Stereotype Problems [message #827812] |
Fri, 23 March 2012 20:38  |
Daniel Riquelme Messages: 2 Registered: March 2012 Location: Chile |
I am working with a model that is extended by a custom Profile. The model has some classes and properties that are stereotyped. When I open the model in Topcased the stereotypes are shown. But when I call "getAppliedStereotypes" from an acceleo template the result is always null.
I figured I could find something by debugging the uml classes, but I only found that when the model is loaded from acceleo the methods that return the stereotypes i.e.: getNonNavigableInverseReferences always return null.
But when the model is loaded from the uml editor this methods will return as expected.
The only noticeable difference with both scenarios is that the URIs for the model an profile are absolute when loaded from acceleo and relative when loaded from the uml editor.
I'm lost here and I found no evidence of other people having this problem so I guess I'm missing something pretty simple.
Any ideas ?
Model
<xmi:XMI xmi:version="2.1" xmlns:xmi="hhttpp://schema.omg.org/spec/XMI/2.1" xmlns:xsi="hhttpp://www.w3.org/2001/XMLSchema-instance" xmlns:ecore="hhttpp://www.eclipse.org/emf/2002/Ecore" xmlns:ofbizprofile="hhttpp:///schemas/ofbizprofile/_6D428HTwEeGwJIM2VpnDkA/11" xmlns:uml="hhttpp://www.eclipse.org/uml2/3.0.0/UML" xsi:schemaLocation="hhttpp:///schemas/ofbizprofile/_6D428HTwEeGwJIM2VpnDkA/11 ../RIABCommon/modelo/ofbiz.profile.uml#_6OOesHTwEeGwJIM2VpnDkA">
<uml:Model xmi:id="_qb8akM37EdqwVrslYOdUDA">
<packagedElement xmi:type="uml:Package" xmi:id="_w8IxIM37EdqwVrslYOdUDA" name="modelo">
<packagedElement xmi:type="uml:Class" xmi:id="_jcSlwHQxEeG9UItNWMxIQw" name="Factura">
<ownedAttribute xmi:id="_ygvcYHQxEeG9UItNWMxIQw" name="facturaId"/>
<ownedAttribute xmi:id="_B5ApEHRBEeGzbokFXp-YXA" name="casoId"/>
<ownedAttribute xmi:id="_CwuyoHTuEeGwJIM2VpnDkA" name="numeroFactura" type="_uPnjYHULEeGwJIM2VpnDkA"/>
<ownedAttribute xmi:id="_EsVjsHTuEeGwJIM2VpnDkA" name="fechaEmision">
<type xmi:type="uml:PrimitiveType" href="../RIABCommon/modelo/ofbiz.profile.uml#_xNA84HTwEeGwJIM2VpnDkA"/>
</ownedAttribute>
<ownedAttribute xmi:id="_GGyvgHTuEeGwJIM2VpnDkA" name="fechaVencimiento">
</ownedAttribute>
<ownedAttribute xmi:id="_Ogb7AHTuEeGwJIM2VpnDkA" name="statusId"/>
<ownedAttribute xmi:id="_do8yQHTuEeGwJIM2VpnDkA" name="materiaId"/>
<ownedAttribute xmi:id="_fcLqcHTuEeGwJIM2VpnDkA" name="clienteId"/>
<ownedAttribute xmi:id="_giADAHTuEeGwJIM2VpnDkA" name="deudorId"/>
<ownedAttribute xmi:id="_hgqqsHTuEeGwJIM2VpnDkA" name="direccion"/>
<ownedAttribute xmi:id="_ivOvkHTuEeGwJIM2VpnDkA" name="paisId"/>
<ownedAttribute xmi:id="_jxwjkHTuEeGwJIM2VpnDkA" name="comunaId"/>
<ownedAttribute xmi:id="_ySrPUHTuEeGwJIM2VpnDkA" name="regionId"/>
<ownedAttribute xmi:id="_zqIxgHTuEeGwJIM2VpnDkA" name="ciudad"/>
<ownedAttribute xmi:id="_0k6XsHTuEeGwJIM2VpnDkA" name="montoBruto"/>
<ownedAttribute xmi:id="_1X_acHTuEeGwJIM2VpnDkA" name="interesMora"/>
<ownedAttribute xmi:id="_24HwcHTuEeGwJIM2VpnDkA" name="gastosCobranza"/>
<ownedAttribute xmi:id="_4CdcoHTuEeGwJIM2VpnDkA" name="totalAdeudado"/>
<ownedAttribute xmi:id="_6WOPAHTuEeGwJIM2VpnDkA" name="observaciones"/>
</packagedElement>
<packagedElement xmi:type="uml:Class" xmi:id="_cMK1wHTvEeGwJIM2VpnDkA" name="Caso">
<ownedAttribute xmi:id="_c-AiYHTvEeGwJIM2VpnDkA" name="casoId"/>
<ownedAttribute xmi:id="_egKRoHTvEeGwJIM2VpnDkA" name="fecha"/>
