Re: [Acceleo] Nothing is generated [message #843188 is a reply to message #840109] |
Thu, 12 April 2012 21:02 |
Michaël Melchiore Messages: 47 Registered: April 2012 |
Member |
Unluckily, you guys replied in the topic I had reported as a duplicate. If needed, I can repost your answers here from the email notifications I received.
I imported the two "UML to Java" example plug-ins in my workspace and launched an Eclipse debug application from there. Then I pasted the the uml and umlclass files into a newly created project and tried to trigger Acceleo generation from the popup menu. I get a message window saying "The chosen operation is currently unavailable" along with the following logs :
!ENTRY org.eclipse.osgi 2 0 2012-04-12 22:51:27.978
!MESSAGE The activator org.eclipse.acceleo.module.example.uml2java.helios.ui.Activator for bundle org.eclipse.acceleo.module.example.uml2java.helios.ui is invalid
!STACK 0
org.osgi.framework.BundleException: The activator org.eclipse.acceleo.module.example.uml2java.helios.ui.Activator for bundle org.eclipse.acceleo.module.example.uml2java.helios.ui is invalid
at org.eclipse.osgi.framework.internal.core.AbstractBundle.loadBundleActivator(AbstractBundle.java:156)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.start(BundleContextImpl.java:751)
at org.eclipse.osgi.framework.internal.core.BundleHost.startWorker(BundleHost.java:370)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.start(AbstractBundle.java:284)
at org.eclipse.osgi.framework.util.SecureAction.start(SecureAction.java:417)
at org.eclipse.osgi.internal.loader.BundleLoader.setLazyTrigger(BundleLoader.java:265)
at org.eclipse.osgi.framework.internal.core.BundleHost.loadClass(BundleHost.java:239)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.loadClass(AbstractBundle.java:1197)
at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.createExecutableExtension(RegistryStrategyOSGI.java:174)
at org.eclipse.core.internal.registry.ExtensionRegistry.createExecutableExtension(ExtensionRegistry.java:904)
at org.eclipse.core.internal.registry.ConfigurationElement.createExecutableExtension(ConfigurationElement.java:243)
at org.eclipse.core.internal.registry.ConfigurationElementHandle.createExecutableExtension(ConfigurationElementHandle.java:55)
at org.eclipse.ui.internal.WorkbenchPlugin$1.run(WorkbenchPlugin.java:267)
at org.eclipse.ui.internal.WorkbenchPlugin.createExtension(WorkbenchPlugin.java:263)
at org.eclipse.ui.internal.PluginAction.createDelegate(PluginAction.java:122)
at org.eclipse.ui.internal.PluginAction.runWithEvent(PluginAction.java:223)
at org.eclipse.jface.action.ActionContributionItem.handleWidgetSelection(ActionContributionItem.java:584)
at org.eclipse.jface.action.ActionContributionItem.access$2(ActionContributionItem.java:501)
at org.eclipse.jface.action.ActionContributionItem$5.handleEvent(ActionContributionItem.java:411)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1258)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:3540)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3161)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2640)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2604)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2438)
at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:671)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:664)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:115)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:369)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
at java.lang.reflect.Method.invoke(Method.java:616)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:620)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:575)
at org.eclipse.equinox.launcher.Main.run(Main.java:1408)
at org.eclipse.equinox.launcher.Main.main(Main.java:1384)
Caused by: java.lang.ClassNotFoundException: org.eclipse.acceleo.module.example.uml2java.helios.ui.Activator
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:506)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:422)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:410)
at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loadClass(DefaultClassLoader.java:107)
at java.lang.ClassLoader.loadClass(ClassLoader.java:266)
at org.eclipse.osgi.internal.loader.BundleLoader.loadClass(BundleLoader.java:338)
at org.eclipse.osgi.framework.internal.core.BundleHost.loadClass(BundleHost.java:232)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.loadBundleActivator(AbstractBundle.java:149)
... 44 more
Root exception:
!ENTRY org.eclipse.ui 4 4 2012-04-12 22:51:27.991
!MESSAGE Could not create action delegate for id: org.eclipse.acceleo.module.example.uml2java.helios.ui.popupMenus.acceleoGenerateUmlToJavaAction
!ENTRY org.eclipse.equinox.registry 4 1 2012-04-12 22:51:27.995
!MESSAGE Plug-in org.eclipse.acceleo.module.example.uml2java.helios.ui was unable to load class org.eclipse.acceleo.module.example.uml2java.helios.ui.popupMenus.AcceleoGenerateExampleUml2javaAction.
!STACK 0
java.lang.ClassNotFoundException: org.eclipse.acceleo.module.example.uml2java.helios.ui.popupMenus.AcceleoGenerateExampleUml2javaAction
A bit of background informations about my problem.
I am working on a medium sized framework that uses Acceleo 2 as a code generation back-end. To that purpose, several dedicated metamodels plug-ins have been defined in the workspace.
As the framework is about to greatly evolve, I am investigating Acceleo 3 to solve the few issues I have with our current templates extendibility. If successful, my ultimate goal is to convince my colleagues to also switch to Acceleo 3. I use the latest nightly build because I had the "SWT null argument" bug.
I am not allowed to provide you with code snippets. I did try to reproduce the bug on a small project but, with no success.
[Updated on: Thu, 12 April 2012 21:04] Report message to a moderator
FUDForum. Page generated in 0.02836 seconds
