Home » Modeling » Modeling (top-level project) » [EMF][CDO][Hibernate] ClassCastException org.eclipse.emf.cdo.server.internal.hibernate.tuplizer.Hibe
[EMF][CDO][Hibernate] ClassCastException org.eclipse.emf.cdo.server.internal.hibernate.tuplizer.Hibe [message #831028] Wed, 28 March 2012 11:15 Go to next message
Kris Missing name is currently offline Kris Missing nameFriend
Member
in my model one class has an attribute, that is a list of enumerations.
The enumeration is defined with the standard emf EEnum and EEnumLiteral
elements.
When I create an instance of that class, add an Enum type to the
attribute list and then save it with CDO/Hibernate, I get the following
exception (see below).
Any idea whats the reason for this class cast exception?
Thanks & Regards
Kris
org.eclipse.emf.cdo.util.CommitException: Rollback in HibernateStore:
java.lang.ClassCastException:
org.eclipse.emf.cdo.server.internal.hibernate.tuplizer.HibernateMoveableListWrapper
cannot be cast to org.eclipse.emf.common.util.Enumerator
at
org.eclipse.emf.cdo.server.internal.hibernate.tuplizer.CDOENumStringType.nullSafeSet(CDOENumStringType.java:187)
at org.hibernate.type.CustomType.nullSafeSet(CustomType.java:140)
at
org.hibernate.persister.entity.AbstractEntityPersister.dehydrate(AbstractEntityPersister.java:2166)
at
org.hibernate.persister.entity.AbstractEntityPersister.dehydrate(AbstractEntityPersister.java:2143)
at
org.hibernate.persister.entity.AbstractEntityPersister$4.bindValues(AbstractEntityPersister.java:2321)
at
org.hibernate.id.insert.AbstractSelectingDelegate.performInsert(AbstractSelectingDelegate.java:56)
at
org.hibernate.persister.entity.AbstractEntityPersister.insert(AbstractEntityPersister.java:2327)
at
org.hibernate.persister.entity.AbstractEntityPersister.insert(AbstractEntityPersister.java:2834)
at
org.hibernate.action.EntityIdentityInsertAction.execute(EntityIdentityInsertAction.java:71)
at org.hibernate.engine.ActionQueue.execute(ActionQueue.java:273)
at
org.hibernate.event.def.AbstractSaveEventListener.performSaveOrReplicate(AbstractSaveEventListener.java:320)
at
org.hibernate.event.def.AbstractSaveEventListener.performSave(AbstractSaveEventListener.java:203)
at
org.hibernate.event.def.AbstractSaveEventListener.saveWithGeneratedId(AbstractSaveEventListener.java:129)
at
org.hibernate.event.def.DefaultSaveOrUpdateEventListener.saveWithGeneratedOrRequestedId(DefaultSaveOrUpdateEventListener.java:210)
at
org.hibernate.event.def.DefaultSaveOrUpdateEventListener.entityIsTransient(DefaultSaveOrUpdateEventListener.java:195)
at
org.hibernate.event.def.DefaultSaveOrUpdateEventListener.performSaveOrUpdate(DefaultSaveOrUpdateEventListener.java:117)
at
org.hibernate.event.def.DefaultSaveOrUpdateEventListener.onSaveOrUpdate(DefaultSaveOrUpdateEventListener.java:93)
at org.hibernate.impl.SessionImpl.fireSaveOrUpdate(SessionImpl.java:685)
at org.hibernate.impl.SessionImpl.saveOrUpdate(SessionImpl.java:677)
at
org.eclipse.emf.cdo.server.internal.hibernate.HibernateStoreAccessor.doWrite(HibernateStoreAccessor.java:683)
at
org.eclipse.emf.cdo.spi.server.StoreAccessorBase.write(StoreAccessorBase.java:150)
at
org.eclipse.emf.cdo.internal.server.TransactionCommitContext.write(TransactionCommitContext.java:463)
at
org.eclipse.emf.cdo.spi.server.InternalCommitContext$1.runLoop(InternalCommitContext.java:42)
at
org.eclipse.emf.cdo.spi.server.InternalCommitContext$1.runLoop(InternalCommitContext.java:1)
at
org.eclipse.net4j.util.om.monitor.ProgressDistributor.run(ProgressDistributor.java:96)
at
org.eclipse.emf.cdo.server.internal.net4j.protocol.CommitTransactionIndication.indicatingCommit(CommitTransactionIndication.java:244)
at
org.eclipse.emf.cdo.server.internal.net4j.protocol.CommitTransactionIndication.indicating(CommitTransactionIndication.java:92)
at
org.eclipse.emf.cdo.server.internal.net4j.protocol.CDOServerIndicationWithMonitoring.indicating(CDOServerIndicationWithMonitoring.java:109)
at
org.eclipse.net4j.signal.IndicationWithMonitoring.indicating(IndicationWithMonitoring.java:84)
at