<ownedAttribute xmi:id="_fSgUkHTvEeGwJIM2VpnDkA" name="statusId"/>
<ownedAttribute xmi:id="_gFq24HTvEeGwJIM2VpnDkA" name="tipoCasoId"/>
<ownedAttribute xmi:id="_g7wKUHTvEeGwJIM2VpnDkA" name="ramoId"/>
<ownedAttribute xmi:id="_hzUrgHTvEeGwJIM2VpnDkA" name="createdByUserLogin"/>
<ownedAttribute xmi:id="_mRDbEHTvEeGwJIM2VpnDkA" name="numeroReferencia"/>
<ownedAttribute xmi:id="_nWeLAHTvEeGwJIM2VpnDkA" name="clienteId"/>
</packagedElement>
<packagedElement xmi:type="uml:PrimitiveType" xmi:id="_uPnjYHULEeGwJIM2VpnDkA" name="String"/>
<profileApplication xmi:id="_vVlvAHQxEeG9UItNWMxIQw">
<eAnnotations xmi:id="_vVoyUHQxEeG9UItNWMxIQw" source="hhttpp://www.eclipse.org/uml2/2.0.0/UML">
<references xmi:type="ecore:EPackage" href="../RIABCommon/modelo/ofbiz.profile.uml#_6OOesHTwEeGwJIM2VpnDkA"/>
</eAnnotations>
<appliedProfile href="../RIABCommon/modelo/ofbiz.profile.uml#_XkGiwB07Ed-QQ4mYkrb7Gg"/>
</profileApplication>
</packagedElement>
</uml:Model>
<ofbizprofile:Entity xmi:id="_wTEq8HQxEeG9UItNWMxIQw" base_Class="_jcSlwHQxEeG9UItNWMxIQw"/>
<ofbizprofile:Field xmi:id="_-_SOcHQ2EeG9UItNWMxIQw" base_Property="_ygvcYHQxEeG9UItNWMxIQw"/>
<ofbizprofile:PrimKey xmi:id="_ATRaUHRBEeGzbokFXp-YXA" base_Property="_ygvcYHQxEeG9UItNWMxIQw"/>
<ofbizprofile:Field xmi:id="_Dek4sHRBEeGzbokFXp-YXA" type="id-ne" base_Property="_B5ApEHRBEeGzbokFXp-YXA"/>
<ofbizprofile:Entity xmi:id="_pJavUHTvEeGwJIM2VpnDkA" base_Class="_cMK1wHTvEeGwJIM2VpnDkA"/>
<ofbizprofile:Field xmi:id="_kkeIAHTwEeGwJIM2VpnDkA" base_Property="_CwuyoHTuEeGwJIM2VpnDkA"/>
<ofbizprofile:Field xmi:id="_rQCoIHTwEeGwJIM2VpnDkA" base_Property="_EsVjsHTuEeGwJIM2VpnDkA"/>
<ofbizprofile:Field xmi:id="_F8dAYHTxEeGwJIM2VpnDkA" base_Property="_GGyvgHTuEeGwJIM2VpnDkA"/>
</xmi:XMI>
Profile
[code]
<uml:Profile xmi:version="2.1" xmlns:xmi="hhttpp://schema.omg.org/spec/XMI/2.1" xmlns:ecore="hhttpp://www.eclipse.org/emf/2002/Ecore" xmlns:uml="hhttpp://www.eclipse.org/uml2/3.0.0/UML" xmi:id="_XkGiwB07Ed-QQ4mYkrb7Gg" name="ofbiz.profile">
<eAnnotations xmi:id="_31haoHQvEeG9UItNWMxIQw" source="hhttpp://www.eclipse.org/uml2/2.0.0/UML">
<contents xmi:type="ecore:EPackage" xmi:id="_6OOesHTwEeGwJIM2VpnDkA" name="ofbizprofile" nsURI="hhttpp:///schemas/ofbizprofile/_6D428HTwEeGwJIM2VpnDkA/11" nsPrefix="ofbizprofile">
<eClassifiers xmi:type="ecore:EClass" xmi:id="_6OOesXTwEeGwJIM2VpnDkA" name="Entity">
<eAnnotations xmi:id="_6OOesnTwEeGwJIM2VpnDkA" source="hhttpp://www.eclipse.org/uml2/2.0.0/UML" references="_WpbCIHQvEeG9UItNWMxIQw"/>
<eStructuralFeatures xmi:type="ecore:EAttribute" xmi:id="_6OOes3TwEeGwJIM2VpnDkA" name="entityname" ordered="false" lowerBound="1">
<eType xmi:type="ecore:EDataType" href="hhttpp://www.eclipse.org/emf/2002/Ecore#//EString"/>
</eStructuralFeatures>
<eStructuralFeatures xmi:type="ecore:EAttribute" xmi:id="_6OOetXTwEeGwJIM2VpnDkA" name="tablename" ordered="false" lowerBound="1">
<eStructuralFeatures xmi:type="ecore:EAttribute" xmi:id="_6OOet3TwEeGwJIM2VpnDkA" name="packagename" ordered="false" lowerBound="1">
<eStructuralFeatures xmi:type="ecore:EReference" xmi:id="_6OOeuXTwEeGwJIM2VpnDkA" name="base_Class" ordered="false" lowerBound="1">
<eType xmi:type="ecore:EClass" href="hhttpp://www.eclipse.org/uml2/3.0.0/UML#//Class"/>
</eClassifiers>
<eClassifiers xmi:type="ecore:EClass" xmi:id="_6OOeu3TwEeGwJIM2VpnDkA" name="Field">
<eAnnotations xmi:id="_6OOevHTwEeGwJIM2VpnDkA" source="hhttpp://www.eclipse.org/uml2/2.0.0/UML" references="_AkdgsHQwEeG9UItNWMxIQw"/>
