Home » Modeling » OCL » [OCLInEcore] Problem with OCL expressions containing type references from imported packages
[OCLInEcore] Problem with OCL expressions containing type references from imported packages [message #815247] Wed, 07 March 2012 12:17 Go to next message
Filip Krikava is currently offline Filip KrikavaFriend
Member
I have a problem to use types from imported packages in OCL expressions. Quick example:
package a:
module _'A.ecore'
package a : a = 'http[:]//me.me/a'
	class System
		property components : Component[*] { ordered composes };
	class Component
		attribute name : String[1] { ordered };
a package b:
module _'B.ecore'
import a : 'A.ecore#/';
package b : b = 'http[:]//me.me/b'
	class Instance
		property type : a::Component[1] { ordered };
		property parent : a::System[1] { derived readonly transient volatile }
			derivation: type.oclContainer().oclAsType(a::System);
This works as long as I don't close and reopen the editor. When I do that it changes the OCL expression for the derived property to:
derivation: type.oclContainer().oclAsType(System);
which is invalid. It correctly preserves the property types like (a::Component[1], a::System[1]).
Is this a bug (I tried to look for it, but I only found problems regarding the type definition rather than embedded OCL expressions)? Is there any workaround (besides merging the packages)?
Re: [OCLInEcore] Problem with OCL expressions containing type references from imported packages [message #815258 is a reply to message #815247] Wed, 07 March 2012 12:33 Go to previous messageGo to next message
This looks like https://bugs.eclipse.org/bugs/show_bug.cgi?id=362620
which was fixed in Indigo SR2.
Ed Willink
On 07/03/2012 12:17, Filip Krikava wrote:
> package a:
> module _'A.ecore'
> class System
> class Component
> a package b:
> module _'B.ecore'
> class Instance
> volatile }
Re: [OCLInEcore] Problem with OCL expressions containing type references from imported packages [message #815259 is a reply to message #815258] Wed, 07 March 2012 12:37 Go to previous messageGo to next message
Member
That is what I hoped, but I use: 3.1.2.v20120206-0606 and I think it is a different issue - my problem is not the model structure but the OCL expressions themselves.
Re: [OCLInEcore] Problem with OCL expressions containing type references from imported packages [message #815310 is a reply to message #815259] Wed, 07 March 2012 13:47 Go to previous messageGo to next message
Sorry replied too quickly. This is a problem fixed in Juno for the Pivot
model only.
The problem is that OCL, as specified, provides no way of binding the
'a' alias to 'A.ecore'. For Juno, I've introduced an extension so that
package names can be URIs and so the OCL saved in Ecore is
<eAnnotations source="http://www.eclipse.org/emf/2002/Ecore/OCL/Pivot">
<details key="derivation"
value="type.oclContainer().oclAsType(_'A.ecore'::a::System)"/>
</eAnnotations>
which is loadable by a compliant parser.
You will also need a compliant library to support the oclContainer()
function too.
So, your next question, how does this work in Acceleo? It doesn't.
This is an example of many corner case problems in the legacy code.
These are very hard to fix, hence the new pivot binding. It is very
unlikely that Acceleo will use the pivot model in Juno, so use of these
OCL fixes may have to wait for Kepler.
https://bugs.eclipse.org/bugs/show_bug.cgi?id=373518 raised to
investigate solutions.
Ed Willink
Re: [OCLInEcore] Problem with OCL expressions containing type references from imported packages [message #815312 is a reply to message #815310] Wed, 07 March 2012 13:53 Go to previous message
Member
Hi Ed,
Thanks a lot for all this clarification, it has been extremely useful!
/cheers
Filip
Previous Topic:OCL for Extended ECORE model
Next Topic:CompleteOCL in the Console: what to do with .ocl file
Current Time: Sat Sep 14 10:27:53 GMT 2024
Powered by FUDForum. Page generated in 0.04019 seconds
