Home » Archived » M2M (model-to-model transformation) » [QVTO] Invoke a transformation using its XMI file(Invoke in Java a QVTo transformation from its XMI file, not from the source)
[QVTO] Invoke a transformation using its XMI file [message #835609] Tue, 03 April 2012 13:03 Go to next message
thomas legrand is currently offline thomas legrandFriend
Hello all,
I investigate the way to call in Java a QVTo transformation, not from the qvto file but from an XMI file representing the transformation (conforming the qvto metamodel).
Does anyone have a clue to do so ?
Tom
PS: For those interested in the reason why I do that, read below
I "transform qvto transformation", i.e I use qvto transfos to transform other qvto transfos. First, I create an XMI file "mytransfo.xmi" from a qvto file "mytransfo.qvto" using the following code and the Eclipse/Qvto launcher:
modeltype qvto uses qvtoperational::expressions('[...]eclipse.org/QVT/1.0.0/Operational');
transformation copyToXmi(in model : qvto,out outmodel : qvto);
main()
	model.objects()[OperationalTransformation].deepclone();
"mytransfo.xmi" is an instance of the qvtoperational metamodel. Then I transform this instance to change names, mapping operations, parameters... and obtain a "finaltransfo.xmi". I finally want to execute this final transformation, directly from the XMI file without having to translate the model to some qvto code (m2t).
Re: [QVTO] Invoke a transformation using its XMI file [message #835623 is a reply to message #835609] Tue, 03 April 2012 13:20 Go to previous message
Nicolas Rouquette has a patch awaiting source approval. If you contact
him, nicolas.f.rouquette _at_ jpl.nasa.gov, he may able to let you have
a copy. Be aware that the XMI file is not OMG compliant and may evlv e
to be OMG complinat once OMG defines an XMI serialisation to comply with.
Ed Willink
On 03/04/2012 14:03, thomas legrand wrote:
> Hello all,
> Tom
> modeltype qvto uses
> main()
Previous Topic:[ATL] Problem to run ATL in JAVA
Next Topic:[QVTO] Use metamodel mappings with nested packages
Current Time: Sat Feb 22 02:30:24 GMT 2020
Powered by FUDForum. Page generated in 0.02101 seconds