<eStructuralFeatures xmi:type="ecore:EAttribute" xmi:id="_6OOevXTwEeGwJIM2VpnDkA" name="name" ordered="false" lowerBound="1">
<eStructuralFeatures xmi:type="ecore:EAttribute" xmi:id="_6OOev3TwEeGwJIM2VpnDkA" name="type" ordered="false" lowerBound="1">
<eStructuralFeatures xmi:type="ecore:EAttribute" xmi:id="_6OOewXTwEeGwJIM2VpnDkA" name="enableauditlog" ordered="false" lowerBound="1">
<eType xmi:type="ecore:EDataType" href="hhttpp://www.eclipse.org/emf/2002/Ecore#//EBoolean"/>
<eStructuralFeatures xmi:type="ecore:EAttribute" xmi:id="_6OOew3TwEeGwJIM2VpnDkA" name="notnull" ordered="false" lowerBound="1">
<eStructuralFeatures xmi:type="ecore:EReference" xmi:id="_6OOexXTwEeGwJIM2VpnDkA" name="base_Property" ordered="false" lowerBound="1">
<eType xmi:type="ecore:EClass" href="hhttpp://www.eclipse.org/uml2/3.0.0/UML#//Property"/>
</eClassifiers>
<eClassifiers xmi:type="ecore:EClass" xmi:id="_6OOex3TwEeGwJIM2VpnDkA" name="PrimKey">
<eAnnotations xmi:id="_6OOeyHTwEeGwJIM2VpnDkA" source="hhttpp://www.eclipse.org/uml2/2.0.0/UML" references="_cQeigHQ1EeG9UItNWMxIQw"/>
<eStructuralFeatures xmi:type="ecore:EAttribute" xmi:id="_6OOeyXTwEeGwJIM2VpnDkA" name="field" ordered="false" lowerBound="1">
<eStructuralFeatures xmi:type="ecore:EReference" xmi:id="_6OOey3TwEeGwJIM2VpnDkA" name="base_Property" ordered="false" lowerBound="1">
</eClassifiers>
<eClassifiers xmi:type="ecore:EDataType" xmi:id="_6OOezXTwEeGwJIM2VpnDkA" name="DateTime" instanceClassName="DateTime">
<eAnnotations xmi:id="_6OOeznTwEeGwJIM2VpnDkA" source="hhttpp://www.eclipse.org/uml2/2.0.0/UML" references="_xNA84HTwEeGwJIM2VpnDkA"/>
</eClassifiers>
<eClassifiers xmi:type="ecore:EDataType" xmi:id="_6OOez3TwEeGwJIM2VpnDkA" name="Description" instanceClassName="Description">
<eAnnotations xmi:id="_6OOe0HTwEeGwJIM2VpnDkA" source="hhttpp://www.eclipse.org/uml2/2.0.0/UML" references="_1oYU8HTwEeGwJIM2VpnDkA"/>
</eClassifiers>
<eClassifiers xmi:type="ecore:EDataType" xmi:id="_6OOe0XTwEeGwJIM2VpnDkA" name="CurrencyAmount" instanceClassName="CurrencyAmount">
<eAnnotations xmi:id="_6OOe0nTwEeGwJIM2VpnDkA" source="hhttpp://www.eclipse.org/uml2/2.0.0/UML" references="_4j_KcHTwEeGwJIM2VpnDkA"/>
</eClassifiers>
</contents>
<contents xmi:type="ecore:EPackage" xmi:id="_3LaNAXQ3EeG9UItNWMxIQw" name="ofbizprofile" nsURI="hhttpp:///schemas/ofbizprofile/_3LaNAHQ3EeG9UItNWMxIQw/10" nsPrefix="ofbizprofile">
<eClassifiers xmi:type="ecore:EClass" xmi:id="_3LaNAnQ3EeG9UItNWMxIQw" name="Entity">
<eAnnotations xmi:id="_3LaNA3Q3EeG9UItNWMxIQw" source="hhttpp://www.eclipse.org/uml2/2.0.0/UML" references="_WpbCIHQvEeG9UItNWMxIQw"/>
<eStructuralFeatures xmi:type="ecore:EAttribute" xmi:id="_3LaNBHQ3EeG9UItNWMxIQw" name="entityname" ordered="false" lowerBound="1">
<eStructuralFeatures xmi:type="ecore:EAttribute" xmi:id="_3LaNBnQ3EeG9UItNWMxIQw" name="tablename" ordered="false" lowerBound="1">
<eStructuralFeatures xmi:type="ecore:EAttribute" xmi:id="_3LaNCHQ3EeG9UItNWMxIQw" name="packagename" ordered="false" lowerBound="1">
<eStructuralFeatures xmi:type="ecore:EReference" xmi:id="_3LaNCnQ3EeG9UItNWMxIQw" name="base_Class" ordered="false" lowerBound="1">
</eClassifiers>
<eClassifiers xmi:type="ecore:EClass" xmi:id="_3LaNDHQ3EeG9UItNWMxIQw" name="Field">
<eAnnotations xmi:id="_3LaNDXQ3EeG9UItNWMxIQw" source="hhttpp://www.eclipse.org/uml2/2.0.0/UML" references="_AkdgsHQwEeG9UItNWMxIQw"/>
