nice to have: an Equinox "Generic" Bridge [message #106264] |
Wed, 12 March 2008 20:24 |
Originally posted by: amottadelli_remove.tele2.it
Equinox has a very nice "servlet bridge" to allow the inclusion of an
Equinox framework in a Servlet environment.
I believe that I would be very nice and useful to have an equivalent
"Equinox" solution for embedding an Equinox framework in a generic java
environment.
It also would be very nice to have a "standard" mechanism to allow the
plugins to communicate with the "external" environment.
Sandro
Re: nice to have: an Equinox "Generic" Bridge [message #106292 is a reply to message #106264] |
Thu, 13 March 2008 10:19 |
Originally posted by: Boyan.Yurukov.softwareag.com
Exactly what I need right now to be honest. Now in order to allow external
programs to access and run the services in the framework, I have to use a
bundle that listens to a port, through which I send all the commands in
text. Very uncomfortable and slow.
Greetings,
Boyan.
"Alessandro Mottadelli" <amottadelli_remove@tele2.it> wrote in message
news:fr9e61$4n8$1@build.eclipse.org...
> environment.
> Best regards,
> Sandro
Re: nice to have: an Equinox "Generic" Bridge [message #106359 is a reply to message #106292] |
Fri, 14 March 2008 08:54 |
Originally posted by: amottadelli_NO_SPAM.it.ibm.com
Yes.
In this days I have been thinking on what kind of "general" model could
be used to communicate with an ambedded framework.
My first idea is that "isolates" could be a nice solutions...
http://bitser.net/isolate-interest/
wdyt?
Sandro
> Greetings,
> Boyan.
Re: nice to have: an Equinox "Generic" Bridge [message #107599 is a reply to message #106292] |
Mon, 07 April 2008 12:37 |
> Greetings,
> Boyan.
do you have any idea how to communicate with the framework besides using
a network connection?
I dont want to use one.
Is it possible to change the Classloaders somehow for example?
Gordian
Re: nice to have: an Equinox "Generic" Bridge [message #107861 is a reply to message #107599] |
Thu, 10 April 2008 09:19 |
The only way I know is to build a bundle that provides a hook and then
to start the Framework from a java application and exploit the hook.
Essentially there is no other way to get access to the internal classes
and services, because of the strong restrictions. Also that is how
Equinox is started in Tomcat - there is a servlet that gets all the http
requests and then forwards them to a bundle that has defined a hook.
What I would suggest is that you build your application as a bundle. I
is easier to do and you have to deal with less classloader issues.
Greetings,
Boyan.
gordian wrote:
> Hello,
> Regards,
> Gordian
Re: nice to have: an Equinox "Generic" Bridge [message #107900 is a reply to message #107599] |
Thu, 10 April 2008 17:49 |
gordian wrote:
> Hello,
> Regards,
> Gordian
Gordian,
we use as a "bridge" a "known" static variable in a class that can be
accessed from the framework loader.
This is fast and convenient but maybe not very clean.
It maybe would be better to implement an "isolate" link (??)
Sandro
Re: nice to have: an Equinox "Generic" Bridge [message #107914 is a reply to message #107599] |
Thu, 10 April 2008 18:47 |
Thank you both.
I made a fragment to the system.bundle that exported the class i needed
to be shared.
Gordian
>> external programs to access and run the services in the framework, I
>> have to use a bundle that listens to a port, through which I send all
>> the commands in text. Very uncomfortable and slow.
>> Greetings,
>> Boyan.
> Hello,
> Regards,
> Gordian
FUDForum. Page generated in 0.03113 seconds
