Home » Eclipse Projects » EclipseLink » Too long identifiers for oracle(Eclipselink sometimes generates too long identifiers)
Too long identifiers for oracle [message #830322] Tue, 27 March 2012 13:31 Go to next message
Ga'bor Pe'ntek is currently offline Ga'bor Pe'ntekFriend
Hi All,
is there a way to tell eclipselink not to generate longer identifiers than 30 characters on Oracle platform?
Gabor
Re: Too long identifiers for oracle [message #831311 is a reply to message #830322] Wed, 28 March 2012 18:45 Go to previous messageGo to next message
Chris Delahunt is currently offline Chris DelahuntFriend
Can you give an example where you see the identifier being used being too long? JPA requires that the defaults used match that attribute names in a particular way, so in some cases you may need to override the defaults to something more suitable.
Best Regards,
Chris
Re: Too long identifiers for oracle [message #832727 is a reply to message #831311] Fri, 30 March 2012 14:04 Go to previous messageGo to next message
@Entity
@Customizer(CMCHistoryCustomizer.class)
@Table(name = "CreditsCatalogueElement", schema="CMC")
@Inheritance(strategy = InheritanceType.JOINED)
@Index(columnNames = { "dtype" },name="INX_CrdCatalogueElmnt_dtype" )
public abstract class CreditsCatalogueElement extends CMCEntity {
Best Regards,
Gábor
Re: Too long identifiers for oracle [message #832825 is a reply to message #832727] Fri, 30 March 2012 16:26 Go to previous message
More information is needed to reproduce what you are seeing. Can you show what generated identifier is longer 30 characters?
Chris
Previous Topic:Validate against database schema
Next Topic:Problem with LEFT JOIN and long field
Current Time: Mon Jan 18 02:15:40 GMT 2021
Powered by FUDForum. Page generated in 0.01607 seconds
