Home » Eclipse Projects » Dali » Can't add entity class that doesn't have @table into the diagram
Can't add entity class that doesn't have @table into the diagram [message #816233] Thu, 08 March 2012 15:26 Go to next message
Cristiano Gavião is currently offline Cristiano GaviãoFriend
I'm using Dali's Diagram Editor v.1.0.1.
I've created a diagram and in it I've created a 'Inherited Entity'.
When I try to drag the generated MappedSuperclass1 drop it into the diagram, another Entity# is created. The same occurs when I try to do the same with a entity that doesn't have @table.
It's a bug ?
regards,
Cristiano
Re: Can't add entity class that doesn't have @table into the diagram [message #816258 is a reply to message #816233] Thu, 08 March 2012 16:12 Go to previous messageGo to next message
Petya Sabeva is currently offline Petya SabevaFriend
Hi Cristiano,
For the current versions of the Eclipse, this is the expected behavior. We had decided that only the entities should be shown in the diagram editor.
Nevertheless there is a proposed feature for visualizing the MappedSuperclasses which will be part of the Juno Eclipse.
Petya
Re: Can't add entity class that doesn't have @table into the diagram [message #816292 is a reply to message #816258] Thu, 08 March 2012 16:57 Go to previous message
Hi Petya,
thanks for clarifying...
regards,
Cristiano
Previous Topic:Generate tables from entities stop to work after convert JPA into a OSGi project
Next Topic:Preselected JPA Platform and Implementation on JPA Facet page?
Current Time: Sat Jan 16 09:55:12 GMT 2021
Powered by FUDForum. Page generated in 0.01932 seconds
