Home » Modeling » Papyrus » Papyrus in RCP
Papyrus in RCP [message #826064] Wed, 21 March 2012 15:59 Go to next message
Leonid Ripeynih is currently offline Leonid RipeynihFriend
Is it possible to use papyrus in RCP project? We have a EMF model, with Model, .Edit, Core and UI widget model editors, and want to use Papyrus to edit our model in UML form. Is it possible to integrate papyrus in custom RCP application?
Re: Papyrus in RCP [message #857490 is a reply to message #826064] Thu, 26 April 2012 15:30 Go to previous messageGo to next message
Horacio Hoyos is currently offline Horacio HoyosFriend
Yes it is. On your RCP plugin project, in the .product configuration file, go to the Dependencies tab and add all the papyrus plugins. Then to make sure papyrus dependencies are added to click on "Add required Plug-ins". That should do.
Launch your RCP and work on Papyrus. In case you get an error due to a class missing, read the error log, found out the class and then u can use the internet to search what plugin provides that class. Go back to your RCP .product include the missing plugin, rinse and repeat.
Horace
Horacio Hoyos Rodriguez
Epsilon Committer
Research Assistant
University Of York
Re: Papyrus in RCP [message #1753331 is a reply to message #826064] Fri, 03 February 2017 23:37 Go to previous message
GHORAB Mostafa Anouar is currently offline GHORAB Mostafa AnouarFriend
hi
did it work with you !!
Previous Topic:Problems with generated static profile
Next Topic:Symbol compartment not visible for some elements
Current Time: Sun Aug 09 21:29:19 GMT 2020
Powered by FUDForum. Page generated in 0.01654 seconds
