Home » Archived » BIRT » Problems building BIRT 3.7.1 from instructions
Problems building BIRT 3.7.1 from instructions [message #841117] |
Tue, 10 April 2012 23:21 |
d h Messages: 10 Registered: March 2012 |
I'm trying to download and build Birt 3.7.1 with the instructions in the link on
wiki.eclipse.org BIRT/FAQ/Birt_Project#Q:_How_to_Build_BIRT_3.7.1.2B_from_GIT.3F
But I'm having problems.
In step 4f, Branch Selection it says to keep the default. The list of branches start with 2_1_0, 2_1_1_Branch_20060829, 2_1_2, ... to 2_6_2, 3_8_0, master. There's 18 of them in all. I just want 3.7.1. Is there a way to just take that? Does master equate to 3.8.0?
I kept the default...
In step 5f where it says:
In "Import Projects", Deselect extension-*, *.features, *.nl, *osgi*, *test*,
org.eclipse.birt.build, org.eclipse.birt.releng.birtbuilder,
org.eclipse.birt.releng.util.
I can't seem to get the filter text so that it unselects the projects for: extension-*, *.features, *.nl, *osgi*, *test*... etc
I've let it add all or a lot of the projects and then gone in and deleted extension-*, *.features, *.nl, *osgi*, *test*, org.eclipse.birt.build, org.eclipse.birt.releng.birtbuilder
But then I get 250 errors. The first is: "API analysis aborted for 'org.eclipse.birt.report.engine.dataextraction' since its build path is incomplete"
Then there are bunch of ColumnDefinition, DataElementAttributes, DataSetDesign, cannot be resolved to a type.
I also tried the Import Projects and just imported everything. No filtering anything.
There are again a bunch of ColumnDefinition, DataElementAttributes, DataSetDesign, cannot be resolved to a type.
Did something change with the Birt 3.7.1 build from the time this document was written till now?
Don
Re: Problems building BIRT 3.7.1 from instructions [message #856361 is a reply to message #855319] |
Wed, 25 April 2012 15:37 |
No, GIT is right. I was assuming you just wanted to build the web
viewer. If that is the case look at the wiki links for the
WebViewerPackager.xml comments after the source has been checked out.
Jason
On 4/24/2012 2:07 PM, d h wrote:
> Hi Jason,
> Thanks for your continued help. Both of these links refer to 3.7.0 and
> checking out the source from cvs. I started with the 3.7.1 code base
> from git. Shouldn't I do the checkouts from there?
> Don
Re: Problems building BIRT 3.7.1 from instructions [message #856442 is a reply to message #856409] |
Wed, 25 April 2012 17:02 |
I just tried this with the 3.7.2 source.
I started with :
http://wiki.eclipse.org/BIRT/FAQ/Birt_Project#Q:_How_do_I_export_org.eclipse.birt.report.runtime_jar_for_3.7_BIRT_web_viewer.3F
step 7. But before I did that I had already checked out the birt source
and cleared any errors. I then checked out the
org.eclipse.birt.build, org.eclipse.birt.releng.birtbuilder projects
from git. I did steps 7-13 and it appears to work for me. Make sure
when you do the ant build that you use option 3 Run Ant Build... so it
will prompt for the specific build you want to do.
Jason
On 4/25/2012 12:28 PM, d h wrote:
> Hi Jason,
> I'm sorry, I should have been clear. And thank you for your patience.
> I want to build the 3.7.1 org.eclipse.birt.report.runtime war.
> There are instructions for in the FAQ for exporting the 3.7.0
> org.eclipse.birt.report.runtime jar.
> But those are for 3.7.0 and cvs.
> I've gone down the path of trying to import org.eclipse.birt.build,
> org.eclipse.birt.releng.birtbuilder.
> But then trying to run the ant build gives me errors.
> Are there instructions for how to do this with git?
> Don
Re: Problems building BIRT 3.7.1 from instructions [message #881982 is a reply to message #881865] |
Tue, 05 June 2012 15:11 |
I did not update any plugins. What error are you getting and on what
step of the wiki?
