Home » Modeling » TMF (Xtext) » migrating to Xtext 2.3 and ITreeAppendable
migrating to Xtext 2.3 and ITreeAppendable [message #826625] Thu, 22 March 2012 09:51 Go to next message
Lorenzo Bettini is currently offline Lorenzo BettiniFriend
I started to migrate my DSL to Xtext 2.3 milestone; in the compiler
methods I see that now Xbase requires an ITreeAppendable instead of
IAppendable... since I was using StringBuilderBasedAppendable (which
does not implement ITreeAppendable), what class should I use now? would
the class TreeAppendable be OK?
thanks in advance
Lore
ICQ# lbetto, 16080134 (GNU/Linux User # 158233)
HOME: http://www.lorenzobettini.it MUSIC: http://www.purplesucker.com
http://www.myspace.com/supertrouperabba
BLOGS: http://tronprog.blogspot.com http://longlivemusic.blogspot.com
http://www.gnu.org/software/src-highlite
http://www.gnu.org/software/gengetopt
http://www.gnu.org/software/gengen http://doublecpp.sourceforge.net
Re: migrating to Xtext 2.3 and ITreeAppendable [message #827211 is a reply to message #826625] Fri, 23 March 2012 02:35 Go to previous messageGo to next message
Sebastian Zarnekow is currently offline Sebastian ZarnekowFriend
Hi Lorenzo,
what do you want to do? The appendable is created by the framework and
passed to clients.
Sebastian
Am 22.03.12 05:51, schrieb Lorenzo Bettini:
> Hi
> thanks in advance
> Lore
Re: migrating to Xtext 2.3 and ITreeAppendable [message #827423 is a reply to message #827211] Fri, 23 March 2012 10:04 Go to previous messageGo to next message
On 03/23/2012 03:35 AM, Sebastian Zarnekow wrote:
> Hi Lorenzo,
> passed to clients.
> Regards,
> Sebastian
Hi Sebastian
in this DSL I'm not using the inferrer (for the moment) and I have a
custom xbase compiler which I call from the generator, thus I have to
create the appendable myself...
Is FakeTreeAppendable the right substitute?
thanks in advance
Lorenzo
Re: migrating to Xtext 2.3 and ITreeAppendable [message #828478 is a reply to message #827423] Sat, 24 March 2012 21:51 Go to previous messageGo to next message
Hi Lorenzo,
yes you can use that but you won't get debugging for free.
TreeAppendable is the actual implementation, but it imposes some
constraints on how you use the compiler. If you don't need the tracing
and jsr45 stuff, FakeTreeAppendable is the way to go.
Sebastian
Am 23.03.12 06:04, schrieb Lorenzo Bettini:
>> Hi Lorenzo,
>> passed to clients.
>> Regards,
>> Sebastian
> Hi Sebastian
> thanks in advance
> Lorenzo
Re: migrating to Xtext 2.3 and ITreeAppendable [message #1146533 is a reply to message #828478] Sun, 20 October 2013 07:52 Go to previous message
Hirdesh Agrawal is currently offline Hirdesh AgrawalFriend
Dear All,
I need your favor or suggestion regarding migrate the xtext version from 1.0.1 to 2.3.0 in custom application.
I followed all following process for migrate the xtext version.
1. Delete the old plug-ins and update the latest plug-ins in target platform.
2. Update the Plug-in Dependencies and Import Statements.
3. Introduction of the Qualified Name.
4. Changes in the index and in find references.
5. Rewritten Node Model.
6. AutoEditStrategy.
7. Other Noteworthy API Changes
To consider the above steps, I started the work with Eclipse-4.2, Which has a xtext-2.3.0 dependency. Successfully I completed the all above steps and removed the compilation error.
Problem: After that I start the testing and getting below error Messages:
[XtextLinkingDiagnostic: null:6 Couldn't resolve reference to Material 'MPS_RECUR'.,
XtextLinkingDiagnostic: null:9 Couldn't resolve reference to Cstic 'NUM_OF_ALLOC'.,
XtextLinkingDiagnostic: null:15 Couldn't resolve reference to Cstic 'INSTANCE_NUM'.,
XtextLinkingDiagnostic: null:14 Couldn't resolve reference to Class 'ALLOC'.]
Previous Topic:Migration strategies
Next Topic:Problems with imports after migrating to xtext 2.0
Current Time: Thu May 13 02:00:18 GMT 2021
Powered by FUDForum. Page generated in 0.02847 seconds
