Home » Archived » Test and Performance Tools Platform (TPTP) » Re: ClassCastException in GenModel if org.eclipse.xsd is present
Re: ClassCastException in GenModel if org.eclipse.xsd is present [message #102290] |
Mon, 02 July 2007 16:35 |
Nicolas,
I'll add the TPTP newsgroup to the reply to see if anyone there knows a
reason why TPTP would affect the parser created via the standard JAXP
APIs, i.e., why SAXParserFactory.newInstance() should fail with TPTP
present.
Nicolas Cabanis wrote:
> And I use:
> java version "1.6.0"
> Java(TM) SE Runtime Environment (build 1.6.0-b105)
> Java HotSpot(TM) Client VM (build 1.6.0-b105, mixed mode)
> Nicolas Cabanis schrieb:
>> Hell Ed,
>> I use:
>> - eclipse-SDK-3.3 (and all following through Europa update site)
>> - TPTP Tracing and Profiling
>> - TPTP Platform (4.3.0v200706132116...)
>> - XSD (2.3.0v20070626000)
>> All I do is open a .genmodel file. But TPTP may be activted as it is
>> included in all perspectives.
>> I have just tried to activate XSD without TPTP - and it all works.
>> Nicolas
>> Ed Merks schrieb:
>>> Nicolas,
>>> I tried this locally with a slightly pre-GA setup without a
>>> problem. Do I need to use something in TPTP first before the
>>> problem starts to happen? I.e., does the problem happen with a
>>> freshly started Eclipse where all you've done is tried to open a
>>> .genmodel file as your first action?
>>> Ed Merks wrote:
>>>> Nicolas,
>>>> Sounds like some other component has registered an JAXP
>>>> implementation that's in conflict with the one provided by the JVM
>>>> because the code that's failing is just this standard pattern that
>>>> should work anywhere:
>>>> SAXParserFactory parserFactory=
>>>> SAXParserFactory.newInstance();
>>>> I know that XSD doesn't register such a thing, but perhaps TPTP's
>>>> use of this plugin causes a problem:
>>>> eclipse/plugins/org.apache.xerces_2.8.0.v200705301630.jar
>>>> If that is indeed the problem, I imagine that many things relying
>>>> on JAXP to simply work will be broken. Which JVM/JRE are you using?
>>>>> Hello,
>>>>> I have updated my Eclipse to 3.3 final together with EMF, GEF and
>>>>> GMF. Now, I get the following problem: if I open any genmodel with
>>>>> the GenModel-Editor, I get the exception appended at the end of
>>>>> this message. This only happens if I have TPTP (and therefore XSD)
>>>>> also in my configuration.
>>>>> How can I prevent this?
>>>>> Regards
>>>>> Nicolas
>>>>> java.lang.ClassCastException:
>>>>> org.apache.xerces.jaxp.SAXParserFactoryImpl cannot be cast to
>>>>> javax.xml.parsers.SAXParserFactory
>>>>> at javax.xml.parsers.SAXParserFactory.newInstance(Unknown Source)
>>>>> at
>>>>> org.eclipse.emf.ecore.plugin.EcorePlugin.computePlatformPlug inToPlatformResourceMap(EcorePlugin.java:302)
>>>>> at
>>>>> org.eclipse.emf.ecore.plugin.EcorePlugin.computePlatformURIM ap(EcorePlugin.java:409)
Re: ClassCastException in GenModel if org.eclipse.xsd is present [message #102344 is a reply to message #102290] |
Mon, 02 July 2007 19:26 |
Joe Toomey Messages: 79 Registered: July 2009 |
Member |
It's worth noting that although some committers may do informal testing,
TPTP does not yet support Java 6.
http://www.eclipse.org/tptp/home/project_info/releaseinfo/4. 4/support.html
I can't comment on why we distribute the org.apache.xerces bundle, but I
see that we (TPTP) require and reexport it in
org.eclipse.tptp.platform.models. Neither the plugin.xml file nor the
java code within our models plugin references or uses the
org.apache.xerces plugin. I will check with the plugin owner to
understand why this is the case -- I have a foggy recollection of why we
used to continue to ship xerces, but my recollection may be out of date.
I tried the scenario described using Sun 1.5 & 1.6 and also tried with
an IBM 1.6 JRE. I wasn't able to reproduce this issue (the genmodel
editor opened fine, no errors reported in the log.) I also checked in
the OSGI console, and in each case, the org.apache.xerces plugin was
resolved but not active after opening the genmodel file.
[I'm using Europa bits from today -- Eclipse Classic Windows download,
then TPTP installed via Update Manager. Among the required plugins
selected by UM were "EMF Runtime + End-User Tools 2.3.0.v200706262000"
and "XSD Schema Infoset Model 2.3.0.v200706262000".]
Ed -- are you able to see this error?
--Joe
Ed Merks wrote:
> Nicolas,
> present.
