Bug with Papyrus and CVL [message #815464] |
Wed, 07 March 2012 17:44 |
leroy romain Messages: 4 Registered: January 2012 |
Junior Member |
hi,
i have this error in the error log: Unhandled event loop exception
plug-in : org.eclipse.ui
repport bug:
_____________________________________________________________________________________
at cvl.action.CVLEditorActionDelegate.run(CVLEditorActionDelegate.java:39)
at cvl.diagram.action.CVLTransformationAction.run(CVLTransformationAction.java:13)
at org.eclipse.ui.internal.PluginAction.runWithEvent(PluginAction.java:251)
at org.eclipse.jface.action.ActionContributionItem.handleWidgetSelection(ActionContributionItem.java:584)
at org.eclipse.jface.action.ActionContributionItem.access$2(ActionContributionItem.java:501)
at org.eclipse.jface.action.ActionContributionItem$6.handleEvent(ActionContributionItem.java:452)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1053)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4165)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3754)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2696)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2660)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2494)
at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:674)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:667)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:123)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:344)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:179)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:622)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:577)
at org.eclipse.equinox.launcher.Main.run(Main.java:1410)
and another error :
"No repository found at ..."
An exception stack trace is not available.
plug-in : org.eclipse.equinox.p2.metadata.repository
Can you help me please?
Thank you.
Romain
FUDForum. Page generated in 0.02362 seconds