Jason
On 6/5/2012 7:58 AM, Julio Perez wrote:
> Hello,
> I´ve the same problems which had d h at first time. I´m trying to make
> it by the instructions and have some errors. Could you tell me which
> plugins do you update and how?
> Thanks in advice.
Re: Problems building BIRT 3.7.1 from instructions [message #882020 is a reply to message #882011] |
Tue, 05 June 2012 16:34 |
Did you do this step:
f) In "Import Projects", Deselect extension-*, *.features, *.nl, *osgi*,
*test*, org.eclipse.birt.build, org.eclipse.birt.releng.birtbuilder,
I noticed a couple of your errors are coming from a test project.
Jason
On 6/5/2012 12:17 PM, Julio Perez wrote:
> Hello Jason,
> I´m doing the build according of the wiki´s entry about "How to Build
> BIRT 3.7.1+ from GIT"
> I follow all the steps mentioned there but when finish I don´t have only
> the error related to API_baselines, i´ve also this errors:
> Description Resource Path Location Type
> The method getRGBs() is undefined for the type ColorDialog
> ColorSelector.java
> /org.eclipse.birt.report.designer.ui/src/org/eclipse/birt/report/designer/internal/ui/swt/custom
> line 285 Java Problem
> ComboBoxColorCellEditor.java
> /org.eclipse.birt.report.designer.ui/src/org/eclipse/birt/report/designer/internal/ui/views/property/widgets
> line 353 Java Problem
> The method isValidFilePath(HttpServletRequest, String) in the type
> ParameterAccessor is not applicable for the arguments (String)
> ParameterAccessorTest.java
> /org.eclipse.birt.report.viewer.tests/test/org/eclipse/birt/report/viewer/utility
> line 812 Java Problem
> line 821 Java Problem
Re: Problems building BIRT 3.7.1 from instructions [message #882141 is a reply to message #882051] |
Tue, 05 June 2012 23:23 |
Did you use the allinone birt download to build the source?
I believe those calls are implemented in the org.eclipse.swt plugin.
Jason
On 6/5/2012 1:56 PM, Julio Perez wrote:
> First of all Jason, thanks for all.
> I tell you,
> Once this files with this extensions are be deleted I continue with
> errors refered to the methods getRGB() and setRGB().
> Do you know what could it be?
Re: Problems building BIRT 3.7.1 from instructions [message #882647 is a reply to message #882392] |
Wed, 06 June 2012 23:05 |
I believe the error is due to checking out the source from head versus
checking out the 3.7.2 version. I tried it and got the same error as
you. I then switched to the GIT perspective and expanded the Tags tree
under Branches and located the 3.7.2 release tag. I then right clicked
on the release tag and selected the checkout option. After doing this
the source built fine.
Jason
On 6/6/2012 7:32 AM, Julio Perez wrote:
> I´ve tested with the one in the instructions, Eclipse SDK 3.7,
> EMF+XSD,......., step by step,
> and also downloading the Eclipse all in one 3.7.2 and installing there
> the SDK from the "Install new software" of Eclipse and both of them
> carry me to the same place.
> I've tested in linux and Windows and both of them give me these errors.
Re: Problems building BIRT 3.7.1 from instructions [message #888779 is a reply to message #888531] |
Mon, 18 June 2012 15:58 |
This link:
http://wiki.eclipse.org/BIRT/FAQ/Birt_Project#Q:_How_do_I_export_the_3.7_BIRT_web_viewer.3F
Needs some updating with GIT instead of cvs, but look at step 9. You
will notice you have to set the integratedir to you allinone download
location.
Jason
On 6/18/2012 4:45 AM, Julio Perez wrote:
> Hi again Jason,
> I´m having problems when I try to build the Web Viewer. When I use ant
> build to make it, it creates me the birt_web folder, but after 20
> seconds it gives me an error about a folder that doesn´t exists, caused
> by a variable which is not taking its value:
> BUILD FAILED
> C:\Birt_372\eclipse\workspace\org.eclipse.birt\viewer\org.eclipse.birt.report.viewer\WebViewerPackager.xml:312:
> The following error occurred while executing this line:
> C:\Birt_372\eclipse\workspace\org.eclipse.birt\viewer\org.eclipse.birt.report.viewer\WebViewerPackager.xml:634:
> C:\Birt_372\eclipse\workspace\org.eclipse.birt\viewer\org.eclipse.birt.report.viewer\${integrate.dir}\plugins
> does not exist.
