Integrated Agent Controller, config file invalid [message #105968] |
Fri, 20 July 2007 11:50 |
Originally posted by: chantal.ackermann.btelligent.de
Hello all,
sry, if I am refering to a topic that has already been discussed. I've
looked through threads that mention the IAC unavailability but due to the
log output I get I am not sure whether this is really the problem with my
installation (a brandnew from-scratch out-of-the-box one).
My system is: Windows XP prof
Java Runtime: 1.5.0_11 (tried with 1.6 as well)
Eclipse: Version: 3.3.0 (wtp-all-in-one pack clean install)
eclipse.buildId=I20070625-1500
eclipse.vm=C:\Programme\eclipse\..\Java\jre1.5.0_11\bin\java w.exe
tptp: 4.4.0.1
Release files: wtp-all-in-one-sdk-R-2.0-200706260303-win32.zip
tptp.runtime.allInOne.win32.win32.x86-TPTP-4.4.0.1.zip
I installed everything from scratch using those two files, yesterday.
Later on, I've added the Subversive Plugin and today I updated the latest
Patch (Eclipse core I think). There weren't any other updates for the
installed plugins/features.
I've tried running eclipse under 1.5 and 1.6 (using -vm from the
commandline). I started with a new workspace and imported the project
after renaming the .project, .classpath and .settings files/dirs. So there
shouldn't be any old config files lingering.
The application I want to test runs fine launched by eclipse through "Run"
but gives the above error run in "Profile" - though I don't think that
this matters in the current state of affairs... ;-)
The effect of the error is that the Integrated Agent Controller is not
started. The log output follows right underneath. I don't understand it,
though. Could someone enlighten me on what is going wrong?
!ENTRY org.eclipse.update.configurator 2007-07-20 13:30:10.968
!MESSAGE Can't find bundle for base name feature, locale de_DE
!ENTRY org.eclipse.tptp.platform.iac.administrator 4 0 2007-07-20
13:30:10.968
!MESSAGE Execution framework config file is invalid. This could be caused
by the execution plugin checked out in your workspace.
13:30:11.171
13:30:11.171
!MESSAGE IAC could not be started due to invalid configuration files.
13:30:13.203
13:30:13.359
13:30:13.359
!ENTRY org.eclipse.hyades.trace.ui 4 4 2007-07-20 13:30:14.328
!MESSAGE Agent Controller is unavailable under port 10002. Make sure that
the service is started and the port number is correct under preferences.
!STACK 1
org.eclipse.core.runtime.CoreException: Agent Controller is unavailable
under port 10002. Make sure that the service is started and the port
at
org.eclipse.tptp.trace.ui.internal.launcher.core.LauncherUti lity.createCoreException(LauncherUtility.java:123)
Thanks a lot for your attention and help!
Chantal
FUDForum. Page generated in 0.03164 seconds