<eStructuralFeatures xmi:type="ecore:EAttribute" xmi:id="_3LaNDnQ3EeG9UItNWMxIQw" name="name" ordered="false" lowerBound="1">
<eStructuralFeatures xmi:type="ecore:EAttribute" xmi:id="_3LaNEHQ3EeG9UItNWMxIQw" name="type" ordered="false" lowerBound="1">
<eStructuralFeatures xmi:type="ecore:EAttribute" xmi:id="_3LaNEnQ3EeG9UItNWMxIQw" name="enableauditlog" ordered="false" lowerBound="1">
<eStructuralFeatures xmi:type="ecore:EAttribute" xmi:id="_3LaNFHQ3EeG9UItNWMxIQw" name="notnull" ordered="false" lowerBound="1">
<eStructuralFeatures xmi:type="ecore:EReference" xmi:id="_3LaNFnQ3EeG9UItNWMxIQw" name="base_Property" ordered="false" lowerBound="1">
</eClassifiers>
<eClassifiers xmi:type="ecore:EClass" xmi:id="_3LaNGHQ3EeG9UItNWMxIQw" name="PrimKey">
<eAnnotations xmi:id="_3LaNGXQ3EeG9UItNWMxIQw" source="hhttpp://www.eclipse.org/uml2/2.0.0/UML" references="_cQeigHQ1EeG9UItNWMxIQw"/>
<eStructuralFeatures xmi:type="ecore:EAttribute" xmi:id="_3LaNGnQ3EeG9UItNWMxIQw" name="field" ordered="false" lowerBound="1">
<eStructuralFeatures xmi:type="ecore:EReference" xmi:id="_3LaNHHQ3EeG9UItNWMxIQw" name="base_Property" ordered="false" lowerBound="1">
</eClassifiers>
</contents>
<contents xmi:type="ecore:EPackage" xmi:id="_23XPoXQ3EeG9UItNWMxIQw" name="ofbizprofile" nsURI="hhttpp:///schemas/ofbizprofile/_23XPoHQ3EeG9UItNWMxIQw/9" nsPrefix="ofbizprofile">
<eClassifiers xmi:type="ecore:EClass" xmi:id="_23XPonQ3EeG9UItNWMxIQw" name="Entity">
<eAnnotations xmi:id="_23XPo3Q3EeG9UItNWMxIQw" source="hhttpp://www.eclipse.org/uml2/2.0.0/UML" references="_WpbCIHQvEeG9UItNWMxIQw"/>
<eStructuralFeatures xmi:type="ecore:EAttribute" xmi:id="_23XPpHQ3EeG9UItNWMxIQw" name="entityname" ordered="false" lowerBound="1">
<eStructuralFeatures xmi:type="ecore:EAttribute" xmi:id="_23XPpnQ3EeG9UItNWMxIQw" name="tablename" ordered="false" lowerBound="1">
<eStructuralFeatures xmi:type="ecore:EAttribute" xmi:id="_23XPqHQ3EeG9UItNWMxIQw" name="packagename" ordered="false" lowerBound="1">
<eStructuralFeatures xmi:type="ecore:EReference" xmi:id="_23XPqnQ3EeG9UItNWMxIQw" name="base_Class" ordered="false" lowerBound="1">
</eClassifiers>
<eClassifiers xmi:type="ecore:EClass" xmi:id="_23XPrHQ3EeG9UItNWMxIQw" name="Field">
<eAnnotations xmi:id="_23XPrXQ3EeG9UItNWMxIQw" source="hhttpp://www.eclipse.org/uml2/2.0.0/UML" references="_AkdgsHQwEeG9UItNWMxIQw"/>
<eStructuralFeatures xmi:type="ecore:EAttribute" xmi:id="_23XPrnQ3EeG9UItNWMxIQw" name="name" ordered="false" lowerBound="1">
<eStructuralFeatures xmi:type="ecore:EAttribute" xmi:id="_23XPsHQ3EeG9UItNWMxIQw" name="type" ordered="false" lowerBound="1">
<eStructuralFeatures xmi:type="ecore:EAttribute" xmi:id="_23XPsnQ3EeG9UItNWMxIQw" name="enableauditlog" ordered="false" lowerBound="1">
<eStructuralFeatures xmi:type="ecore:EAttribute" xmi:id="_23XPtHQ3EeG9UItNWMxIQw" name="notnull" ordered="false" lowerBound="1">
<eStructuralFeatures xmi:type="ecore:EReference" xmi:id="_23XPtnQ3EeG9UItNWMxIQw" name="base_Property" ordered="false" lowerBound="1">
</eClassifiers>
<eClassifiers xmi:type="ecore:EClass" xmi:id="_23XPuHQ3EeG9UItNWMxIQw" name="PrimKey">
<eAnnotations xmi:id="_23XPuXQ3EeG9UItNWMxIQw" source="hhttpp://www.eclipse.org/uml2/2.0.0/UML" references="_cQeigHQ1EeG9UItNWMxIQw"/>
<eStructuralFeatures xmi:type="ecore:EAttribute" xmi:id="_23XPunQ3EeG9UItNWMxIQw" name="field" ordered="false" lowerBound="1">
<eStructuralFeatures xmi:type="ecore:EReference" xmi:id="_23XPvHQ3EeG9UItNWMxIQw" name="base_Property" ordered="false" lowerBound="1">
