Re: task.setParameterValue [message #832187 is a reply to message #831603] |
Thu, 29 March 2012 22:02 |
The Date parameter should be able to take a java.sql or java.util date.
Can you post the complete stack trace?
Jason
On 3/29/2012 12:56 AM, Sergey Syr wrote:
> Interested moment
> thats void, continue..
> if (p.type.equals(Param.TYPE_DATE_TIME))
> { SimpleDateFormat formatter = new SimpleDateFormat("yyyy-MM-dd HH:mm");
> formatter.setLenient (false);
> try
> Date date = formatter.parse(p.value.replaceAll(p.value.substring(0, 10),
> Date2SQL(p.value.substring(0, 10))));
> task.setParameterValue(paramName,date);
> catch (Exception Ex)
> This fragment work!
> I see my changed DataTime parameter on report form
> p.value - String parameter value from enter form
> Date2SQL - formated String from "dd.MM.yyyy" to "yyyy-MM-dd"
> Date2SQL(p.value.substring(0, 10)))) - formated String from "dd.MM.yyyy
> HH:mm" to "yyyy-MM-dd HH:mm"
> what do you think about IScalarParameterDefn.TYPE_DATE ?
Re: task.setParameterValue [message #835714 is a reply to message #834654] |
Tue, 03 April 2012 15:28 |
Can you try opening the report and setting the parameter type as a Date
Time instead of a Date?
Jason
On 4/2/2012 4:13 AM, Sergey Syr wrote:
> Hello!
> task.run and...
> SEVERE:
> org.eclipse.birt.report.engine.api.impl.ParameterValidationException:
> The type of parameter "DateParameter" is expected as "date", not
> "java.util.Date".
> at
> org.eclipse.birt.report.engine.api.impl.EngineTask.validateParameterValueType(EngineTask.java:885)
> at
> org.eclipse.birt.report.engine.api.impl.EngineTask.validateAbstractScalarParameter(EngineTask.java:841)
> at
> org.eclipse.birt.report.engine.api.impl.EngineTask.access$0(EngineTask.java:768)
> at
> org.eclipse.birt.report.engine.api.impl.EngineTask$ParameterValidationVisitor.visitScalarParameter(EngineTask.java:698)
> at
> org.eclipse.birt.report.engine.api.impl.EngineTask$ParameterVisitor.visit(EngineTask.java:1432)
> at
> org.eclipse.birt.report.engine.api.impl.EngineTask.doValidateParameters(EngineTask.java:682)
> at
> org.eclipse.birt.report.engine.api.impl.RunAndRenderTask.doRun(RunAndRenderTask.java:94)
> at
> org.eclipse.birt.report.engine.api.impl.RunAndRenderTask.run(RunAndRenderTask.java:77)
> at com.mecheltrans.test_1.BirtReporter.BirtReport.run(BirtReport.java:319)
> at com.mecheltrans.test_1.BirtReporter.test.outReport(test.java:120)
> at com.mecheltrans.test_1.BirtReporter.test.processRequest(test.java:79)
> at com.mecheltrans.test_1.BirtReporter.test.doPost(test.java:33)
> at javax.servlet.http.HttpServlet.service(HttpServlet.java:754)
> at javax.servlet.http.HttpServlet.service(HttpServlet.java:847)
> at
> org.apache.catalina.core.StandardWrapper.service(StandardWrapper.java:1539)
> at
> org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:281)
> at
> org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:175)
> at
> org.apache.catalina.core.StandardPipeline.doInvoke(StandardPipeline.java:655)
> at
> org.apache.catalina.core.StandardPipeline.invoke(StandardPipeline.java:595)
> at com.sun.enterprise.web.WebPipeline.invoke(WebPipeline.java:98)
> at
> com.sun.enterprise.web.PESessionLockingStandardPipeline.invoke(PESessionLockingStandardPipeline.java:91)
> at
> org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:162)
> at
> org.apache.catalina.connector.CoyoteAdapter.doService(CoyoteAdapter.java:330)
> at
> org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:231)
> at
> com.sun.enterprise.v3.services.impl.ContainerMapper.service(ContainerMapper.java:174)
> at com.sun.grizzly.http.ProcessorTask.invokeAdapter(ProcessorTask.java:828)
> at com.sun.grizzly.http.ProcessorTask.doProcess(ProcessorTask.java:725)
> at com.sun.grizzly.http.ProcessorTask.process(ProcessorTask.java:1019)
> at
> com.sun.grizzly.http.DefaultProtocolFilter.execute(DefaultProtocolFilter.java:225)
> at
> com.sun.grizzly.DefaultProtocolChain.executeProtocolFilter(DefaultProtocolChain.java:137)
> at
> com.sun.grizzly.DefaultProtocolChain.execute(DefaultProtocolChain.java:104)
> at
> com.sun.grizzly.DefaultProtocolChain.execute(DefaultProtocolChain.java:90)
> at
> com.sun.grizzly.http.HttpProtocolChain.execute(HttpProtocolChain.java:79)
> at
> com.sun.grizzly.ProtocolChainContextTask.doCall(ProtocolChainContextTask.java:54)
> at
> com.sun.grizzly.SelectionKeyContextTask.call(SelectionKeyContextTask.java:59)
> at com.sun.grizzly.ContextTask.run(ContextTask.java:71)
> at
> com.sun.grizzly.util.AbstractThreadPool$Worker.doWork(AbstractThreadPool.java:532)
> at
> com.sun.grizzly.util.AbstractThreadPool$Worker.run(AbstractThreadPool.java:513)
> at java.lang.Thread.run(Thread.java:662)
> INFO: The type of parameter "DateParameter" is expected as "date", not
> "java.util.Date".
Re: task.setParameterValue [message #836124 is a reply to message #835714] |
Wed, 04 April 2012 05:08 |
Sergey Syr Messages: 19 Registered: February 2012 |
Junior Member |
DateTime type mismatching for Date parameter, because working another handler
DateTime type working totally normal.
SimpleDateFormat formatter = new SimpleDateFormat("dd.MM.yyyy HH:mm");
try
Date date = formatter.parse(p.value);
if (p.type.equals(Param.TYPE_DATE))
SimpleDateFormat formatter = new SimpleDateFormat("dd.MM.yyyy");
try
task.setParameterValue(paramName, date);
if (p.type.equals(Param.TYPE_DECIMAL))
Double n = Double.parseDouble(p.value.replace(',', '.'));
task.setParameterValue(paramName, n);
if (p.type.equals(Param.TYPE_INTEGER))
task.setParameterValue(paramName, (new Integer(p.value)));
//...etceteras, and so forth, and so on...
FUDForum. Page generated in 0.03736 seconds
