Re: JNDI configuration for BIRT report designer [message #830772 is a reply to message #830084] |
Wed, 28 March 2012 03:19 |
I assume you do not want to use the connection profile mechanisms which
store the connection properties in a file. How do you read the jndi
properties in your current application. You should be able to write
similar code in the property binding expression for the data source.
Jason
On 3/27/2012 2:55 AM, Tony M wrote:
> Hi everyone,
> I am trying to configure a JNDI for my report design so it can
> dynamically load the database properties from a JNDI file (.xml
> extension) which is already been used by my application and deployed
> under jboss deploy directory.
> I am using BIRT RCP REPORT DESIGNER 3.7.1 and i have been trying to
> achieve this for over two days now.
> Any help would be appreciated guys
> Thanks a lot
> Tony
FUDForum. Page generated in 0.03140 seconds
