prohibiting attributes in extension [message #9265] |
Wed, 08 January 2003 10:02 |
Originally posted by: Michael.Hartmeier.softwareag.com
Eclipse allows to create a schema where a derived type prohibites an
attribute of the base type. Is this correct, is the attached schema valid
according the the XML schema spec? I'd expect to see some kind of XSD
diagnostics, but there are none (with XSD 20021023_1900TL).
Michael
<xs:schema xmlns:xs='http://www.w3.org/2001/XMLSchema'>
<xs:complexType name='base'>
<xs:sequence>
<xs:element name='a' type='xs:string'/>
</xs:sequence>
<xs:attribute name='a' type='xs:string' use='required'/>
<xs:attribute name='b' type='xs:string' use='required'/>
</xs:complexType>
<xs:complexType name='derived' >
<xs:complexContent>
<xs:extension base='base'>
<xs:sequence>
<xs:element name='b' type='xs:string'/>
</xs:sequence>
<xs:attribute name='b' type='xs:string' use='prohibited'/>
<xs:attribute name='c' type='xs:string' use='required'/>
</xs:extension>
</xs:complexContent>
</xs:complexType>
</xs:schema>
Re: prohibiting attributes in extension [message #9522 is a reply to message #9265] |
Fri, 24 January 2003 11:45 |
Michael,
No, this schema is not correct. It violates cause 1.2 of cos-ct-extends,
i.e., the base type's attributes uses are not a subset of those of the
complex type itself. (Only a restriction can prohibit attributes.) I've
fixed the implementation to produce a diagnostic for this case.
Thanks for finding this problem.
> Michael
> <xs:sequence>
> </xs:sequence>
> </xs:complexType>
> <xs:complexContent>
> <xs:sequence>
> </xs:sequence>
> </xs:extension>
> </xs:complexType>
> </xs:schema>
Ed Merks
Re: prohibiting attributes in extension [message #11707 is a reply to message #9522] |
Sat, 01 March 2003 09:51 |
Build 1207 properly reports the invalid schema :-)
Michael
Ed Merks wrote:
> Michael,
> > Michael
> > <xs:sequence>
> > </xs:sequence>
> > </xs:complexType>
> > <xs:complexContent>
> > <xs:sequence>
> > </xs:sequence>
> > </xs:extension>
> > </xs:complexType>
> > </xs:schema>
> Ed Merks
Re: prohibiting attributes in extension [message #564765 is a reply to message #9265] |
Ed Merks Messages: 33137 Registered: July 2009 |
Michael,
> Michael
> <xs:sequence>
> </xs:sequence>
> </xs:complexType>
> <xs:complexContent>
> <xs:sequence>
> </xs:sequence>
> </xs:extension>
> </xs:complexType>
> </xs:schema>
Ed Merks
Ed Merks
FUDForum. Page generated in 0.01501 seconds
