Re: console persistency [message #105725 is a reply to message #105539] |
Sat, 01 March 2008 13:32 |
Originally posted by: jeff.code9.com
This is standard OSGi behavior and is not related to the console (the
console just lets you see it). With Equinox you can run with -clean to
clear out the configuration each time you start.
Jef
Reto Bachmann-Gmür wrote:
> For now I found out that things seems to be stored relatively to the
> equinox jar, so when using maven its in
> ~/.m2/repository/org/eclipse/osgi/3.3.0-v20070530/configurat ion/
>> I've just started using equinox, and I was surprised to see the
>> bundles still installed after restarting the equinox console. How does
>> this persistency work? where is the list of installed bundles stored?
>> can I start the console in a non-persistent mode?
>> Cheers,
>> reto
FUDForum. Page generated in 0.03329 seconds
