Re: Migrate Eclipse RCP application from Eclipse 3.7 to eclipse e4 SDK [message #843877 is a reply to message #840556] |
Fri, 13 April 2012 13:04 |
Kuldeep Jain Messages: 6 Registered: December 2011 |
Hi Tom & Lars,
I tried using a custom Legacy.e4xmi file, but have no clue about how to edit that, neither found any documentation about it. I tried to modify it but still seeing Run and Search menus. Could you please let me know about what to change in Legacy.e4xmi file to remove the menubar all together and some of the toolbar items. I also want to mention that in my RCP application I am having an Xtext plugin, if that makes any difference.
[Updated on: Fri, 13 April 2012 13:05] Report message to a moderator
Re: Migrate Eclipse RCP application from Eclipse 3.7 to eclipse e4 SDK [message #847335 is a reply to message #843895] |
Tue, 17 April 2012 07:55 |
hi Lars & Tom,
Thanks for the information. I installed e4 tools on my Eclipse 4.2 and was able to change stuff in Legacy.e4xmi file. But even if I make the menu bar invisible or mark toBeRendered as false, and then first time when I launch the Application, it does not show the Menu bar, which is correct, but when I relaunch it without making any change then it starts showing the Menu bar with Search and Run menu items. And I am unable to figure out from where they are coming from.
Note: I also want to mention that in my RCP application I am having Xtext plugin.
[Updated on: Tue, 17 April 2012 08:06] Report message to a moderator
FUDForum. Page generated in 0.03616 seconds
