Home » Archived » M2M (model-to-model transformation) » [QVTo] Execute .qvto transformations from MWE
[QVTo] Execute .qvto transformations from MWE [message #106153] |
Sun, 07 June 2009 15:45 |
I am looking for a WorkflowComponent implementation for executing .qvto
transformation from .mwe scripts (Eclipse EMFT Modeling Workflow Engine).
Do you know any such implementation? If not, some directions how to write
one would be wonderful.
Ioan
Re: [QVTo] Execute .qvto transformations from MWE [message #106512 is a reply to message #106235] |
Fri, 12 June 2009 02:54 |
Hi Radek,
Thanks for your help. The code you wrote is working fine from Action
but when I try to run from WME or run as Java Application ( main() ) I get
following Exception:
Exception in thread "main" java.lang.ExceptionInInitializerError
at
qvto.ecore2uml.invoke2.executor.TransformationExecutor.doLoa d(TransformationExecutor.java:189)
at
qvto.ecore2uml.invoke2.executor.TransformationExecutor.loadT ransformation(TransformationExecutor.java:92)
at
qvto.ecore2uml.invoke2.executor.TransformationExecutor.execu te(TransformationExecutor.java:121)
at qvto.ecore2uml.invoke2.InvokeQVT.convertEcore2UML(InvokeQVT. java:71)
at qvto.ecore2uml.invoke2.InvokeQVT.main(InvokeQVT.java:59)
at
org.eclipse.m2m.internal.qvt.oml.compiler.UnitResolverFactor y$Registry$1.readFactories(UnitResolverFactory.java:66)
at
org.eclipse.m2m.internal.qvt.oml.compiler.UnitResolverFactor y$Registry$1. <init>(UnitResolverFactory.java:44)
at
org.eclipse.m2m.internal.qvt.oml.compiler.UnitResolverFactor y$Registry. <clinit>(UnitResolverFactory.java:43)
... 5 more
Apparently, inside of UnitResolverFactory, QVTo is trying to access
Extension Registry but pluginRegistry is null.
private List<UnitResolverFactory> readFactories() {
ArrayList<UnitResolverFactory> factoryEntries = new
ArrayList<UnitResolverFactory>();
IExtensionRegistry pluginRegistry = Platform.getExtensionRegistry();
IExtensionPoint extensionPoint =
pluginRegistry.getExtensionPoint(POINT_ID);
Ioan
Re: [QVTo] Execute .qvto transformations from MWE [message #106526 is a reply to message #106512] |
Fri, 12 June 2009 09:33 |
Radomil Dvorak Messages: 249 Registered: July 2009 |
Hi Ioan,
In case you are trying to run standalone (no Eclipse),
the bad news is that QVTo does not support this yet, though you can
use a headless eclipse application.
However, the good news is that we plan to support that in early milestones
of the next release.
Obviously, we should have handled such a situation gracefully, check for
the extension
registry availability and drop an explaining message.
Sorry for not clearly manifesting this limitation, the doc material is
always behind
the implementation due to lack of resources ;(.
We will improve that just after the Galileo release.
/Radek
On Fri, 12 Jun 2009 04:54:29 +0200, Ioan <ioan.salau@insighteck.com>
wrote:
> Hi Radek,
> get following Exception:
> at
> at
> at
> at
> at
> at
> ... 5 more
> Regards,
> Ioan
Re: [QVTo] Execute .qvto transformations from MWE [message #107980 is a reply to message #107853] |
Tue, 07 July 2009 10:20 |
Hi Ioan,
Unfortunately, the current invocation API does not give you access to
traces.
The trace meta-model is still internal, though we could support the trace
serialization
at a user provided URI. Will be solved by
https://bugs.eclipse.org/bugs/show_bug.cgi?id=282645.
If it's essential to your application and you need to stick to the
released QVTo 2.0.0, you could
use a custom transf. executor class based on the #282645 resolution.
/Radek
On Mon, 06 Jul 2009 07:35:04 +0200, Ioan <ioan.salau@insighteck.com>
wrote:
> Hi Radek,
> What should I change in your sample to generate the trace model as
> well?
> Ioan
Re: [QVTo] Execute .qvto transformations from MWE [message #498213 is a reply to message #498209] |
Sun, 15 November 2009 22:08 |
Originally posted by: dvorak.radek.gmail.com
Hi Christoph,
We have done a great progress in Eclipse dependency cleanup, but need to
complete
the blackbox support outside Eclipse. Also, it still requires
some extra testing.
Yes, it's still planned.
/Radek
On Sun, 15 Nov 2009 22:48:48 +0100, <christoph.ainhauser@googlemail.com>
wrote:
> Hi Radek,
> Quote:
> Actually I tried the same, until my try failed due to the same exception
> "ExceptionInInitializerError" as in Ioan's example.
> Quote:
>> milestones
> Are there any updates from the release plan? Is it still planned to
> support the standalone invokation of the transformation?
> Christoph
Current Time: Thu Apr 25 04:40:06 GMT 2024
Powered by FUDForum. Page generated in 0.02835 seconds
