Progress information Configuring GDB hangs [message #831861] |
Thu, 29 March 2012 13:03 |
Axel B Messages: 23 Registered: March 2012 |
my first try to use remote debugging via Eclipse Indigo is a desaster and i can't fix it.
The Basics:
I use a Cross Compiler Toolchain and have no problems to debug via network with my cross debugger on my devel-host and the counterpart gdbserver on my target. Up to this point -> no Trouble.
Now, i will use this with eclipse. I have read many tutorials about the configuration of such a debugging session. But when i try to start a session i get the Progress Information Widget and thats it. Pushing the Cancel button doesn't work. Only "Strg+C" is working. But this still closes eclipse completely.
I start eclipse out of an Linux Terminal with the correct Environment Variables set. Calling the gdb from this place is no Problem.
I get no error information in the terminal. Also when i Kill the Application with Strg+C
Is this a Bug or do i have missed some configurations? (Please ask when you need more information about my Debug conf settings)
Thanks in advance for any Hint!
Axel
Eclipse Build id: 20120216-1857
RSE 3.1.1
Running on a Ubuntu 10.04
[Updated on: Thu, 29 March 2012 14:03] Report message to a moderator
FUDForum. Page generated in 0.02347 seconds
