Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » [Compare] Non-eclipse context
[Compare] Non-eclipse context [message #99658] Fri, 19 October 2007 03:38 Go to next message
Originally posted by: user.domain.invalid
I want to use my EMF model in a server context (jdk 1.5, with teneo). In
this context, I want to make comparison between two models. In the FAQ
web site, a question precises that it is possible to use EMF/Compare in
such context and a code exemple is supplied.
Nevertheless, in the MatchService, I see :
final IExtension[] extensions =
Platform.getExtensionRegistry().getExtensionPoint(
MATCH_ENGINES_EXTENSION_POINT).getExtensions();
So it seems it's not possible to run Compare in such context. I'm right ?
Thanks for any answer.
Robert Jacolin
Re: [Compare] Non-eclipse context [message #99665 is a reply to message #99658] Fri, 19 October 2007 03:55 Go to previous messageGo to next message
--------------080604000001030102050607
Indeed this would probably fail, I will look into this as this code
shouldn't be called when out of eclipse. For now, you can bypass this by
replacing "ModelMatch.doMatch(EObject, EObject, ProgressMonitor)" with
"new DifferencesService.modelMatch(EObject, EObject, ProgressMonitor)".
Laurent Goubet
Obeo
user@domain.invalid a
Re: [Compare] Non-eclipse context [message #99670 is a reply to message #99665] Fri, 19 October 2007 04:28 Go to previous messageGo to next message
laurent Goubet a écrit :
Thanks for you speed and your answer.
I obtain the same error with the call DiffService.doDiff (I tried to
change to DiffMaker.doDiff but I still obtain the same error).
Robert Jacolin
Re: [Compare] Non-eclipse context [message #100086 is a reply to message #99670] Tue, 23 October 2007 09:49 Go to previous messageGo to next message
We worked this out, fixed things for the latest builds and Laurent created a
Java project example you can find there:
http://wiki.eclipse.org/EMF_Compare_FAQ#Is_EMF_Compare.2C_as _EMF.2C_able_to_run_outside_of_Eclipse_.3F
Do not hesitate to give feedback on this kind of use case, thanks again.
Cédric Brun
>> Hi,
> Regards,
> Robert Jacolin
Re: [Compare] Non-eclipse context [message #100114 is a reply to message #100086] Tue, 23 October 2007 11:24 Go to previous message
Originally posted by: robert.jacolin.anyware-tech.com
Cédric Brun a écrit :
created a
It works fine ! I updated the 3 emf.compare jar and called the methods :
final MatchModel match = new DifferencesServices().modelMatch(model1,
model2, Collections.<String, Object> emptyMap());
final DiffModel diff = new DiffMaker().doDiff(match, false);
Thanks again.
Robert Jacolin
Robert JACOLIN
M2M
ANYWARE TECHNOLOGIES
www.anyware-tech.com
Re: [Compare] Non-eclipse context [message #610084 is a reply to message #99658] Fri, 19 October 2007 03:55 Go to previous message
Laurent Goubet
Obeo
Re: [Compare] Non-eclipse context [message #610086 is a reply to message #99665] Fri, 19 October 2007 04:28 Go to previous message
Robert Jacolin
Re: [Compare] Non-eclipse context [message #610131 is a reply to message #99670] Tue, 23 October 2007 09:49 Go to previous message
Cédric Brun
>> Hi,
> Regards,
> Robert Jacolin
Re: [Compare] Non-eclipse context [message #610136 is a reply to message #100086] Tue, 23 October 2007 11:24 Go to previous message
created a
Thanks again.
Robert Jacolin
Robert JACOLIN
M2M
Previous Topic:Log4j Dependency
Next Topic:[Announce] Mint component proposal
Current Time: Wed Mar 19 02:54:39 EDT 2025
Powered by FUDForum. Page generated in 0.28347 seconds