</eClassifiers>
</contents>
<contents xmi:type="ecore:EPackage" xmi:id="_0-9jkXQ3EeG9UItNWMxIQw" name="ofbizprofile" nsURI="hhttpp:///schemas/ofbizprofile/_0-9jkHQ3EeG9UItNWMxIQw/8" nsPrefix="ofbizprofile">
<eClassifiers xmi:type="ecore:EClass" xmi:id="_0-9jknQ3EeG9UItNWMxIQw" name="Entity">
<eAnnotations xmi:id="_0-9jk3Q3EeG9UItNWMxIQw" source="hhttpp://www.eclipse.org/uml2/2.0.0/UML" references="_WpbCIHQvEeG9UItNWMxIQw"/>
<eStructuralFeatures xmi:type="ecore:EAttribute" xmi:id="_0-9jlHQ3EeG9UItNWMxIQw" name="entityname" ordered="false" lowerBound="1">
<eStructuralFeatures xmi:type="ecore:EAttribute" xmi:id="_0-9jlnQ3EeG9UItNWMxIQw" name="tablename" ordered="false" lowerBound="1">
<eStructuralFeatures xmi:type="ecore:EAttribute" xmi:id="_0-9jmHQ3EeG9UItNWMxIQw" name="packagename" ordered="false" lowerBound="1">
<eStructuralFeatures xmi:type="ecore:EReference" xmi:id="_0-9jmnQ3EeG9UItNWMxIQw" name="base_Class" ordered="false" lowerBound="1">
</eClassifiers>
<eClassifiers xmi:type="ecore:EClass" xmi:id="_0-9jnHQ3EeG9UItNWMxIQw" name="Field">
<eAnnotations xmi:id="_0-9jnXQ3EeG9UItNWMxIQw" source="hhttpp://www.eclipse.org/uml2/2.0.0/UML" references="_AkdgsHQwEeG9UItNWMxIQw"/>
<eStructuralFeatures xmi:type="ecore:EAttribute" xmi:id="_0-9jnnQ3EeG9UItNWMxIQw" name="name" ordered="false" lowerBound="1">
<eStructuralFeatures xmi:type="ecore:EAttribute" xmi:id="_0-9joHQ3EeG9UItNWMxIQw" name="type" ordered="false" lowerBound="1">
<eStructuralFeatures xmi:type="ecore:EAttribute" xmi:id="_0-9jonQ3EeG9UItNWMxIQw" name="enableauditlog" ordered="false" lowerBound="1">
<eStructuralFeatures xmi:type="ecore:EAttribute" xmi:id="_0-9jpHQ3EeG9UItNWMxIQw" name="notnull" ordered="false" lowerBound="1">
<eStructuralFeatures xmi:type="ecore:EReference" xmi:id="_0-9jpnQ3EeG9UItNWMxIQw" name="base_Property" ordered="false" lowerBound="1">
</eClassifiers>
<eClassifiers xmi:type="ecore:EClass" xmi:id="_0-9jqHQ3EeG9UItNWMxIQw" name="PrimKey">
<eAnnotations xmi:id="_0-9jqXQ3EeG9UItNWMxIQw" source="hhttpp://www.eclipse.org/uml2/2.0.0/UML" references="_cQeigHQ1EeG9UItNWMxIQw"/>
<eStructuralFeatures xmi:type="ecore:EAttribute" xmi:id="_0-9jqnQ3EeG9UItNWMxIQw" name="field" ordered="false" lowerBound="1">
<eStructuralFeatures xmi:type="ecore:EReference" xmi:id="_0-9jrHQ3EeG9UItNWMxIQw" name="base_Property" ordered="false" lowerBound="1">
</eClassifiers>
</contents>
<contents xmi:type="ecore:EPackage" xmi:id="_lyW2gXQ3EeG9UItNWMxIQw" name="ofbizprofile" nsURI="hhttpp:///schemas/ofbizprofile/_lyW2gHQ3EeG9UItNWMxIQw/7" nsPrefix="ofbizprofile">
<eClassifiers xmi:type="ecore:EClass" xmi:id="_lyW2gnQ3EeG9UItNWMxIQw" name="Entity">
<eAnnotations xmi:id="_lyW2g3Q3EeG9UItNWMxIQw" source="hhttpp://www.eclipse.org/uml2/2.0.0/UML" references="_WpbCIHQvEeG9UItNWMxIQw"/>
<eStructuralFeatures xmi:type="ecore:EAttribute" xmi:id="_lyW2hHQ3EeG9UItNWMxIQw" name="entityname" ordered="false" lowerBound="1">
<eStructuralFeatures xmi:type="ecore:EAttribute" xmi:id="_lyW2hnQ3EeG9UItNWMxIQw" name="tablename" ordered="false" lowerBound="1">
<eStructuralFeatures xmi:type="ecore:EAttribute" xmi:id="_lyW2iHQ3EeG9UItNWMxIQw" name="packagename" ordered="false" lowerBound="1">
<eStructuralFeatures xmi:type="ecore:EReference" xmi:id="_lyW2inQ3EeG9UItNWMxIQw" name="base_Class" ordered="false" lowerBound="1">
</eClassifiers>
<eClassifiers xmi:type="ecore:EClass" xmi:id="_lyW2jHQ3EeG9UItNWMxIQw" name="Field">