>> And I use:
>>> Hell Ed,
>>> I use:
>>> Nicolas
>>> Ed Merks schrieb:
>>>> Nicolas,
>>>> Ed Merks wrote:
>>>>> Nicolas,
>>>>>> Hello,
>>>>>> Regards
>>>>>> Nicolas
>>>>>> at
>>>>>> at
Re: ClassCastException in GenModel if org.eclipse.xsd is present [message #102353 is a reply to message #102344] |
Mon, 02 July 2007 19:29 |
Joe,
No. I have some bits slightly older than the GA version and it's all
working fine for me. I've never heard of a problem like this before
either. It's quite a basic/fundamental thing that's going wrong...
> testing, TPTP does not yet support Java 6.
> I see that we (TPTP) require and reexport it in
> we used to continue to ship xerces, but my recollection may be out of
> date.
> --Joe
> Ed Merks wrote:
>> Nicolas,
>> a reason why TPTP would affect the parser created via the standard
>> JAXP APIs, i.e., why SAXParserFactory.newInstance() should fail with
>> TPTP present.
>>> And I use:
>>>> Hell Ed,
>>>> I use:
>>>> is included in all perspectives.
>>>> Nicolas
>>>> Ed Merks schrieb:
>>>>> Nicolas,
>>>>> Ed Merks wrote:
>>>>>> Nicolas,
>>>>>> JVM because the code that's failing is just this standard pattern
>>>>>> that should work anywhere:
>>>>>>> Hello,
>>>>>>> and GMF. Now, I get the following problem: if I open any
>>>>>>> genmodel with the GenModel-Editor, I get the exception appended
>>>>>>> at the end of this message. This only happens if I have TPTP
>>>>>>> (and therefore XSD) also in my configuration.
>>>>>>> Regards
>>>>>>> Nicolas
>>>>>>> at
>>>>>>> at
Re: ClassCastException in GenModel if org.eclipse.xsd is present [message #102377 is a reply to message #102353] |
Mon, 02 July 2007 20:26 |
Member |
Agreed. I'm not sure how/if we're involved, but if we can figure out
how to reproduce the problem, I'll be happy to investigate on the TPTP side.
--Joe
Ed Merks wrote:
> Joe,
>> date.
>> Thanks,
>> --Joe
>> Ed Merks wrote:
>>> Nicolas,
>>> TPTP present.
>>>> And I use:
>>>>> Hell Ed,
>>>>> I use:
>>>>> Nicolas
>>>>> Ed Merks schrieb:
>>>>>> Nicolas,
>>>>>> Ed Merks wrote:
>>>>>>> Nicolas,
>>>>>>>> Hello,
>>>>>>>> Regards
>>>>>>>> Nicolas
>>>>>>>> at
>>>>>>>> at
Re: ClassCastException in GenModel if org.eclipse.xsd is present [message #102585 is a reply to message #102377] |
Tue, 03 July 2007 13:33 |
Miles Parker Messages: 1341 Registered: July 2009 |
As a btw, I think JAXP / Xerces related incompatabilites, especially
given their "fail-slow" nature, create painful issues in intergrating
various projects. The same kinds of things have come up w/ oAW, e.g.:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=186687
> side.
> --Joe
> Ed Merks wrote:
>> Joe,
I
>>> date.
>>> Thanks,
>>> --Joe
>>> Ed Merks wrote:
>>>> Nicolas,
>>>> present.
>>>>> And I use:
>>>>>> Hell Ed,
>>>>>> I use:
>>>>>> Nicolas
>>>>>> Ed Merks schrieb:
>>>>>>> Nicolas,
>>>>>>> I tried this locally with a slightly pre-GA setup without a problem.
>>>>>>> Do I need to use something in TPTP first before the problem starts to
>>>>>>> happen? I.e., does the problem happen with a freshly started Eclipse
>>>>>>> where all you've done is tried to open a .genmodel file as your first
>>>>>>> action?
>>>>>>> Ed Merks wrote:
>>>>>>>> Nicolas,
>>>>>>>> Sounds like some other component has registered an JAXP implementation
>>>>>>>> that's in conflict with the one provided by the JVM because the code
>>>>>>>> that's failing is just this standard pattern that should work anywhere:
>>>>>>>> SAXParserFactory parserFactory= SAXParserFactory.newInstance();
>>>>>>>> I know that XSD doesn't register such a thing, but perhaps TPTP's use
>>>>>>>> If that is indeed the problem, I imagine that many things relying on
>>>>>>>>> Hello,
>>>>>>>>> I have updated my Eclipse to 3.3 final together with EMF, GEF and GMF.
>>>>>>>>> Now, I get the following problem: if I open any genmodel with the
>>>>>>>>> GenModel-Editor, I get the exception appended at the end of this
>>>>>>>>> message. This only happens if I have TPTP (and therefore XSD) also in
>>>>>>>>> my configuration.
>>>>>>>>> Regards
>>>>>>>>> Nicolas
>>>>>>>>> at
>>>>>>>>> at
Current Time: Thu Apr 25 19:57:11 GMT 2024
Powered by FUDForum. Page generated in 0.03360 seconds
