Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » [Teneo] and SDO
[Teneo] and SDO [message #104334] Thu, 06 December 2007 17:18 Go to next message
Daniel Tuohy is currently offline Daniel TuohyFriend
Member
We have an EMF data model that we are currently persisting with
Teneo/Hibernate. However, we are expecting that in the future parts of our
data model, including some of the objects that our EMF objects reference,
will be coming from heterogeneous sources (Web Services, other remote data
bases, etc). So for example, Foo has a EList of Bars, and we expect that
our Bars will need to be lazy-loaded from a Web Service. My questions are:
1. Are we boxing ourselves out of a clean pure-SDO design by going with
Teneo?
2. Is there a slick SDO project that does automated ORM with EMF models?
3. If you (Ed and Martin in particular) were in our shoes, would you stick
with Teneo?
I apologize that the scenario is somewhat vague, I'm really just looking for
some free advice from the experts!.
Daniel Tuohy
Re: [Teneo] and SDO [message #104360 is a reply to message #104334] Thu, 06 December 2007 18:45 Go to previous messageGo to next message
--------------000509030405000909000902
Daniel,
Comments below.
Daniel Tuohy wrote:
> Hello,
> Teneo?
I don't think so. In general SDO is just a candy coated wrapper around
EMF. It doesn't provide much of anything that can't be accomplished
with EMF directly. I'm not sure if the Teneo's design allows references
to non-Teneo-based resources. I suspect it does.
EMF 2.4 also introduces a lot of greater flexibility in the URI
converter to effective support complete REST services.
<https://bugs.eclipse.org/bugs/show_bug.cgi?id=207671>
https://bugs.eclipse.org/bugs/show_bug.cgi?id=191077
The latter bugzilla even has a simple servlet attachment that I used to
test read, write, and delete access via HTTP.
I think Teneo does exactly that. Eike Stepper's CDO/Net4J project does
some interesting things in this field as well.
> with Teneo?
Yes, I think in the future we'll see synergy with the EclipseLink project.
Eclipse will now gladly accept your gratitude in the form of donations. :-P
http://www.eclipse.org/donate/
> Daniel Tuohy
Content-Type: text/html; charset=ISO-8859-1
<html>
<head>
</head>
Daniel,<br>
<br>
Comments below.<br>
<br>
<br>
Daniel Tuohy wrote:
<blockquote cite="mid:fj9apv$km1$1@build.eclipse.org" type="cite">
<pre wrap="">Hello,
Teneo?
</pre>
</blockquote>
I don't think so.&nbsp; In general SDO is just a candy coated wrapper around
EMF.&nbsp; It doesn't provide much of anything that can't be accomplished
with EMF directly.&nbsp; I'm not sure if the Teneo's design allows
references to non-Teneo-based resources.&nbsp; I suspect it does.&nbsp;&nbsp; <br>
<br>
converter to effective support complete REST services. <a
href="https://bugs.eclipse.org/bugs/show_bug.cgi?id=207671"><br>
</a>
<blockquote><a
href="https://bugs.eclipse.org/bugs/show_bug.cgi?id=207671">https://bugs.eclipse.org/bugs/show_bug.cgi?id=207671</a><br>
<a href="https://bugs.eclipse.org/bugs/show_bug.cgi?id=191077">https://bugs.eclipse.org/bugs/show_bug.cgi?id=191077</a><br>
</blockquote>
test read, write, and delete access via HTTP.<br>
<pre wrap="">2. Is there a slick SDO project that does automated ORM with EMF models?
</pre>
</blockquote>
I think Teneo does exactly that.&nbsp; Eike Stepper's CDO/Net4J project does
some interesting things in this field as well.<br>
<pre wrap="">3. If you (Ed and Martin in particular) were in our shoes, would you stick
with Teneo?
</pre>
</blockquote>
project.<br>
<pre wrap="">
</pre>
</blockquote>
donations.&nbsp; :-P<br>
<blockquote><a href="http://www.eclipse.org/donate/">http://www.eclipse.org/donate/</a><br>
</blockquote>
<pre wrap="">
Daniel Tuohy
</pre>
</blockquote>
<br>
</body>
</html>
--------------000509030405000909000902--
Re: [Teneo] and SDO [message #104367 is a reply to message #104360] Thu, 06 December 2007 18:55 Go to previous messageGo to next message
Member
Ed- Thanks for the prompt response, that's just what I was looking for.
The gratitude module has been noted.
"Ed Merks" <merks@ca.ibm.com> wrote in message
news:fj9g02$kpd$1@build.eclipse.org...
Daniel,
Comments below.
Daniel Tuohy wrote:
>Hello,
>Teneo?
I don't think so. In general SDO is just a candy coated wrapper around EMF.
It doesn't provide much of anything that can't be accomplished with EMF
directly. I'm not sure if the Teneo's design allows references to
EMF 2.4 also introduces a lot of greater flexibility in the URI converter to
The latter bugzilla even has a simple servlet attachment that I used to test
I think Teneo does exactly that. Eike Stepper's CDO/Net4J project does some
>with Teneo?
>for
Daniel Tuohy
Re: [Teneo] and SDO [message #104382 is a reply to message #104367] Thu, 06 December 2007 21:58 Go to previous message
Martin Taal is currently offline Martin TaalFriend
The only thing I want to Ed's answer is that for persisting certain parts outside of hibernate you
would probably need to use hibernate custom types. So yes, afaics it should be possible (never tried
it myself though).
gr. Martin
> Daniel,
> Comments below.
> Daniel Tuohy wrote:
>> Hello,
>> Teneo?
>> with Teneo?
>> for
> Daniel Tuohy
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: [Teneo] and SDO [message #612764 is a reply to message #104334] Thu, 06 December 2007 18:45 Go to previous message
Daniel,
Comments below.
Daniel Tuohy wrote:
> Hello,
> Teneo?
> with Teneo?
> Daniel Tuohy
<html>
<head>
</head>
Daniel,<br>
<br>
Comments below.<br>
<br>
<br>
<pre wrap="">Hello,
Teneo?
</pre>
</blockquote>
<br>
</a>
<blockquote><a
</blockquote>
</pre>
</blockquote>
with Teneo?
</pre>
</blockquote>
project.<br>
<pre wrap="">
</pre>
</blockquote>
</blockquote>
<pre wrap="">
Daniel Tuohy
</pre>
</blockquote>
<br>
</body>
</html>
Ed Merks
Re: [Teneo] and SDO [message #612766 is a reply to message #104360] Thu, 06 December 2007 18:55 Go to previous message
Member
Daniel,
Comments below.
Daniel Tuohy wrote:
>Hello,
>Teneo?
>with Teneo?
>for
Daniel Tuohy
Re: [Teneo] and SDO [message #612767 is a reply to message #104367] Thu, 06 December 2007 21:58 Go to previous message
it myself though).
gr. Martin
> Daniel,
> Comments below.
> Daniel Tuohy wrote:
>> Hello,
>> Teneo?
>> with Teneo?
>> for
> Daniel Tuohy
The Netherlands
Previous Topic:[Teneo] and SDO
Next Topic:Extending ECORE Model Editor Plugin
Current Time: Fri Oct 23 00:47:47 GMT 2020
Powered by FUDForum. Page generated in 0.02371 seconds