> Do i need to declare this variable anywhere? What value to?
> Thank you so much!
Re: Problems building BIRT 3.7.1 from instructions [message #906212 is a reply to message #906173] |
Fri, 31 August 2012 21:11 |
Pamela
As stated in the bug you referenced 3 and 4 are caused by not installing
the EMF+XSD SDK 2.7.0 to the allinone. Error 1 is caused which has a
description in item 6. On your second one, which plugin is having the
issue?
Jason
On 8/31/2012 3:34 PM, Pamela White wrote:
> Also having trouble with building BIRT 3.7X with GIT. 1. Downloaded all
> in one birt.
> 2. cloned GIT repository with Master branch
> 3. checked out tag BIRT_3_7_0_Release_20110606101 118235d.
> 1st Attempt: then imported files as directed in step f. and let the
> project build. Got 65 thousand or so errors. Completely cleaned the
> workspace.
> 2nd Attempt: repeated steps 1-3. Just built what I had checked out. Now
> there are just three errors.
> 1. The "An API baseline has not be set for the current workspace"(as
> listed in the instructions so it is ok)
> 2. Plugin Problems- Bundle 'org.apache.jasper:bundle-version='5.5.17'
> cannot be resolved
> 3. Referenced element 'enablement' is not defined elementAdapters.exsd
> /org.eclipse.birt.report.designer.ui/schema line 92
> 4. Referenced element 'enablement' is not defined
> reportItemEditpart.exsd /org.eclipse.birt.report.designer.ui/schema line 51
> I have seen the bug report for errors 3 and 4. (Bugzilla Bug 310987)
> Clearly I have missed something. Could it be because the all in one BIRT
> is version 4.2 and the tagged version I checked out is 3.7? Thank you.
Re: Problems building BIRT 3.7.1 from instructions [message #908007 is a reply to message #906456] |
Tue, 04 September 2012 14:39 |
In my build the org.eclipse.birt.report.viewer plugin has a dependency
on org.apache.jasper but it is marked as optional. Open the plugin.xml
of the viewer plugin and select the dependencies tab, select the jasper
plugin and click on properties. Make sure it is marked as optional. Do
a project->clean.
Jason
On 9/1/2012 10:33 AM, Pamela White wrote:
> The plugin is org.eclipse.birt.report.designer.ui/scheme for the
> enablement error
> and /org.eclipse.birt.report.viewer/META-INF for the bundle issue. Thank
> you.
Re: Problems building BIRT 3.7.1 from instructions [message #908596 is a reply to message #908172] |
Wed, 05 September 2012 16:10 |
In your install do you have the org.eclipse.core.expressions_version.jar
plugin?
Check the dependencies tab for that plugin to verify that there is a
reference to it.
Jason
On 9/4/2012 5:40 PM, Pamela White wrote:
> Thank you. That removed the jasper dependency issue.
> I installed EMF+XSD SDK 2.7.0 to the allinone. Wiped the workspace, re-installed the eclipse allinone, unzipped and installed the other packages suggested(DTP,WTP,GEF,Framework).
> Still getting the
> Referenced element 'enablement' is not defined elementAdapters.exsd /org.eclipse.birt.report.designer.ui/schema line 92 Plug-in Problem
> Referenced element 'enablement' is not defined reportItemEditpart.exsd /org.eclipse.birt.report.designer.ui/schema line 51 Plug-in Problem
> Continued research sort of suggests that the expressionLanguage.exsd file is missing or not being pointed at properly by the plugin. Have supplied a screenshot of editing of the extension showing the missing schema file. Thank you.
Current Time: Thu Apr 25 08:22:48 GMT 2024
Powered by FUDForum. Page generated in 0.05219 seconds
