Re: Logging issues in BIRT 3.7.1 [message #837404 is a reply to message #836546] |
Thu, 05 April 2012 16:17 |
Annette,
Can you try removing the setting in websphere for birt and just leave
the log level set to finest in the web.xml. Next try providing a log
directory:
<context-param>
<param-name>BIRT_VIEWER_LOG_DIR</param-name>
<param-value></param-value>
</context-param>
as a test and see if anything is written to this directory. Make sure
you have write permission on the directory.
Jason
On 4/4/2012 12:06 PM, Annette Rego wrote:
> I want to enable debugging in BIRT 3.7.1. So i set BIRT_VIEWER_LOG_LEVEL to FINEST in the web.xml. But in log folder, only Exceptions are getting logged nothing else. I am using WebSphere.In WebSphere i have set org.eclipse.birt.*=finest. Still no luck. I have attached web.xml Does anyone know if i have missed anything?
Re: Logging issues in BIRT 3.7.1 [message #840034 is a reply to message #837561] |
Mon, 09 April 2012 15:33 |
Annette
Have you made an progress on this issue?
Did you deploy as described here:
http://wiki.eclipse.org/BirtPOJO_Viewer_WebSphere_Deployment
Jason
On 4/5/2012 4:48 PM, Annette Rego wrote:
> Thanks for your reply Jason. I tried by removing the settings in
> webshere. But dint work. I also tried by giving different directory in
> <context-param>
> </context-param>
> but dint work.Even if i give different directory, log files are getting
> created inside birt.war\logs which is default path. I am not able to
> figure out the problem
Re: Logging issues in BIRT 3.7.1 [message #840853 is a reply to message #840811] |
Tue, 10 April 2012 15:30 |
Good to hear. I should have read the whole thread before responding :>
Jason
On 4/10/2012 10:36 AM, Annette Rego wrote:
> Hi Jason,
> Its working now :). I changed the birt package(org.eclipse.birt) log
> level to FINEST in WebSphere And Changed the value of <context-param>
> <param-name>BIRT_VIEWER_WORKING_FOLDER</param-name>
> <param-value>true</param-value>
> </context-param> to blank. And changed the value of <context-param>
> <param-name>WORKING_FOLDER_ACCESS_ONLY</param-name>
> </context-param>
> to false.
> Annette
FUDForum. Page generated in 0.03943 seconds
