Home » Eclipse Projects » BIRT » BIRT viewer integration into a JSF web application
BIRT viewer integration into a JSF web application [message #836618] Wed, 04 April 2012 17:58 Go to next message
Claude B is currently offline Claude BFriend
Member
Hi all,
I'm trying to integrate the BIRT Viewer into a JSF based web application, I'm using "Eclipse BIRT 3.7.1" and I downloaded "birt-runtime-3_7_1" for the viewer
I tried to use the "BIRT Reproting Xeb Project" option while creating a new dynamic web project so I downloaded "birt-wtp-integration-sdk-3_7_1", I copied the plugins and features folders into eclipse and I run I with the -clean command.
But now I'm facing many problems:
- First problem is when I create a new dynamic web project v 3.0 and select BIRT Reporting web project an error message appears:" Dynamic Web Module 3.0 requires Java 1.6 or newer." however I'm having JDK 1.7 and I've successfully created many other dynamic web project v 3.0
- Second problem:(I reduced the web project version to 2.5 to continue) when I clic finish I get a code having many warnings and one error in the file /WebContent/webcontent/birt/ajax/utility/BirtUtility.js, and a NullPointerException appears every build:
Errors occurred during the build.
Errors running builder 'JavaScript Validator' on project 'birt_jsf'.
- Third problem: Despite of this error, I can view reports but this works only if I set the reportContainer option to div and I get an empty report if I set it to iframe, and I need the second option in my project because I need to use the export options provided by the iframe one.
here is my JSP code:
<html>
<f:view>
<body>
<birt:report id="birtViewer" reportDesign="SalesInvoice.rptdesign"
height="600"
width="800"
format="html"
isHostPage="false"
reportContainer="div"
</birt:report>
</body>
</f:view>
</html>
So my question is how can I create a BIRT reporting web project with a dynamic web project v3.0 having no errors and generate reports using the iframe option
Need your help please
Sorry for the long message
Re: BIRT viewer integration into a JSF web application [message #837434 is a reply to message #836618] Thu, 05 April 2012 16:56 Go to previous message
Jason Weathersby is currently offline Jason WeathersbyFriend
Claude,
Can you log a bug for this issue. I see the validation error as well in
3.7.1 and 3.7.2. I only have options for web project version 2.4 and
less though.
On the iframe issue have you tried using a viewer tag instead of the
report tag?
Jason
On 4/4/2012 1:58 PM, Claude B wrote:
> Hi all,
> <html>
> <f:view>
> <body>
> height="600"
> width="800"
> format="html"
> isHostPage="false"
> </birt:report>
> </body>
> </f:view>
> </html>
> iframe option
Previous Topic:Chart area and legend colors
Next Topic:Crosstab style
Current Time: Wed Dec 01 10:16:46 GMT 2021
Powered by FUDForum. Page generated in 0.02425 seconds
