Home » Modeling » TMF (Xtext) » Create own notice elements(Like info(), warning(), error())
Create own notice elements [message #822263] Fri, 16 March 2012 11:35 Go to next message
Heinz Huber is currently offline Heinz HuberFriend
Member
is there any way to create own notice elements?
I want to use them after validations to show different types of errors with different symbols instead the one that error brings with.
Is there a way to to this?
And if there is a way ... how?
Thanks in advance! Smile
Re: Create own notice elements [message #822284 is a reply to message #822263] Fri, 16 March 2012 12:15 Go to previous messageGo to next message
Christian Dietrich is currently offline Christian DietrichFriend
have a look at MarkerCreator and its callees
~Christian
Need professional support for Xtext, Xpand, EMF?
Go to: https://www.itemis.com/en/xtext/
Twitter : @chrdietrich
[Updated on: Fri, 16 March 2012 12:16]
Report message to a moderator
Re: Create own notice elements [message #822287 is a reply to message #822263] Fri, 16 March 2012 12:19 Go to previous message
Henrik Lindberg is currently offline Henrik LindbergFriend
You can add new marker types.
I create some new types of error and warning markers in
cloudsmith/geppetto @ github that you could look at.
The marker API is described in Eclipse documentation.
The rest depends on what you want to do, where, what triggers their
creation and more importantly cleanup when the markers should no longer
be there.
- henrik
On 2012-16-03 12:35, Heinz Huber wrote:
> Thanks in advance! :)
Previous Topic:using non java style escaping in xtext eclipse editor
Next Topic:XtextResource couldn't resolve references to an external Ecore model
Current Time: Fri May 29 17:50:36 GMT 2020
Powered by FUDForum. Page generated in 0.01779 seconds