<eAnnotations xmi:id="_lyW2jXQ3EeG9UItNWMxIQw" source="hhttpp://www.eclipse.org/uml2/2.0.0/UML" references="_AkdgsHQwEeG9UItNWMxIQw"/>
<eStructuralFeatures xmi:type="ecore:EAttribute" xmi:id="_lyW2jnQ3EeG9UItNWMxIQw" name="name" ordered="false" lowerBound="1">
<eStructuralFeatures xmi:type="ecore:EAttribute" xmi:id="_lyW2kHQ3EeG9UItNWMxIQw" name="type" ordered="false" lowerBound="1">
<eStructuralFeatures xmi:type="ecore:EAttribute" xmi:id="_lyW2knQ3EeG9UItNWMxIQw" name="enableauditlog" ordered="false" lowerBound="1">
<eStructuralFeatures xmi:type="ecore:EAttribute" xmi:id="_lyW2lHQ3EeG9UItNWMxIQw" name="notnull" ordered="false" lowerBound="1">
<eStructuralFeatures xmi:type="ecore:EReference" xmi:id="_lyW2lnQ3EeG9UItNWMxIQw" name="base_Property" ordered="false" lowerBound="1">
</eClassifiers>
<eClassifiers xmi:type="ecore:EClass" xmi:id="_lyW2mHQ3EeG9UItNWMxIQw" name="PrimKey">
<eAnnotations xmi:id="_lyW2mXQ3EeG9UItNWMxIQw" source="hhttpp://www.eclipse.org/uml2/2.0.0/UML" references="_cQeigHQ1EeG9UItNWMxIQw"/>
<eAnnotations xmi:id="_lyW2mnQ3EeG9UItNWMxIQw" source="duplicates">
<contents xmi:type="ecore:EReference" xmi:id="_lyW2m3Q3EeG9UItNWMxIQw" name="base_Property" ordered="false" lowerBound="1">
<eAnnotations xmi:id="_lyW2nHQ3EeG9UItNWMxIQw" source="redefines" references="_lyW2nnQ3EeG9UItNWMxIQw"/>
</contents>
</eAnnotations>
<eStructuralFeatures xmi:type="ecore:EReference" xmi:id="_lyW2nnQ3EeG9UItNWMxIQw" name="base_Property" ordered="false" lowerBound="1">
<eStructuralFeatures xmi:type="ecore:EAttribute" xmi:id="_lyW2oHQ3EeG9UItNWMxIQw" name="field" ordered="false" lowerBound="1">
</eClassifiers>
</contents>
<contents xmi:type="ecore:EPackage" xmi:id="_eHHCEXQ3EeG9UItNWMxIQw" name="ofbizprofile" nsURI="hhttpp:///schemas/ofbizprofile/_eHHCEHQ3EeG9UItNWMxIQw/6" nsPrefix="ofbizprofile">
<eClassifiers xmi:type="ecore:EClass" xmi:id="_eHHCEnQ3EeG9UItNWMxIQw" name="Entity">
<eAnnotations xmi:id="_eHHCE3Q3EeG9UItNWMxIQw" source="hhttpp://www.eclipse.org/uml2/2.0.0/UML" references="_WpbCIHQvEeG9UItNWMxIQw"/>
<eStructuralFeatures xmi:type="ecore:EAttribute" xmi:id="_eHHCFHQ3EeG9UItNWMxIQw" name="entityname" ordered="false" lowerBound="1">
<eStructuralFeatures xmi:type="ecore:EAttribute" xmi:id="_eHHCFnQ3EeG9UItNWMxIQw" name="tablename" ordered="false" lowerBound="1">
<eStructuralFeatures xmi:type="ecore:EAttribute" xmi:id="_eHHCGHQ3EeG9UItNWMxIQw" name="packagename" ordered="false" lowerBound="1">
<eStructuralFeatures xmi:type="ecore:EReference" xmi:id="_eHHCGnQ3EeG9UItNWMxIQw" name="base_Class" ordered="false" lowerBound="1">
</eClassifiers>
<eClassifiers xmi:type="ecore:EClass" xmi:id="_eHHCHHQ3EeG9UItNWMxIQw" name="Field">
<eAnnotations xmi:id="_eHHCHXQ3EeG9UItNWMxIQw" source="hhttpp://www.eclipse.org/uml2/2.0.0/UML" references="_AkdgsHQwEeG9UItNWMxIQw"/>
<eStructuralFeatures xmi:type="ecore:EAttribute" xmi:id="_eHHCHnQ3EeG9UItNWMxIQw" name="name" ordered="false" lowerBound="1">
<eStructuralFeatures xmi:type="ecore:EAttribute" xmi:id="_eHHCIHQ3EeG9UItNWMxIQw" name="type" ordered="false" lowerBound="1">
<eStructuralFeatures xmi:type="ecore:EAttribute" xmi:id="_eHHCInQ3EeG9UItNWMxIQw" name="enableauditlog" ordered="false" lowerBound="1">
<eStructuralFeatures xmi:type="ecore:EAttribute" xmi:id="_eHHCJHQ3EeG9UItNWMxIQw" name="notnull" ordered="false" lowerBound="1">
<eStructuralFeatures xmi:type="ecore:EReference" xmi:id="_eHHCJnQ3EeG9UItNWMxIQw" name="base_Property" ordered="false" lowerBound="1">
