Re: Updates are not installed properly? [message #844242 is a reply to message #844092] |
Fri, 13 April 2012 21:08 |
Christian Eugster Messages: 203 Registered: July 2009 Location: St. Gallen Switzerland |
Hi F FA,
unfortunately I can not access the website of vogella (may be it is down?). As I see it, you don't have to add those commands. It seems, that you have set up p2 correctly as the menues are active and work correctly.
I do it in the following way:
Initially I set the version numbers in my plugins, features and product to (e.g. 1.0.0.201204121110 (major 1, minor 0, service 0, qualifier date and time (yyyymmddhhnn).
Each time I prepare an update for changed plugins, I update the qualifier to an actual timestamp (as described above) and do the same in the features that contain the plugins.
I add the the updated features to the site.xml and build the site.xml. Then I update the update site using rsync.
After that the next time I start my app, p2 messages that there is an update available (I do not automatic updates).
I hope that helps you.
Christian
FUDForum. Page generated in 0.03593 seconds
