@LongString property editor's action alignment [message #837154] |
Thu, 05 April 2012 10:27 |
Roded Bahat Messages: 152 Registered: August 2011 |
I've noticed that button actions of property editors which have the @LongString annotation are aligned horizontally which isn't very conservative of screen space. LongString editors should probably be added vertically as in Multiline property editors.. Should I open a bug for this?
While I'm at it, is it possible to add an action to a property editor so that the action will always be active - even when the property editor is disabled? I understand that in this case the action loses relevance to the editor, but adding actions under properties is the most visually appealing way of showing actions next to properties (I could add actuators to the property editor's related content, but it looks less appealing as the minimum width is 20).
Roded
[Updated on: Thu, 05 April 2012 14:51] Report message to a moderator
Re: @LongString property editor's action alignment [message #837399 is a reply to message #837387] |
Thu, 05 April 2012 16:14 |
Basically, I'd like to allow the user to be able to copy a property editor's value to the clipboard even when the editor is disabled.
If I add the "Copy" action to the property editor, it'll disable with the editor..
Another way to look at it: Is it possible to allow selection & copying of text in a disabled editor? (I think SWT doesn't allow this...)
Bug for @LongString: 376198
[Updated on: Thu, 05 April 2012 16:19] Report message to a moderator
FUDForum. Page generated in 0.02475 seconds
