Home » Eclipse Projects » Equinox » Remote install/start
Remote install/start [message #106028] Mon, 10 March 2008 15:08 Go to next message
Originally posted by: Boyan.Yurukov.softwareag.com
I want to install/start bundles remotely. Is there a web interface (non-UI)
or a way to connect the osgi api to a remote server in order to manage the
bundles? I couldn't find anything in the api ref and the startup guide.
Greetings,
Boyan Yurukov.
Re: Remote install/start [message #106041 is a reply to message #106028] Mon, 10 March 2008 16:13 Go to previous messageGo to next message
Originally posted by: jacek.pospychala.pl.ibm.com
Boydan,
easiest thing you can do is start equinox with -console <port> argument,
and then connect remotely using telnet to that port.
Boyan Yurukov wrote:
> Hello,
> Greetings,
> Boyan Yurukov.
Re: Remote install/start [message #106055 is a reply to message #106041] Mon, 10 March 2008 16:46 Go to previous messageGo to next message
That's a bit too low-level and I am not sure how to handle the security.
Does anyone know of a bundle that exports the console functionality to a web
service (soap)? Since the server-side Equinox has support for servlets, it
should be possible. My goal is to make a plugin for Eclipse that takes
locally installed bundles and installes/starts them on a serverside osgi
framework.
Greetings,
Boyan.
"Jacek Pospychala" <jacek.pospychala@pl.ibm.com> wrote in message
news:fr3mnh$pm6$1@build.eclipse.org...
> Boydan,
>> Hello,
>> (non-UI) or a way to connect the osgi api to a remote server in order to
>> manage the bundles? I couldn't find anything in the api ref and the
>> startup guide.
>> Greetings,
>> Boyan Yurukov.
Re: Remote install/start [message #106067 is a reply to message #106055] Mon, 10 March 2008 18:29 Go to previous message
Gunnar Wagenknecht is currently offline Gunnar WagenknechtFriend
> service (soap)?
You can use the HTTP/HTML console from Knopflerfish.
https://www.knopflerfish.org/svn/knopflerfish.org/trunk/osgi /bundles/http/httpconsole/readme.html
-Gunnar
Gunnar Wagenknecht
gunnar@wagenknecht.org
http://wagenknecht.org/
Previous Topic:Jetty on Multiple Ports
Next Topic:get bundleInfo/bundleContext for classes within a bundle outside activator
Current Time: Mon Dec 06 00:38:21 GMT 2021
Powered by FUDForum. Page generated in 0.02997 seconds