org.eclipse.net4j.signal.IndicationWithResponse.doExtendedInput(IndicationWithResponse.java:90)
at org.eclipse.net4j.signal.Signal.doInput(Signal.java:326)
at
org.eclipse.net4j.signal.IndicationWithResponse.execute(IndicationWithResponse.java:63)
at
org.eclipse.net4j.signal.IndicationWithMonitoring.execute(IndicationWithMonitoring.java:63)
at org.eclipse.net4j.signal.Signal.runSync(Signal.java:251)
at org.eclipse.net4j.signal.Signal.run(Signal.java:147)
at
java.util.concurrent.ThreadPoolExecutor$Worker.runTask(ThreadPoolExecutor.java:886)
at
java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:908)
at java.lang.Thread.run(Thread.java:680)
at
com.foo.persistence.hibernate.impl.PersistenceManagerImpl.commit(PersistenceManagerImpl.java:205)
at
com.foo.persistence.hibernate.impl.PersistenceManagerImpl.saveSomeObject(PersistenceManagerImpl.java:101)
at
biz.foo.persistence.hibernate.impl.test.PersistenceManagerTest.testAddSomeObject(PersistenceManagerTest.java:109)
at
sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
at
sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
at junit.framework.TestCase.runTest(TestCase.java:168)
at junit.framework.TestCase.runBare(TestCase.java:134)
at junit.framework.TestResult$1.protect(TestResult.java:110)
at junit.framework.TestResult.runProtected(TestResult.java:128)
at junit.framework.TestResult.run(TestResult.java:113)
at junit.framework.TestCase.run(TestCase.java:124)
at junit.framework.TestSuite.runTest(TestSuite.java:243)
at junit.framework.TestSuite.run(TestSuite.java:238)
at
org.junit.internal.runners.JUnit38ClassRunner.run(JUnit38ClassRunner.java:83)
at
org.eclipse.jdt.internal.junit4.runner.JUnit4TestReference.run(JUnit4TestReference.java:50)
at
org.eclipse.jdt.internal.junit.runner.TestExecution.run(TestExecution.java:38)
at
org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.runTests(RemoteTestRunner.java:467)
at
org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.runTests(RemoteTestRunner.java:683)
at
org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.run(RemoteTestRunner.java:390)
at
org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.main(RemoteTestRunner.java:197)
Caused by: org.eclipse.emf.cdo.util.CommitException: Rollback in
HibernateStore: java.lang.ClassCastException:
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
org.eclipse.emf.internal.cdo.transaction.CDOSingleTransactionStrategyImpl.commit(CDOSingleTransactionStrategyImpl.java:94)
at
org.eclipse.emf.internal.cdo.transaction.CDOTransactionImpl.commit(CDOTransactionImpl.java:1069)
at
org.eclipse.emf.internal.cdo.transaction.CDOTransactionImpl.commit(CDOTransactionImpl.java:1089)
at
com.foo.persistence.hibernate.impl.PersistenceManagerImpl.commit(PersistenceManagerImpl.java:203)
... 21 more
Re: [EMF][CDO][Hibernate] ClassCastException org.eclipse.emf.cdo.server.internal.hibernate.tuplizer. [message #831071 is a reply to message #831028] Wed, 28 March 2012 12:33 Go to previous messageGo to next message
Kris,
Please use eclipse.tools.emf for asking questions about CDO.
On 28/03/2012 7:15 AM, KW wrote:
> enumerations. The enumeration is defined with the standard emf EEnum
> and EEnumLiteral elements.
> following exception (see below).
> Thanks & Regards
> Kris
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at java.lang.reflect.Method.invoke(Method.java:597)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 21 more
Ed Merks
Re: [EMF][CDO][Hibernate] ClassCastException org.eclipse.emf.cdo.server.internal.hibernate.tuplizer. [message #831925 is a reply to message #831071] Thu, 29 March 2012 14:25 Go to previous message
Member
Hi Ed,
OK, I reposted to the eclipse.tools.emf group.
Thanks & Regards
Kris
Am 3/28/12 2:33 PM, schrieb Ed Merks:
> Kris,
>> Hi,
>> Thanks & Regards
>> Kris
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> ... 21 more
Previous Topic:[EMF] [Teneo] [Hibernate] Reference on NON Primary Key
Next Topic:SysML and GMF -based domain specific modeling language
Current Time: Sat Jul 31 10:23:00 GMT 2021
Powered by FUDForum. Page generated in 0.01463 seconds