</eClassifiers>
<eClassifiers xmi:type="ecore:EClass" xmi:id="_eHHCKHQ3EeG9UItNWMxIQw" name="PrimKey">
<eAnnotations xmi:id="_eHHCKXQ3EeG9UItNWMxIQw" source="hhttpp://www.eclipse.org/uml2/2.0.0/UML" references="_cQeigHQ1EeG9UItNWMxIQw"/>
<eStructuralFeatures xmi:type="ecore:EReference" xmi:id="_eHHCKnQ3EeG9UItNWMxIQw" name="base_Property" ordered="false" lowerBound="1">
<eStructuralFeatures xmi:type="ecore:EAttribute" xmi:id="_eHHCLHQ3EeG9UItNWMxIQw" name="field" ordered="false" lowerBound="1">
</eClassifiers>
</contents>
<contents xmi:type="ecore:EPackage" xmi:id="_nCmBQXQ1EeG9UItNWMxIQw" name="ofbizprofile" nsURI="hhttpp:///schemas/ofbizprofile/_nCmBQHQ1EeG9UItNWMxIQw/5" nsPrefix="ofbizprofile">
<eClassifiers xmi:type="ecore:EClass" xmi:id="_nCmBQnQ1EeG9UItNWMxIQw" name="Entity">
<eAnnotations xmi:id="_nCmBQ3Q1EeG9UItNWMxIQw" source="hhttpp://www.eclipse.org/uml2/2.0.0/UML" references="_WpbCIHQvEeG9UItNWMxIQw"/>
<eStructuralFeatures xmi:type="ecore:EAttribute" xmi:id="_nCmBRHQ1EeG9UItNWMxIQw" name="entityname" ordered="false" lowerBound="1">
<eStructuralFeatures xmi:type="ecore:EAttribute" xmi:id="_nCmBRnQ1EeG9UItNWMxIQw" name="tablename" ordered="false" lowerBound="1">
<eStructuralFeatures xmi:type="ecore:EAttribute" xmi:id="_nCmBSHQ1EeG9UItNWMxIQw" name="packagename" ordered="false" lowerBound="1">
<eStructuralFeatures xmi:type="ecore:EReference" xmi:id="_nCmBSnQ1EeG9UItNWMxIQw" name="base_Class" ordered="false" lowerBound="1">
</eClassifiers>
<eClassifiers xmi:type="ecore:EClass" xmi:id="_nCmBTHQ1EeG9UItNWMxIQw" name="Field">
<eAnnotations xmi:id="_nCmBTXQ1EeG9UItNWMxIQw" source="hhttpp://www.eclipse.org/uml2/2.0.0/UML" references="_AkdgsHQwEeG9UItNWMxIQw"/>
<eStructuralFeatures xmi:type="ecore:EAttribute" xmi:id="_nCmBTnQ1EeG9UItNWMxIQw" name="name" ordered="false" lowerBound="1">
<eStructuralFeatures xmi:type="ecore:EAttribute" xmi:id="_nCmBUHQ1EeG9UItNWMxIQw" name="type" ordered="false" lowerBound="1">
<eStructuralFeatures xmi:type="ecore:EAttribute" xmi:id="_nCmBUnQ1EeG9UItNWMxIQw" name="enableauditlog" ordered="false" lowerBound="1">
<eStructuralFeatures xmi:type="ecore:EAttribute" xmi:id="_nCmBVHQ1EeG9UItNWMxIQw" name="notnull" ordered="false" lowerBound="1">
<eStructuralFeatures xmi:type="ecore:EReference" xmi:id="_nCmBVnQ1EeG9UItNWMxIQw" name="base_Property" ordered="false" lowerBound="1">
</eClassifiers>
<eClassifiers xmi:type="ecore:EClass" xmi:id="_nCmBWHQ1EeG9UItNWMxIQw" name="PrimKey">
<eAnnotations xmi:id="_nCmBWXQ1EeG9UItNWMxIQw" source="hhttpp://www.eclipse.org/uml2/2.0.0/UML" references="_cQeigHQ1EeG9UItNWMxIQw"/>
<eStructuralFeatures xmi:type="ecore:EReference" xmi:id="_nCmBWnQ1EeG9UItNWMxIQw" name="base_Property" ordered="false" lowerBound="1">
</eClassifiers>
</contents>
<contents xmi:type="ecore:EPackage" xmi:id="_CvkQ4XQxEeG9UItNWMxIQw" name="ofbizprofile" nsURI="hhttpp:///schemas/ofbizprofile/_CvkQ4HQxEeG9UItNWMxIQw/4" nsPrefix="ofbizprofile">
<eClassifiers xmi:type="ecore:EClass" xmi:id="_CvkQ4nQxEeG9UItNWMxIQw" name="Entity">
<eAnnotations xmi:id="_CvkQ43QxEeG9UItNWMxIQw" source="hhttpp://www.eclipse.org/uml2/2.0.0/UML" references="_WpbCIHQvEeG9UItNWMxIQw"/>
<eStructuralFeatures xmi:type="ecore:EAttribute" xmi:id="_CvkQ5HQxEeG9UItNWMxIQw" name="entityname" ordered="false" lowerBound="1">
<eStructuralFeatures xmi:type="ecore:EAttribute" xmi:id="_CvkQ5nQxEeG9UItNWMxIQw" name="tablename" ordered="false" lowerBound="1">
