TPTP 4.4 failure [message #102104] |
Sat, 30 June 2007 12:28 |
Originally posted by: n.sherlock.gmail.com
Hey all,
I downloaded the latest Eclipse 3.3, and grabbed TPTP 4.4 from the
update manager, but I can't seem to get it to do anything :). I didn't
touch any of the settings. When try to profile any application with
"Java Profiling (JRE 1.5 or newer) > Execution time analysis", I get
this message:
org.eclipse.core.runtime.CoreException
Agent Controller is unavailable under port 10006. Make sure that the
service is started and the port number is correct under preferences.
org.eclipse.tptp.platform.execution.exceptions.AgentControll erUnavailableException
at
org.eclipse.tptp.platform.jvmti.client.internal.launcher.uti l.AgentControllerDelegate.getConnection(AgentControllerDeleg ate.java:226)
at
org.eclipse.tptp.platform.jvmti.client.internal.launcher.uti l.AgentControllerDelegate.getConnection(AgentControllerDeleg ate.java:71)
at
org.eclipse.tptp.platform.jvmti.client.internal.launcher.TID elegateHelper.connectToAgentController(TIDelegateHelper.java :388)
at
org.eclipse.tptp.platform.jvmti.client.internal.launcher.TID elegateHelper.launch(TIDelegateHelper.java:308)
at
org.eclipse.tptp.platform.jvmti.client.internal.launcher.TIJ avaLauncherDelegate.launch(TIJavaLauncherDelegate.java:37)
at
org.eclipse.tptp.trace.ui.internal.launcher.core.LauncherUti lity.delegateInit(LauncherUtility.java:1153)
at
org.eclipse.tptp.trace.ui.provisional.launcher.PrimaryLaunch Delegate.run(PrimaryLaunchDelegate.java:196)
If I click the "Test connection" button in the Hosts preferences page,
Eclipse locks hard and I have to kill it in Task manager. Where do I
start in diagnosing this problem?
Nicholas Sherlock
Re: TPTP 4.4 failure [message #102134 is a reply to message #102121] |
Sun, 01 July 2007 09:19 |
Asaf Yaffe wrote:
> Nicholas,
> Which O/S and Architecture are you using?
Windows XP SP2, running on Sun JRE 1.6.0_01-b06.
Nicholas Sherlock
Re: TPTP 4.4 failure [message #102164 is a reply to message #102150] |
Sun, 01 July 2007 22:44 |
Charlie Kelly wrote:
> Hi Nicholas,
> I had the same problem.
> The problem "went away" when I used a 1.5 JRE.
> Charlie
Ohhh, I was hopeful, but no change when running on Sun JRE 1.5.0_10-b03. :(
Nicholas Sherlock
Re: TPTP 4.4 failure [message #102973 is a reply to message #102184] |
Wed, 04 July 2007 11:58 |
Igor Alelekov wrote:
> Hi Nicholas,
> Is Integrated Agent Controller enabled in your preferences
> (Window/Preferences/Agent Controller/Integrated Agent Controller)?
Yes, it is enabled. Setting security to accept "all" instead of
"localhost" doesn't help either. Disabling Windows Firewall doesn't help.
Nicholas Sherlock
Re: TPTP 4.4 failure [message #103166 is a reply to message #102973] |
Thu, 05 July 2007 15:35 |
Originally posted by: adam.giemza.gmx.de
Hey Nicholas,
is it working now? I wanted to profile my application as well, without any
result. Same System configuration.
Greets,
Adam
Re: TPTP 4.4 failure [message #103479 is a reply to message #103166] |
Sun, 08 July 2007 03:37 |
Adam Giemza wrote:
> Hey Nicholas,
Sorry, I wish it were, but I haven't had any more luck getting it to work.
Nicholas Sherlock
Re: TPTP 4.4 failure [message #105062 is a reply to message #102104] |
Mon, 16 July 2007 17:43 |
Originally posted by: meackerman.rmanet.com
similiar problem here. Windows XP SP2. Eclipse 3.3 TPTP 4.4. Java
1.6.0_01
Fresh install of Eclipse.
Agent Controller is unavailable under port 10010. Make sure that the
at
at
at
at
at
at
at
at java.lang.Thread.run(Thread.java:595)
Re: TPTP 4.4 failure [message #105911 is a reply to message #105062] |
Fri, 20 July 2007 09:43 |
Originally posted by: cl.silistix.com
I remember reading somewhere that something (TPTP/AGR/Agent Controller)
doesn't support java 1.6.
You might try switching down to 1.5 and seeing if that works.
> 1.6.0_01
> at
> at
> at
> at
> at
> at
> at
Re: TPTP 4.4 failure [message #105996 is a reply to message #103479] |
Fri, 20 July 2007 16:22 |
Originally posted by: rick.ingham.expeditors.com
Are your Window/Preferences/General/NetworkConnections set to use a proxy?
I turned of the proxy setting and then everything worked.
I think this is a bug. I don't think it should use the proxy settings at
all. Even if it should, I had localhost in the proxy exclusion list, but
it was still trying to connect to the agent controller through the proxy.
If you have the proxy enabled, try disabling it.
I had the same symptom that it appeared even Test Connnection locked up
Eclipse, but in reality, it just took a long time for it to time out on
the proxy connection. It would come back, eventually.
Re: TPTP 4.4 failure [message #106191 is a reply to message #105911] |
Mon, 23 July 2007 16:08 |
Since we rely on some 1.6 features, there's no going back to 1.5.
Guess we'll just have to look at using a different profiling tool.
Re: TPTP 4.4 failure [message #108250 is a reply to message #106257] |
Thu, 09 August 2007 20:52 |
Ok downloaded the standalone agent controller. Couldn't get it to start
as a windows service, but it ran as an application.
Started profiling my application, but the profiling is really slow.
FUDForum. Page generated in 0.04449 seconds
