Home » Modeling » TMF (Xtext) » Comparison!!!(create a boolean expression combined with arthmetic operations)
Comparison!!! [message #818337] Sun, 11 March 2012 12:44 Go to next message
fay ab is currently offline fay abFriend
first, excuse me for my English if you find some wrong sentenses.
I must write Xtext grammar for a project, and I'm jammed at some boolean expression,
this is the problem:
transition NomOfTransition [ Guard ] {
my problem is the Guard.
the grammar is:
System :
('System' name=ID '{'
(variables+=VariableDeclaration)*
transitions+=Transition+
VariableDeclaration returns Variable:
name=ID '=' initVal=INT ';'|
aname=ID'['index=Addition']' '=' initVal=INT ';' //array
Transition:
'transition' name=ID '[' garde=(Or) ']' ('label' label=STRING)? '{'
(assignments+=Assignment )+
Assignment :
var=VariableRef '=' expr=Addition';'
Addition returns IntExpression:
Multiplication (
({Addition.left=current} '+' | {Subtraction.left=current} '-' )
right=Multiplication
Multiplication returns IntExpression :
UnitaryMinus
({Multiplication.left=current} '*' | {Division.left=current} '/' | {Modulo.left=current} '%')
right=UnitaryMinus
UnitaryMinus returns IntExpression :
('-'? Power {UnitaryMinus.val=current})
Power returns IntExpression:
Primary ({Power.left=current} '**' right=Primary)*
Primary returns IntExpression :
VariableRef | Constante | '(' Addition ')'
Constante:
val=INT
VariableRef :
var=[Variable]
Or returns BooleanExpression :
And ({Or.left=current} '||' right=And)*
And returns BooleanExpression:
Not ({And.left=current} '&&' right=Not)*
Not returns BooleanExpression :
('!' ? PrimaryBool {Not.val=current})
PrimaryBool returns BooleanExpression:
True | False | '(' Or ')'
Comparison return BooleanExpression:
Addition ({Comparison.left=current} op=BoolOperator right=Addition}
BoolOperator:
True:
value='True'
False:
value='False'
I must respect some meta-model, Comparison must have 2 IntExpression and an operator
Thank you so much!
Re: Comparison!!! [message #820569 is a reply to message #818337] Wed, 14 March 2012 09:40 Go to previous message
Meinte Boersma is currently offline Meinte BoersmaFriend
We're still trying to understand what your exact problem is here, I guess.
How about adding
IntExpression:
  Addition;
and changing
IntExpression ({Comparison.left=current} op=BoolOperator right=IntExpression}
Previous Topic:DSL Generation and Validation
Next Topic:Validation just for the changed elements?
Current Time: Fri May 29 23:34:09 GMT 2020
Powered by FUDForum. Page generated in 0.01365 seconds
