Re: set Data Source from your java code [message #819398 is a reply to message #819262] |
Mon, 12 March 2012 21:47   |
Using the de api from the java code that runs the report you should be
able to open the report and modify any properties. What do you want to
change in the data source?
Jason
On 3/12/2012 1:38 PM, Deepali Patil wrote:
> I have rptdesign, and I generate report in different format through my
> java code. I have set the dataSource while designing the report design,
> and java code just run's that design.
> When I am testing same code with rptdesign on different LAN, it can not
> able to find dataSource which I set in design. To run this code I need
> to edit datasource for database. Which is very tedious for different LAN
> Is it possible to set datasource through java code?
> Deepali.
FUDForum. Page generated in 0.02114 seconds
