Home » Eclipse Projects » BIRT » Hide empty yaxix series legend
Hide empty yaxix series legend [message #826247] Wed, 21 March 2012 21:22 Go to next message
Jesh Stha is currently offline Jesh SthaFriend
I have a report with empty y-axis series legend. I want to hide it. can anyone please help?
index.php/fa/7618/0/
  • Attachment: report.png
    (Size: 13.56KB, Downloaded 633 times)
Re: Hide empty yaxix series legend [message #826863 is a reply to message #826247] Thu, 22 March 2012 15:44 Go to previous messageGo to next message
Jason Weathersby is currently offline Jason WeathersbyFriend
I am attaching two examples. One beforeDrawLegendVis.rptdesign just
shows how to hide the graphic if the label contains no text. This may
work in your case, but if it creates a hole in the legend, meaning you
have values after it you may have to do a bit more scripting. The
second example shows how to remove an entry from the legend without
creating a hole.
Jason
On 3/21/2012 5:22 PM, Jesh Stha wrote:
Re: Hide empty yaxix series legend [message #826985 is a reply to message #826863] Thu, 22 March 2012 18:54 Go to previous messageGo to next message
hi Jason,
Awesome, Thank you so much, its working perfectly like what i want.
Again, thank you for your time.
Re: Hide empty yaxix series legend [message #827055 is a reply to message #826985] Thu, 22 March 2012 20:55 Go to previous messageGo to next message
Hi Jason,
I created bunch of reports using scripted data source and send everything to library ( dataset, datasource, parameters..). some of the reports are the same layout with different in parameters. Now when creating a single page report (importing individual report to one single report to create PDF file ) I tried to reuse some of the layout with different parameter but couldn't do that.
How can i re-use the same layout of report with different set of parameter when importing to the single page master report?
Please help me.
Thanks a lot.
Re: Hide empty yaxix series legend [message #827726 is a reply to message #827055] Fri, 23 March 2012 18:15 Go to previous messageGo to next message
I am not exactly sure what you are asking? The master page can be put
in a library.
Jason
On 3/22/2012 4:55 PM, Jesh Stha wrote:
> Hi Jason,
> Please help me.
> Thanks a lot.
Re: Hide empty yaxix series legend [message #827826 is a reply to message #827726] Fri, 23 March 2012 21:07 Go to previous message
HI Jason,
Master page is not in library, all the report items is in library. I am trying to import reports to one single report file (i called it Master report).
Thank you
Previous Topic:Is it possible to check if parameter allows null at rendering time?
Next Topic:BIRT report chart axix coordinates
Current Time: Tue Dec 07 16:25:50 GMT 2021
Powered by FUDForum. Page generated in 0.06705 seconds