<eStructuralFeatures xmi:type="ecore:EAttribute" xmi:id="_CvkQ6HQxEeG9UItNWMxIQw" name="packagename" ordered="false" lowerBound="1">
<eStructuralFeatures xmi:type="ecore:EReference" xmi:id="_CvkQ6nQxEeG9UItNWMxIQw" name="base_Class" ordered="false" lowerBound="1">
</eClassifiers>
<eClassifiers xmi:type="ecore:EClass" xmi:id="_CvkQ7HQxEeG9UItNWMxIQw" name="Field">
<eAnnotations xmi:id="_CvkQ7XQxEeG9UItNWMxIQw" source="hhttpp://www.eclipse.org/uml2/2.0.0/UML" references="_AkdgsHQwEeG9UItNWMxIQw"/>
<eStructuralFeatures xmi:type="ecore:EAttribute" xmi:id="_CvkQ7nQxEeG9UItNWMxIQw" name="name" ordered="false" lowerBound="1">
<eStructuralFeatures xmi:type="ecore:EAttribute" xmi:id="_CvkQ8HQxEeG9UItNWMxIQw" name="type" ordered="false" lowerBound="1">
<eStructuralFeatures xmi:type="ecore:EAttribute" xmi:id="_CvkQ8nQxEeG9UItNWMxIQw" name="enableauditlog" ordered="false" lowerBound="1">
<eStructuralFeatures xmi:type="ecore:EAttribute" xmi:id="_CvkQ9HQxEeG9UItNWMxIQw" name="notnull" ordered="false" lowerBound="1">
<eStructuralFeatures xmi:type="ecore:EReference" xmi:id="_CvkQ9nQxEeG9UItNWMxIQw" name="base_Property" ordered="false" lowerBound="1">
</eClassifiers>
</contents>
<contents xmi:type="ecore:EPackage" xmi:id="_34_I4XQwEeG9UItNWMxIQw" name="ofbizprofile" nsURI="hhttpp:///schemas/ofbizprofile/_34_I4HQwEeG9UItNWMxIQw/3" nsPrefix="ofbizprofile">
<eClassifiers xmi:type="ecore:EClass" xmi:id="_34_I4nQwEeG9UItNWMxIQw" name="Entity">
<eAnnotations xmi:id="_34_I43QwEeG9UItNWMxIQw" source="hhttpp://www.eclipse.org/uml2/2.0.0/UML" references="_WpbCIHQvEeG9UItNWMxIQw"/>
<eStructuralFeatures xmi:type="ecore:EAttribute" xmi:id="_34_I5HQwEeG9UItNWMxIQw" name="entityname" ordered="false" lowerBound="1">
<eStructuralFeatures xmi:type="ecore:EAttribute" xmi:id="_34_I5nQwEeG9UItNWMxIQw" name="tablename" ordered="false" lowerBound="1">
<eStructuralFeatures xmi:type="ecore:EAttribute" xmi:id="_34_I6HQwEeG9UItNWMxIQw" name="packagename" ordered="false" lowerBound="1">
<eStructuralFeatures xmi:type="ecore:EReference" xmi:id="_34_I6nQwEeG9UItNWMxIQw" name="base_Class" ordered="false" lowerBound="1">
</eClassifiers>
<eClassifiers xmi:type="ecore:EClass" xmi:id="_34_I7HQwEeG9UItNWMxIQw" name="Field">
<eAnnotations xmi:id="_34_I7XQwEeG9UItNWMxIQw" source="hhttpp://www.eclipse.org/uml2/2.0.0/UML" references="_AkdgsHQwEeG9UItNWMxIQw"/>
<eStructuralFeatures xmi:type="ecore:EAttribute" xmi:id="_34_I7nQwEeG9UItNWMxIQw" name="name" ordered="false" lowerBound="1">
<eStructuralFeatures xmi:type="ecore:EAttribute" xmi:id="_34_I8HQwEeG9UItNWMxIQw" name="type" ordered="false" lowerBound="1">
<eStructuralFeatures xmi:type="ecore:EAttribute" xmi:id="_34_I8nQwEeG9UItNWMxIQw" name="enableauditlog" ordered="false" lowerBound="1">
<eStructuralFeatures xmi:type="ecore:EAttribute" xmi:id="_34_I9HQwEeG9UItNWMxIQw" name="notnull" ordered="false" lowerBound="1">
</eClassifiers>
</contents>
<contents xmi:type="ecore:EPackage" xmi:id="_bW-g8HQwEeG9UItNWMxIQw" name="ofbizprofile" nsURI="hhttpp:///schemas/ofbizprofile/_bW954HQwEeG9UItNWMxIQw/2" nsPrefix="ofbizprofile">
<eClassifiers xmi:type="ecore:EClass" xmi:id="_bW-g8XQwEeG9UItNWMxIQw" name="Entity">
<eAnnotations xmi:id="_bW-g8nQwEeG9UItNWMxIQw" source="hhttpp://www.eclipse.org/uml2/2.0.0/UML" references="_WpbCIHQvEeG9UItNWMxIQw"/>
<eStructuralFeatu
[Updated on: Fri, 23 March 2012 20:41] Report message to a moderator
FUDForum. Page generated in 0.01993 seconds
