Equinox and CrEme (J2ME CDC) [message #101354] |
Fri, 09 November 2007 12:51 |
Jaime Messages: 56 Registered: July 2009 |
Member |
I've been testing equinox with IBM's J9 in a PDA and it works pretty well.
I'd like to check that it also works with CrEme (an implementation of J2ME
CDC 1.0 specification) but it doesn't work (it doesn't even start the
Equinox framework).
The log output (jscpout.txt) is:
NSIcom Ltd., CrEme(tm) Evaluation Version
CrE-ME J2ME(tm)
CrE-ME V4.12 B122.160107 16-Jan-2007
MemoryLimit=29056Kb
EBCI(TM) Interpreter V1.00,
Copyright 1998-2002 by Bytecodes, Inc.
java.lang.IllegalArgumentException: Cannot start without the following
system properties set: osgi.framework, osgi.install.area
at org.eclipse.core.runtime.adaptor.EclipseStarter.initializePr operties()
at org.eclipse.core.runtime.adaptor.EclipseStarter.startup()
at org.eclipse.core.runtime.adaptor.EclipseStarter.run()
at org.eclipse.core.runtime.adaptor.EclipseStarter.main()
The link that I've used to start Equinox is:
255#\SD-MMCard\Windows\CrEme\bin\CrEme.exe -Of -sp:0 -cp
\SD-MMCard\equinox\org.eclipse.osgi_3.3.0.v20070530.jar
org.eclipse.core.runtime.adaptor.EclipseStarter -console -clean
I've tried to set up the "osgi.framework" and "osgi.install.area" system
properties:
255#\SD-MMCard\Windows\CrEme\bin\CrEme.exe -Of -sp:0 -Dosgi.framework=/SD-MMCard/equinox
-Dosgi.install.area=/SD-MMCard/equinox -cp
org.eclipse.core.runtime.adaptor.EclipseStarter -console -clean -debug
=/SD-MMCard/equinox/configuration/.options
but then the log is:
CrE-ME J2ME(tm)
MemoryLimit=29056Kb
Debug options:
file:/SD-MMCard/equinox/configuration/.options loaded
org.eclipse.osgi Startup error
at org.eclipse.osgi.baseadaptor.BaseAdaptor.initializeStorage()
at org.eclipse.osgi.framework.internal.core.Framework.initializ e()
at org.eclipse.osgi.framework.internal.core.Framework.<init>()
at org.eclipse.osgi.framework.internal.core.OSGi.createFramewor k()
at org.eclipse.osgi.framework.internal.core.OSGi.<init>()
The /SD-MMCard/equinox is the directory that contains
org.eclipse.osgi_3.3.0.v20070530.jar and the configuration directory.
Did someone try to start up Equinox with CrEme?
Thank you in advance,
Jaime
FUDForum. Page generated in 0.02256 seconds
