Re: Converting BIRT reports or Upgrade [message #840874 is a reply to message #840433] |
Tue, 10 April 2012 15:51 |
I am not familiar with the Troux BIRT reporting solution. Do you have a
link we can look at? BTW 3.7.2 should be able to run 2.6 and 2.5 reports.
Jason
On 4/10/2012 12:44 AM, Mitchell Bevan wrote:
> I am seeking to do one of the following (whichever is quicker/easier)
> A) Convert a BIRT 2.6 report design back to a BIRT 2.5 report design.
> B) Upgrade the Troux BIRT reporting engine to align with BIRT 2.6 report
> designs.
> Can you explain briefly what files control the Troux reporting engine?
> Are they tied to a specific version of Troux, or can they be managed (or
> upgraded) independently?
> Will BIRT 3.7.2 be backwards compatible with 2.6 and 2.5 reports?
> Many thanks
Re: Converting BIRT reports or Upgrade [message #841637 is a reply to message #841086] |
Wed, 11 April 2012 15:17 |
Can you give some more detail on how you run the reports? Are you using
the BIRT viewer or is this done with the BIRT APIs? BTW if your reports
are not using anything specific to 2.6 you most likely can change the
header in the report to the 2.5 version and it will work.
Jason
On 4/10/2012 6:18 PM, Mitchell Bevan wrote:
> Hi Jason,
> I was under the impression that Troux BIRT reporting was the same as
> BIRT Eclipse. BIRT is just part of the Troux suite which you probably
> already are aware of.
> Unfortunately we don't have a link as it is hosted on our internal
> network. Is there any files which i can upload to you or extract the
> data out of which may make it easier for you?
> I did see the latest version of BIRT 3.7.2 which i might test out and
> see if it works.
> Thanks
Re: Converting BIRT reports or Upgrade [message #847699 is a reply to message #847040] |
Tue, 17 April 2012 15:05 |
Why will 2.6 not run your 2.5 reports?
Jason
On 4/16/2012 8:34 PM, Mitchell Bevan wrote:
> Hi Jason,
> The reports that are created were in 2.5 and so we cannot run them in
> 2.6 therefore all the reports are only using the 2.5 features.
> Do you think the 3.7.2 version will run the 2.5 reports?
> Thanks
FUDForum. Page generated in 0.04208 seconds
