Problem generating Axis2 web service client - Element QName is null for TestServiceTestException [message #841622] |
Wed, 11 April 2012 15:00  |
I'm looking to create both a web service and the consuming client using Axis2 and the web tools platform. In particular I've based my work thus far off the tutorial on the top Google result for "Creating a bottom-up Axis2 Web service" (I'd post a link but the forum blocks it). Roughly it creates a bottom up web service and then consumes it by passing the WSDL in to the new web service client option in the WTP.
However problems occur when I try adding exceptions. If I generate a bottom up Axis 2 web service from a class with an exception and then try to generate a client I get this exception message.
Exception occurred during code generation for WSDL : org.apache.axis2.wsdl.codegen.CodeGenerationException: org.apache.axis2.wsdl.codegen.CodeGenerationException: java.lang.RuntimeException: Element QName is null for TestServiceTestException!
at org.eclipse.jst.ws.axis2.consumption.core.command.Axis2ClientCodegenCommand.execute(Axis2ClientCodegenCommand.java:222)
at org.eclipse.wst.command.internal.env.core.fragment.CommandFragmentEngine.runCommand(CommandFragmentEngine.java:419)
at org.eclipse.wst.command.internal.env.core.fragment.CommandFragmentEngine.visitTop(CommandFragmentEngine.java:359)
at org.eclipse.wst.command.internal.env.core.fragment.CommandFragmentEngine.moveForwardToNextStop(CommandFragmentEngine.java:254)
at org.eclipse.wst.command.internal.env.ui.widgets.SimpleCommandEngineManager$6.run(SimpleCommandEngineManager.java:294)
at org.eclipse.jface.operation.ModalContext.runInCurrentThread(ModalContext.java:464)
at org.eclipse.jface.operation.ModalContext.run(ModalContext.java:372)
at org.eclipse.jface.wizard.WizardDialog.run(WizardDialog.java:1029)
at org.eclipse.wst.command.internal.env.ui.widgets.SimpleCommandEngineManager.runForwardToNextStop(SimpleCommandEngineManager.java:264)
at org.eclipse.wst.command.internal.env.ui.widgets.WizardPageManager.runForwardToNextStop(WizardPageManager.java:91)
at org.eclipse.wst.command.internal.env.ui.widgets.WizardPageManager.performFinish(WizardPageManager.java:262)
at org.eclipse.wst.command.internal.env.ui.widgets.DynamicWizard.performFinish(DynamicWizard.java:382)
at org.eclipse.jface.wizard.WizardDialog.finishPressed(WizardDialog.java:827)
at org.eclipse.jface.wizard.WizardDialog.buttonPressed(WizardDialog.java:432)
at org.eclipse.jface.dialogs.Dialog$2.widgetSelected(Dialog.java:624)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:240)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1053)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4165)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3754)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:825)
at org.eclipse.jface.window.Window.open(Window.java:801)
at org.eclipse.ui.internal.handlers.WizardHandler$New.executeHandler(WizardHandler.java:257)
at org.eclipse.ui.internal.handlers.WizardHandler.execute(WizardHandler.java:277)
at org.eclipse.ui.internal.handlers.HandlerProxy.execute(HandlerProxy.java:293)
at org.eclipse.core.commands.Command.executeWithChecks(Command.java:476)
at org.eclipse.core.commands.ParameterizedCommand.executeWithChecks(ParameterizedCommand.java:508)
at org.eclipse.ui.internal.handlers.HandlerService.executeCommand(HandlerService.java:169)
at org.eclipse.ui.internal.handlers.SlaveHandlerService.executeCommand(SlaveHandlerService.java:241)
at org.eclipse.ui.internal.actions.CommandAction.runWithEvent(CommandAction.java:157)
at org.eclipse.jface.action.ActionContributionItem.handleWidgetSelection(ActionContributionItem.java:584)
at org.eclipse.jface.action.ActionContributionItem.access$2(ActionContributionItem.java:501)
at org.eclipse.jface.action.ActionContributionItem$5.handleEvent(ActionContributionItem.java:411)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2696)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2660)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2494)
at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:674)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:667)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:123)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:344)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:622)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:577)
at org.eclipse.equinox.launcher.Main.run(Main.java:1410)
Caused by: org.apache.axis2.wsdl.codegen.CodeGenerationException: org.apache.axis2.wsdl.codegen.CodeGenerationException: java.lang.RuntimeException: Element QName is null for TestServiceTestException!
at org.apache.axis2.wsdl.codegen.CodeGenerationEngine.generate(CodeGenerationEngine.java:293)
... 61 more
Caused by: org.apache.axis2.wsdl.codegen.CodeGenerationException: java.lang.RuntimeException: Element QName is null for TestServiceTestException!
at org.apache.axis2.wsdl.codegen.emitter.AxisServiceBasedMultiLanguageEmitter.emitStub(AxisServiceBasedMultiLanguageEmitter.java:537)
at org.apache.axis2.wsdl.codegen.CodeGenerationEngine.generate(CodeGenerationEngine.java:282)
... 61 more
Caused by: java.lang.RuntimeException: Element QName is null for TestServiceTestException!
at org.apache.axis2.wsdl.codegen.emitter.AxisServiceBasedMultiLanguageEmitter.getFaultParamElements(AxisServiceBasedMultiLanguageEmitter.java:2925)
at org.apache.axis2.wsdl.codegen.emitter.AxisServiceBasedMultiLanguageEmitter.getFaultElement(AxisServiceBasedMultiLanguageEmitter.java:2844)
at org.apache.axis2.wsdl.codegen.emitter.AxisServiceBasedMultiLanguageEmitter.generateMethodElement(AxisServiceBasedMultiLanguageEmitter.java:2366)
at org.apache.axis2.wsdl.codegen.emitter.AxisServiceBasedMultiLanguageEmitter.loadOperations(AxisServiceBasedMultiLanguageEmitter.java:2242)
at org.apache.axis2.wsdl.codegen.emitter.AxisServiceBasedMultiLanguageEmitter.createDOMDocumentForCallbackHandler(AxisServiceBasedMultiLanguageEmitter.java:1232)
at org.apache.axis2.wsdl.codegen.emitter.AxisServiceBasedMultiLanguageEmitter.writeCallBackHandlers(AxisServiceBasedMultiLanguageEmitter.java:1198)
at org.apache.axis2.wsdl.codegen.emitter.AxisServiceBasedMultiLanguageEmitter.emitStub(AxisServiceBasedMultiLanguageEmitter.java:500)
... 62 more
A cut down service that exposes the problem is below.
package test;
public class TestService {
public String returnOdd(int value) throws TestException
if(value % 2 == 1)
return "" + value;
else
throw new TestException(42);
package test;
public class TestException extends Exception {
private static final long serialVersionUID = 6251838669400665002L;
private int exceptionCode;
public TestException(int exceptionCode)
this.exceptionCode = exceptionCode;
public String getMessage()
return "Exception code was " + exceptionCode;
Has anyone encountered this before? It seems that the WSDL being generated by the service isn't able to be consumed by the client generator. If this is the case is there some kind of configuration option to make them speak the same language?
Gareth
FUDForum. Page generated in 0.03423 seconds
