Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc) » [Compare] Non-eclipse context
[Compare] Non-eclipse context [message #99658] |
Fri, 19 October 2007 03:38  |
Originally posted by: user.domain.invalid
I want to use my EMF model in a server context (jdk 1.5, with teneo). In
this context, I want to make comparison between two models. In the FAQ
web site, a question precises that it is possible to use EMF/Compare in
such context and a code exemple is supplied.
Nevertheless, in the MatchService, I see :
final IExtension[] extensions =
Platform.getExtensionRegistry().getExtensionPoint(
MATCH_ENGINES_EXTENSION_POINT).getExtensions();
So it seems it's not possible to run Compare in such context. I'm right ?
Thanks for any answer.
Robert Jacolin
Re: [Compare] Non-eclipse context [message #100086 is a reply to message #99670] |
Tue, 23 October 2007 09:49   |
We worked this out, fixed things for the latest builds and Laurent created a
Java project example you can find there:
http://wiki.eclipse.org/EMF_Compare_FAQ#Is_EMF_Compare.2C_as _EMF.2C_able_to_run_outside_of_Eclipse_.3F
Do not hesitate to give feedback on this kind of use case, thanks again.
Cédric Brun
user@domain.invalid wrote:
> laurent Goubet a écrit :
>> Hi,
>> Indeed this would probably fail, I will look into this as this code
>> shouldn't be called when out of eclipse. For now, you can bypass this by
>> replacing "ModelMatch.doMatch(EObject, EObject, ProgressMonitor)" with
>> "new DifferencesService.modelMatch(EObject, EObject, ProgressMonitor)".
> Thanks for you speed and your answer.
> I obtain the same error with the call DiffService.doDiff (I tried to
> change to DiffMaker.doDiff but I still obtain the same error).
> Regards,
> Robert Jacolin
Re: [Compare] Non-eclipse context [message #100114 is a reply to message #100086] |
Tue, 23 October 2007 11:24  |
Originally posted by: robert.jacolin.anyware-tech.com
Cédric Brun a écrit :
created a
It works fine ! I updated the 3 emf.compare jar and called the methods :
final MatchModel match = new DifferencesServices().modelMatch(model1,
model2, Collections.<String, Object> emptyMap());
final DiffModel diff = new DiffMaker().doDiff(match, false);
Thanks again.
Robert Jacolin
Robert JACOLIN
M2M
ANYWARE TECHNOLOGIES
www.anyware-tech.com
Re: [Compare] Non-eclipse context [message #610084 is a reply to message #99658] |
Fri, 19 October 2007 03:55  |
--------------080604000001030102050607
Laurent Goubet
Obeo
user@domain.invalid a
Re: [Compare] Non-eclipse context [message #610086 is a reply to message #99665] |
Fri, 19 October 2007 04:28  |
Robert Jacolin
Re: [Compare] Non-eclipse context [message #610131 is a reply to message #99670] |
Cédric Brun
>> Hi,
> Regards,
> Robert Jacolin
Current Time: Wed Mar 19 06:36:31 EDT 2025
Powered by FUDForum. Page generated in 0.05806 seconds
