SWT DateTime [message #101795] |
Sun, 10 August 2008 17:19 |
Originally posted by: m.n.com
I was thinking about using DateTime now that it looks like it will be
supported by RAP. But it there doesn't seem to be a way to 'null' out
the date like one can with the Nebula DateChooserCombo. Any ideas? I
have some but they are ugly.
Re: SWT DateTime [message #101824 is a reply to message #101795] |
Sun, 10 August 2008 18:31 |
Originally posted by: ifurnadjiev.innoopract.com
Hi Mark,
unfortunately the SWT DateTime widget does not allow null values to all
fields (day, month, year, hours, minutes, seconds). That's why the RAP
implementation will follow the same behavior. I'm just curious... why
you need to "null" the date/time?
Best.
Ivan
Re: SWT DateTime [message #101969 is a reply to message #101824] |
Mon, 11 August 2008 18:50 |
Hi Ivan,
Thanks for confirming what I thought I saw.
Some dates need to have a null value until they are set or when they
are removed. For instance, if I have a form that I want to be used from
X till Y but I don't know when Y is, then they Y date needs to be null.
There are plenty of other scenarios like this.
I could put a check beside that datetime widget that enables/disables
it. I am currentlly weighing the pro's (i can easily switch from RAP to
RCP) and the con's (users will complain and binding will not be straight
forward)
Mark
Ivan Furnadjiev wrote:
> Hi Mark,
> Best.
> Ivan
Re: SWT DateTime [message #102221 is a reply to message #101984] |
Wed, 13 August 2008 04:15 |
Yeah. I was hoping to have something I could use in RCP and RAP. In an
RCP I can just use Nebula widgets. So my choices are dig in and help or
deal with it.
stefan.hansel@tolina.de wrote:
> Too be honest:
> we think the DateTime-Widget is inappropriate for 'normal' user anyway
> (not a problem of RAP but of SWT in the first place).
> Having to 'type-click-type-click-type' or ('type-movecursor-type-...')
> to insert a date is a usability nightmare ..
> That's why we wrote our own widget, much like on the
> RAP-demo-workbench-website (with popup-calendar for instance, but still
> editable date).
> For some Date-Fields we have the need to support null-Dates as well ...
> it's just common to leave a DateField empty, if the Date is unknown to
> the user for instance. Anyway - that's easy if you start to use your own
> widget :D ...
Re: SWT DateTime [message #102338 is a reply to message #102221] |
Wed, 13 August 2008 20:45 |
Originally posted by: tavoaqp.gmail.com
Hi Mark
Check this out
http://dev.eclipse.org/newslists/news.eclipse.technology.rap /msg01675.html
I guess this solves your problem.
Gustavo
Mark escreveu:
> deal with it.
>> Too be honest:
>> still editable date).
>> ... it's just common to leave a DateField empty, if the Date is
>> unknown to the user for instance. Anyway - that's easy if you start to
>> use your own widget :D ...
Re: SWT DateTime [message #102376 is a reply to message #102338] |
Thu, 14 August 2008 01:37 |
Thanks, I'll take a look at it!
Gustavo wrote:
> Hi Mark
> Check this out
> Gustavo
> Mark escreveu:
>> or deal with it.
>>> Too be honest:
>>> anyway (not a problem of RAP but of SWT in the first place).
>>> ('type-movecursor-type-...') to insert a date is a usability
>>> nightmare ..
>>> to use your own widget :D ...
FUDForum. Page generated in 0.03226 seconds
