Re: ClassCastException or ClassNotFoundException [message #103463 is a reply to message #103351] |
Sat, 07 July 2007 18:39 |
Alain Picard Messages: 266 Registered: July 2009 |
Eugene,
I ran many more tests to try to pinpoint the origin of the issue.
I started with a new install to see if our install method that relies on
the link/products directories could have anything to do with the issue.
Well, I am not getting the same behavior at all, except that it looks worse.
I have been getting this error whenever I 1st try to start a profiling
session:
Error occurred during initialization of VM
Could not find agent library on the library path or in the local
directory: JPIBootLoader
And now I just got another type of error:
The JVMTI agent org.eclipse.tptp.jvmti is not available. Make sure that
the librairies for the agent are available and that it is configured
properly.
I then tried to make some path changes and cleanup. This changed the
error messages, but it still kept failing.
I also tried running the sampleclient application, and that ran without
a glitch.
After all of this, I then downloaded the "all TPTP SDK" package and
overlaid it on my new install. After a clean restart, I have now stopped
getting any of the new errors and I am actually getting the exact same
errors as with my original install (ClassNotFoundException:
org.eclipse.hyades.logging.commons.FileLoggerFactory).
A couple more notes:
1) It seems that unless I do a connection test prior to launching the
profile launch, I get an error connecting to the agent.
2) Every time I start profile a launch configuration, it insist of doing
a "build before launch", even if I have just been running the same exact
launch config under debug seconds before. Furthermore, it is trying to
build other non-related workspace projects. Is that expected behavior?
Thanks for your help (I really need it here).
Alain
FUDForum. Page generated in 0.03818 seconds
