regards,
> > Alex Nan.
> >> Hi Experts,
I
able
but
> >> Regards,
> >> Krishna
FUDForum. Page generated in 0.03136 seconds
