Home » Archived » M2M (model-to-model transformation) » [qvto]can I use an ocl operation as a model attribute
[qvto]can I use an ocl operation as a model attribute [message #829953] Tue, 27 March 2012 01:52 Go to next message
Allen Zhang is currently offline Allen ZhangFriend
When doing transformation, I may choose an element using ocl operations.
e.g. var s := source.objectsOfType(A)->select(i | i.name="name1")
But I want to define an element (e1) with an attribute (a1), may be a String ('source.objectsOfType(A)->select(i | i.name="name1")'),
so I can choose the elements like this:
var s := someOperation(e1.a1)
can I do this?Or is there some way?
Re: [qvto]can I use an ocl operation as a model attribute [message #829964 is a reply to message #829953] Tue, 27 March 2012 02:12 Go to previous messageGo to next message
The typos and vagueness in your question defeat me. Please try again.
Ed Willink
> operations. e.g. var s := source.objectsOfType(A)->select(i |
> i.name="name1")
> String ('source.objectsOfType(A)->select(i | i.name="name1")'), so I
> can choose the elements like this: var s := someOperation(e1.a1)
Re: [qvto]can I use an ocl operation as a model attribute [message #846534 is a reply to message #829964] Mon, 16 April 2012 06:31 Go to previous messageGo to next message
Hi, sorry about my poor English.
The question is:
when I write qvto transformation codes, I may need to select some elements.
such as: var element := a.select(i | i.name="name1");
But in this way, there is a limit that I can not dynamically set the condition: "i | i.name="name1".
I wander if I can set this condition in my source model, may be a String attribute.
so in the transformation, my codes will be like this:
var element := a.select(b.condition);
should I import ocl ecore in model b's metamodel, and set condition's type oclExpression?
Re: [qvto]can I use an ocl operation as a model attribute [message #846699 is a reply to message #846534] Mon, 16 April 2012 08:33 Go to previous message
Today: I don't think so. But the evolution of the OCL specification to
recognize iteration bodies as Lambda Expressions could allow it in the
future.
One possible workaround is to define a Predicate class and
select(OclAny) operation so that you can do
var element := aPredicate.select(a);
and pass alternate Predicate instances.
OCL currently has no ability to dynamically parse a Concrete Syntax
string, though I've raised an OMG issue to add support.
Ed Willink
> The question is:
> elements.
> String attribute.
> type oclExpression?
Previous Topic:Transformation failure
Next Topic:[ATL] programmatically launch of ATL transformation
Current Time: Sun Mar 29 23:06:25 GMT 2020
Powered by FUDForum. Page generated in 0.02791 seconds
