Home » Eclipse Projects » BIRT » What properties are passed to an IScriptFunctionExecutor in IScriptFunctionContext?
What properties are passed to an IScriptFunctionExecutor in IScriptFunctionContext? [message #831675] Thu, 29 March 2012 07:29 Go to next message
Alexey Romanov is currently offline Alexey RomanovFriend
IScriptFunctionExecutor.execute takes an IScriptFunctionContext, which is basically a Map of properties. Are the properties named by constants (FUNCITON_BEAN_NAME, LOCALE, TIMEZONE) always present? Can any others be passed?
Re: What properties are passed to an IScriptFunctionExecutor in IScriptFunctionContext? [message #832333 is a reply to message #831675] Fri, 30 March 2012 03:05 Go to previous messageGo to next message
Jason Weathersby is currently offline Jason WeathersbyFriend
Alexey
Currently these are the only ones in the code I believe.
Jason
> passed?
Re: What properties are passed to an IScriptFunctionExecutor in IScriptFunctionContext? [message #1005244 is a reply to message #832333] Thu, 24 January 2013 17:55 Go to previous messageGo to next message
Ronan Crowley is currently offline Ronan CrowleyFriend
How do I get parameters passed to the IScriptFunctionExecutor ?
I have set a Locale and a TimeZone on my Task (tried both Run & Render tasks).
And during execution I can see the IScriptFunctionExecutor only has a Locale Property, not a TimeZone.
How do I get the TimeZone property to appear ?
Ro
Re: What properties are passed to an IScriptFunctionExecutor in IScriptFunctionContext? [message #1005410 is a reply to message #1005244] Fri, 25 January 2013 10:22 Go to previous messageGo to next message
I found this is a bug.
Sad
Just created: https://bugs.eclipse.org/bugs/show_bug.cgi?id=399055
Re: What properties are passed to an IScriptFunctionExecutor in IScriptFunctionContext? [message #1005501 is a reply to message #1005410] Fri, 25 January 2013 17:32 Go to previous message
Ronan
I did not try it in the runtime but in the designer I get a TimeZone.
First I import
import com.ibm.icu.util.TimeZone;
I then added some local static variables to my executor class:
private IScriptFunctionExecutor executor;
private static TimeZone timeZone = null;
Then in the execute method I did this:
scriptContext = context;
if ( scriptContext != null )
timeZone = (TimeZone) scriptContext.findProperty( org.eclipse.birt.core.script.functionservice.IScriptFunctionContext.TIMEZONE );
Jason
Previous Topic:How to change style of Repeated Header
Next Topic:BIRT 3.7.1 and Java 7 support
Current Time: Wed Dec 08 19:29:23 GMT 2021
Powered by FUDForum. Page generated in 0.02024 seconds
